Prius rough start multiple codes need help with this issue
Discussion in 'Gen 2 Prius Technical Discussion' started by Adam Kapit, Aug 14, 2017.
  1. Adam Kapit
    Adam Kapit New Member
    Los Angeles
    Are you asking me which shop I brought my car to? I titled it rough start because the mechanic said the car misfires before it starts. What does that mean that the inverter pump failed instead of the water pump mean or indicate?
  2. JC91006
    16,939
    8,647
    Neither of the 2 water pumps would cause a misfire at startup. If there's a misfire, you may want to address that before messing with the water pump.
    Your codes indicate you have an inverter water pump failure. But you shouldn't fix that until you determine what's causing the misfire.
    I'm close to Los Angeles and I'm curious at this shop you went to
    #22 JC91006, Aug 14, 2017
  3. Fredsimm
    Fredsimm Active Member
    188
    117
    Tupelo MS
    FYI. My daughter's 09 did the same thing with the inverter code. Her inverter coolant level was low. Low level will cause a pump failure code. I agree with the others here. Head gasket failure is rare. It could be water in the gas, or spark plugs. Or possibly an injector.
