Prius Repairs, expense, and "environmentally friendly" discrepancy
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Pria2005, Mar 11, 2015.
  1. Pria2005
    Pria2005 New Member
    Flagstaff
    It’s undeniable that the main advantage of owning a Prius is for the fuel efficiency, but I’m beginning to see there are more disadvantages to owning a hybrid vehicle. Many of us know the controversy of the Prius being an environmentally friendly vehicle. Prior to buying my second generation Prius, I did my research and know that the vehicle production is more energy-intensive and results in higher production emissions than conventional vehicles, but this is offset by the Prius’s lifetime carbon emissions. However, I did not anticipate the amount of repairs and the frequency of them.
    I knew that the hybrid battery was an inevitable expense when I purchased the Prius. I was relieved to find out that there are alternatives to the estimated $4,000 battery replacement. Often times one or two of the cells are bad in the battery, which does not warrant a brand new battery - just a replacement of the cells. It’s unfortunate that Toyota does not offer such a repair given that the production of hybrid batteries require much more energy than producing a standard car battery and results in higher emission levels of gases like sulfur oxide. Also, the production of the battery relies on rare earth elements often coming from China who ignore the environmental safeguards during the mining process like removing topsoil and using acids that enter the groundwater.
    The production and the disposal of the hybrid batteries have given the Prius a bad reputation. Fortunately in 2010 Toyota launched a battery recycling program which may offset the carbon footprint, but it does not offset the expense and waste of creating a new battery. This does not seem like an “environmentally friendly” solution to me.
    It seems to me that Toyota’s strategy is to put you in a new Prius (that you will soon encounter issues on – like all vehicles.) But buying a new car does not resolve anything - agian not very "environmentally friendly". Toyota admits that the production of its lightweight Prius requires more energy and emits more carbon dioxide than the production of its gas-only models. The major reason is because hybrids like the Prius include more advanced components than a conventional car, including a second electric motor and heavy battery packs.
    These more efficient technologies of hybrids often have higher upfront costs because the additional technological element and electric components in them seem to create more issues to fix and more difficulty to work on them independently. Toyota has a monopoly over hybrid parts and services for these vehicles making them much more expensive for repairs because they are newer technologies and basically have to amortize development costs over a smaller number of units produced. For example, the cost to replace the center multifunction display on the Prius runs anywhere from $1,500-4,000!
    Since my car turned 150,000 years I have had to replace the Hybrid battery with an estimated cost of apx. $4,000 and the 12 Volt Battery with an estimated cost of apx. $450. Now I have a proposed estimate of $3,660.26 to fix the combination meter and the brake actuator which seems to be a manufacture defect and is out of its extended warranty. The total cost of repairs for this would cost: $8,110!!! (This is not considering the annual maintenance and costs for expected wear-and-tear on vehicles over its lifetime.) The cost to repair a Prius is absurd. It's cheaper to buy a used Prius, so it’s no wonder that most people opt to buy a new vehicle. It’s unfortunate that we live in a generation were we think that everything is disposable and not repairable. I think we are going to continue to see more issues as we move to more technologically advanced vehicles in the future and these issues are not going to be cheap or easy to fix.
    I have always loved Toyota for the longevity and integrity of their vehicles, but I have to say I am quite disappointed by their inability to uphold to their mission "To attract and attain customers with high-valued products and services and the most satisfying ownership experience in America."
  2. jdenenberg
    jdenenberg EE Professor
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    This discussion is nonsense. The recycling program dates back to the beginning of Prius production. replacing a Prius battery is about $3400 if you do it at a dealer, but there are less expensive options. A greenie like you should have considered recycling a low mileage battery salvaged from a wrecked Prius (less than $1000). Please don't publish inaccurate information.
    JeffD
    The Limey, ftl and PriusGuy32 like this.
  3. Pria2005
    Pria2005 New Member
    Flagstaff
    You are correct, there are less expensive options out there which is what I did if you read the above: "I knew that the hybrid battery was an inevitable expense when I purchased the Prius. I was relieved to find out that there are alternatives to the estimated $4,000 battery replacement. Often times one or two of the cells are bad in the battery, which does not warrant a brand new battery - just a replacement of the cells." There's no need to replace the entire battery. Instead of considered recycling a low mileage battery salvaged from a wrecked Prius I replaced the cells which is something a greenie like me would have done. Thank you. Please don't comment on information that you have not thoroughly read.
    #3 Pria2005, Mar 11, 2015
  4. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    A little bad luck there as the combination meter is indeed a Gen2 issue with a special 9 year warranty. I'm getting close too.
    Pria2005 likes this.
  5. ChapmanF
    18,954
    @Pria2005,
    In a matter of seconds, Mr. Google reveals that the bulk of what you just posted here is a copy/paste from:
    Roos, Dave. "Does hybrid car production waste offset hybrid benefits?" 06 December 2010. HowStuffWorks.com. <http://science.howstuffworks.com/science-vs-myth/everyday-myths/does-hybrid-car-production-waste-offset-hybrid-benefits.htm> 11 March 2015.
