Prius resets itself every time it's turned off
Discussion in 'Gen 2 Prius Technical Discussion' started by Aaron Vitolins, Feb 9, 2017.
  1. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,145
    Franklin TN
    I think it might be a fuse. Surly all the bulbs aren't burnt out a one time. I will try switching some bulbs form my Prius to this old one.
    So I replaced the MFD unit and it wasn't working. Turns out a fuse was blown from when the screen was punched in. I wonder if it could have blown more fuses other than that one. What do you think?
  2. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    Replaced the battery and still acts up! No battery level bars on the MFD, and still resets itself
  3. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    Did the new battery get charged BEFORE being installed (very important).
    The battery bars on the MFD are for the HV hybrid battery, not the 12 V one.
    I think you need professional help sorting this out; dealer or other shop that knows hybrids.
  4. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    I understand that the battery bars are not for the 12v battery. I just think it's really odd that the arrows and battery graph have disappeared form a fully functioning and driving Prius. So weird!
  5. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    So my assumption is you mean when the car is in READY.
    Does it look the same as when you put it in ACC mode (1 press of the power button with foot OFF the brake)?
    Also, have you checked all the connections on the back of the MFD? Maybe pull each one and re-seat confirming they're all plugged in and fully connected (with a click, if applicable).
    #25 dolj, Feb 18, 2017
  6. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    Yes that's what it looks like! I guess that is a good next step, I'll remove it and reinstall
  7. jichi
    jichi Junior Member
    i had similar problem and it was the battery cable was loose . make sure it is tight. thats why it keep resetting. unless the battery is defective or bad
  8. Aaron Vitolins
    1,612
    1,145
    Franklin TN
    Where was the cable loose? On the battery connection? I replaced the battery and made sure the connection was tight. Thanks for you reply!
  9. jichi
    jichi Junior Member
  10. Qinti
    Qinti New Member
    Hawaii
    7 years later...
    So What was it?
    My 2009, keeps resetting and sometime doesnt even start...and then after 10 minutes, i try again and it starts...it sounds like 12V, but its brand new...i was rear ended not long ago, and since then the car started acting up...would the diagnostic find an issue at the hybrid battery? Im not even sure if the car would start at all if the hybrid had the issue...
  11. ETC(SS)
    7,571
    Aaron Vitolins was last seen:
    Jul 20, 2022
