Prius Reliability Statistics - Stay away from the 2004 Prius?
Discussion in 'Gen 2 Prius Main Forum' started by Sparky9292, Jun 10, 2009.
  1. Sparky9292
    Sparky9292 Junior Member
    37
    Earth
    These are ratings from Consumer Reports... should I stay away from purchasing a Prius older than 2004? Looks like those Prius have some serious electrical issues...
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,193
    Nixa, MO
    I bet that score is almost exclusively due to the Multi-display issues. I'm not aware of any other major issues that I would consider "electrical system" in nature.
  3. JimboK
    JimboK One owner, low mileage
    2,817
    187
    49
    Chesterfield, VA
    Your thread title asks about staying away from the 2004, whereas the body of your message says older than 2004. Big difference -- 2004 is a different generation.
    The 01-03 models have had a smattering of hybrid battery failures, which I'm guessing is what led to CR's downgrading for electrical issues. That still wouldn't necessarily keep me from buying one if the car was in good condition, though it might give me pause (and a reason to negotiate the price downward).
    It it's the 2004 you're referring to, I agree with Efusco. The MFD issue would be much less of a concern to me, given that there's an inexpensive fix for it. I too know of no other electrical issues in the 2004s.
    2 people like this.
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,531
    Southwest Colorado
    OP -- did you notice the overall reliability marks at the bottom ?
  5. efusco
    19,891
    1,193
    Nixa, MO
    I had one other thought, there were a couple of SSCs for some electrical issues for some of the very early '04s. It's been so long I don't remember the specific numbers, but there was an issue where the car would go into "limp home mode" occasionally. A simple firmward flash fixed that issue.
    As Jim points out, there's a huge difference b/w the '04 and the PRE-'04 Prius. You should clarify your question.
  6. richard schumacher
    7,663
    1,040
    United States
    Absolutely have a certified Prius technician check over the car. Most of them are at Toyota dealers, and Toyota has proprietary diagnostic equipment which few independents have. So many things could be wrong with any modern car after even moderate damage, it's scary.
  7. bwilson4web
    15,595
    I once drove a Model A Ford and compared to a Model T, it was brilliant. Compared to what we have today, the Model A was one step above a Flintstone's car. But there comes a time when a car moves from being practical to an experiment and learning lab.
    The 2001-03 Prius, NHW11, is certainly rapidly moving in that mode. We have a lot of data about how they work and insights about problem areas. The lessons learned from the NHW11 led to the NHW20, 2004-2009 and now the ZVW30, 2010 Prius.
    If you really want to learn how the Prius works, an NHW11 is a great school, but it should not be the only transportation. If you want to enjoy the lessons learned, get a ZVW30 and treat it as a "magic box."
    p.s. I started with a used, 2003 Prius bought in October 2005. We still have that car as well as a 2010 Prius. We sold the 2001 Echo.
  8. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    The thread title is a atrociously misrepresentative. Mods, please fix this.
  9. StangBanger
    StangBanger New Member
    38
    Miami,Fl
    Just got an 08.. no problems noted..Im lovin it..
  10. StangBanger
    38
    Miami,Fl
    How much is it to have the car looked at by a prius certified tech? at the dealership?
  11. northwichita
    481
    102
    29
    Wichita KS
    The reliability chart of the 04's shows decreasing reliability in the electronics. I had a bad time with my 04 prius with then 110 k miles just stopping dead on the road, the inverter electric cooling pump quit, overheated the inverter, and fuses were blown. I also had something smoke at the time, I doubt it was the pump, 35 k miles later I'm still not sure what all happened that day. Check on my profile for the message thread if interested.
    Anyway, would a failed inverter pump which causes the inverter to overheat and quit be an electrical issue or engine cooling issue for this graph. I would say an electrical issue. With increasing miles all models would be affected by this, just something for owners with older/high mileage cars to watch for, especially in the hot weather with increased electrical demand from the a/c.
  12. fgoodyear
    fgoodyear New Member
    187
    Tillson, New York
    The 2004 is the first year of a neww generatiion. Just as thwe 2010 is the first year of a new generation. I have found that you should never buy the first year of a newly designed car.... that's where all the bugs are found. New style , new problems. Wait until the next year, a lot of the bugs will be worked out and it will be a better car. I couldn't ask for better in my 2007 package 6. It is the 4th year of that generation. Most bugs are worked out.;)
  13. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    93,000 miles on my late year 2005. Zero problems and no warranty work.
  14. Celtic Blue
    2,224
    139
    Midwest
    The thread title still sucks. Looking at the chart the 2004 reliability is above average in every category save one...where it is average. It looks favorable compared to the previous model.
  15. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    Please interpret ConsumersReport data with a grain of salt.
    The data was collected from their subscribers only.
    The major issue is that consumersReport does not distinguish minor and major problems.
    A tail light recall could be interpreted as badly as MFD failure (both electrical). There is no weight put on each problem. It is a survery-based report.
    Of cource, 1st year model has its share of problems more than subsequent years. That applies to all brands and all models.
  16. Jared
    Jared Member
    209
    Long Island
    90,000 miles on my 2005 and nothing done except new tires and oil changes. Brakes are still like new. I didn't bother with a warranty.
  17. Sparky9292
    37
    Earth
    That's true. They do the surveys both in the mail and online. The questions are like:
    Did you experience an electrical problem with your 2003 Prius?
    Yes/No?
    It would be way to complicated for them to specialize each survey for each car. Still pretty useful, I always check the survey results before buying a used car. Keeps me from buying lemons.
    I always check the American cars first when I need a car, and it's always the same -- American sedan cars are the worst in reliability. Such a shame.:(
    Yes and at the bottom, the overall reliability is maximum for any model Prius.
  18. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,802
    1,170
    Auburdale FL
    All cars as they get older have more problems. Do a comparison for all cars 2003 and older and then post those results. I would be shocked if a 2003 did not have problems that needed fixed out of warranty.:confused:
  19. patsparks
    10,664
    567
    Adelaide South Australia
    My 2004 has been a shocker, piece of crap really. I had to spend $25 for repairs in the last 2 years, being a Toyota that disappoints me greatly.
  20. krousdb
    krousdb NX-74205
    580
    500
    47
    Raleigh, NC
    Pat,
    Mine has been an absolute disaster. I only have 177k miles on it! So far I have had to change the oil about 10 times! 3 sets of tires! 4 Air filters and sometimes I even have to put gas in it!:eek:
    I am in a constant state of alarm because in about 150k more miles I will have to replace the original brakes and spark plugs! Outrage! I might actually have to visit the dealership one day!
    But seriously folks, the only problem was the MFD which went flaky 9 months ago. I snagged on on ebay for $150 and installed it myself. I never buy an extended warranty, mainly because I have never had a bad experience with any of my Toyotas, Hondas, Subaru's and Acura.
