Prius recall in Japan 1st?
Discussion in 'Gen 3 Prius Technical Discussion' started by ajc, Feb 9, 2010.
  1. ajc
    ajc Member
    340
    38
    pa
    Toyota initially stated that they were recalling all Prius in Japan only. Today :Toyota is recalling all Prius worldwide. Why didn't Toyota just say they will recall all Prius in the beginning? That was a bit shady or only they were taking care of their own country.
  2. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    Toyota, like all companies, runs pilot test on things first. These pilot tests are always done in a close and friendly environment. Toyota launched the Prius in Japan first as did Honda with the Insight. GM will launch the Volt in the US first.
    All I'm saying is that it is not unusual, and therefore in my opinion not shady, that Toyota would try their fix close to home rather than releasing it upon the world untested.
    2 people like this.
  3. prius convert uk
    prius convert uk New Member
    UK
    My prius left on the back of a low loader today, heading for my companys head office awaiting inspection from Toyota engineers:mad:
    Hopefully it will be back very soon as the Puegeot i have as a replacement STINKS:Cry:
    Hope the mod gets to the UK pretty soon
  4. socratesthecabdriver
    283
    31
    greece
    what is the recall for?????????
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,999
    Fort Lee, NJ
    It was for the feel of the brakes, specifically ABS when the traction if lost. It only happens with the loss of traction during pure regen braking.
  6. bwilson4web
    15,586
    It is a momentary pause in braking, ~800 milliseconds, if you have these four conditions:
    1. Speed under 19 mph (~30 km/h)
    2. Braking at a constant, moderate rate, pushing harder stops instantly
    3. Slippery street, rain or loose debris
    4. Speed bump or pot hole so deep it needs to be repaired
    If you Prius was sold after January, 2010, you should already have it . . . unless your dealer is exceptionally poor.