    Why is that? Are you Dave Roos? Did it just seem like some purpose would be served by recycling Dave Roos's five year old article on PriusChat without attribution? Did you check how well-accepted are the claims in Roos's article before reposting it here? What was your purpose in doing so?
    I guess the impetus may have been in your other post where something seems to be up with your instrument cluster and brakes. I'm sure the PriusChat community would be interested in details of that (codes, diagnosis by the dealer, how they arrived at it, etc.) and how to help you with the situation. But it only muddies up the issue when it's this hard to tease out what you're saying yourself from the copied parts of somebody else's old article.
    Have you had a chance to see the reliability findings in the current issue of Consumer Reports? It's unfortunate that your own car has had maintenance costs that are statistical outliers, but in statistics that has to happen to someone, and still doesn't seem to dislodge the Prius from its very distinguished reliability record.
    -Chap
    Wizeguy, ftl and wjtracy like this.
  6. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Good catch Chap.
    Well see my recent post "Consumer Reports 2015 Autos" the older Gen2 Prii, while still considered excellent reliability overall, do show some lower ratings in the Electrical reliability sub-category
  7. ChapmanF
    18,954
    ... yes, which still don't stop it from having the overall-summary row filled with full-red-best circles straight across the year columns, a distinction it shares with only four other car models in the whole chart: three Lexus models (thanks, Toyota!) and the Honda Fit. :)
    -Chap
    SageBrush likes this.
  8. Pria2005
    Pria2005 New Member
    Flagstaff
    As a Senior Member, you are probably aware that you are unable to paste links directly as a new member. Thank you for posting the link to the entirety of the article.
  9. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
  10. brucebee
    brucebee Junior Member
    84
    vista, ca
    If you are that worried about your carbon footprint, skateboardsm bicycles, or even a horse are probably better options. Autos have really come a long way. Never own a powerboat.
  11. ChapmanF
    18,954
    Ok, but wouldn't it be more usual then to say something like "Hey guys, I don't have enough posts to make a link but I saw this article by Dave Roos over at howstuffworks where he said ... and it got me thinking ..." instead of just trying to whip two scoops of his words and one scoop of yours into some unidentifiable meringue?
    -Chap
    ftl likes this.
  12. The Limey
    The Limey New Member
    England
    Hold the front page - ageing car in breakdown shocker!!!
    If you dont ljke big bills then stick to new cars with warranty. Used cars are a gamble, thats why they cost less. The odds with a used Pious are excellent, but not guaranteed. The bulk of used Prius owners do well, but its inevitable that not 100% of used Prii will not be fault free forever.
    You gambled, you lost, MTFU and move on.
  13. bisco
    52,773
    haven't seen one of these threads in a while. good education for the o/p though, if he's interested.
  14. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    One person's car repair experience says very, very little about the environmental advantages of the Toyota Prius.
    Now, a little fact checking:
    1. The 12v does not cost $450, or anywhere close. Current dealer pricing is about $2 USD/month when the warranty is considered.
    2. The traction battery is anywhere from $1900 - $3000, depending on who installs and where it is bought
    3. The recycling program exists from the beginning of Prius, and no data of CO2 footprint has been published but every other case of nickel recycling is considered a good thing so I see no reason to think the Toyota program is different.
    4. A new traction battery adds 50-100% additional life to a Prius. Find that deal in a conventional car.
    5. OP is confusing TCO with environmental considerations. A new combo meter and brake actuator is not going to move the needle in lifetime CO2 emissions. Overall the Prius TCO is brilliant; IIRC it shares the top position with the Honda Fit.
    6. There are no sulfur compound emissions from production of NiMH batteries. That distinction belongs to standard lead batteries.
    OP: Sorry to hear about your bad luck regarding the brake actuator. However, your attempt to paint that failure as a Toyota conspiracy of planned early obsolescence is at best sorely misinformed. It is a rare failure.
    A suggestion: rather than throw out nonsense, ask for help in repairing the car cheaply. Perhaps you have not yet antagonized everybody.
    #14 SageBrush, Mar 12, 2015
  15. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Your car has lasted 150,000 years and you're complaining about it finally needing a few repairs! Shesh;)
    cwerdna and Wizeguy like this.
  16. stonerider
    stonerider Member
    107
    Lompoc, CA
    Right up there with those who complain about having to replace a $50 part and saying they would never buy a Toyota again.
    Anyways, can you DIY brake actuator replacement job on a Gen 2 Prius?
  17. SageBrush
    11,627
    2,533
    Southwest Colorado
    Brake actuator replacement in pictures | PriusChat
    Does not look so complicated to me, but you may have to own and use a techstream in order to re-pressurize the system. Take my opinion for what it is worth, which is quite a bit less than a grain of salt.
  18. ETC(SS)
    7,494
    What if he's a she? ;)
    Is 'Pria' a masculine or feminine noun?
    (I already think I know about "Prius"..... :eek: )
    The Limey likes this.
  19. bisco
    52,773
    we no longer use her/his, man/woman, he/she. please don't try to determine my baby's future with your labels.
  20. SageBrush
    11,627
    2,533
    Southwest Colorado
    Best to be non-judgemental and just say 'it.'
