Prius Sales Tank Even With Higher Gas Prices
Discussion in 'Gen 3 Prius Main Forum' started by jayrider, May 7, 2014.
  1. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I think you like the idea. :)
    It is a curious one and some issues such as running the lights and a/c when the car is just running off air. Perhaps an uprated electrical system is an option or perhaps led headlights to reduce power consumption.
    I'm looking forward to when they make their way to my local Peugeot dealer. I still like their 3008 diesel hybrid but there are other nicer cars out there for the money.
  2. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    I'm enamored by the idea :)
    Electric hybrids were conceived of 100 years ago but electronics had to catch up (along with a lot of Toyota ingenuity) to make them practical. In the case of pressure hybrids materials improvements has done the same and I suspect has an optimistic path forward. That at least seems clear for the tank. I am less sure about the high pressure plumbing and motors.
  3. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    There is a big difference in the energy released when decompressing gas and decompressing liquid. Compressing gas stores far more energy but it can also do a lot more damage if containment fails.
  4. hill
    8,802
    ..... A lot of ingenuity in deed, but I give a big nod to a certain ingenious (Dr. Severinsky) Russian imagrant too - who had to spend 6 years and big bucks defending his hybrid parents against Toyota:
    The Hybrid Inventor Who Sued Toyota – And Won | Autopia | WIRED
    ... just sayin' - It ain't easy going against the #1 auto giant, and successfully eating their lunch right in front of them.
    #104 hill, Aug 7, 2014
  5. wjtracy
    wjtracy Senior Member
    11,367
    3,608
    Northern VA (NoVA)
    The air hybrid is indeed facinating...but if its anything like nat gas the US version may require more cost. In the case of nat gas, in EU you can convert a car for ~$500-1000 to nat gas, but here we want min. ~$6000 for a special HP tank, so you're talking $7000+ for the same conversion here.
  6. Troy Heagy
    Troy Heagy Member
    1,218
    No it isn't. It could be improved with a smaller engine that eats less gasoline. It could be made from aluminum to reduce weight to ~2500 pounds. It could have a proper teardrop shape & wheel covers to reduce drag to 0.20. (I could go on and on but I won't. Lots of internet articles cover ways to make cars use less energy.)
    No it looks like a Toyota Echo with a trunk. The rearseats don't fold down. Blech.
    Technically the MPG king was and still is the Honda Insight (1999-2006). It not only scored 62 mpg on the highway test (55 combined) but also carried the badge as "greenest car you can buy" according to the American Council for an Energy Efficient Economy (greenercars.org). Even the Civic Natural Gas was not as clean (it ranked #2).
    I'm glad you like your prius. I like my prius too. But I don't delude myself into thinking it's the best or "flawless" or king. There are/were other cars that looked better, scored higher MPG, and of course there are many ways my car could be improved (aluminum, better aerodynamics, better canyon carving, more road feel, etc).
  7. SageBrush
    11,627
    2,533
    Southwest Colorado
    How many times have you been told that the 2-seater Insight was ULEV and the EPA tests were modified circa ~ 2008 ?
  8. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Erm in some parts of Europe you can convert a car (read that as old carburetor car) for $500, namely anywhere in Eastern Europe where standards and more importantly enforcement vary. The simple systems for carburetor or single point injection are cheaper but such vehicles are now few and far between and usually quite old.
    I was quoted about £1,800/$3,000 to convert the Prius to lpg as it needed multipoint lpg injectors etc. The circular lpg tank would fit where the spare sits and you have the choice of petrol or lpg. Because of the extra weight it was recommended to uprate the rear suspension which would have added more cost.
    Convert your petrol-powered vehicle to run on Autogas LPG | Autogas
    Are you sure $6,000 is correct? What is different between the tank or is it that it has to be registered and because of low volumes sold the extra cost is passed on?
    Environmental benefits of running a vehicle on Autogas LPG | Autogas interesting to see the emission reductions.
  9. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    Energy loss would depend on how good the thermal insulation is, how quickly the energy is used after compressing it, and environmental factors. There are many variables at play.
    As you probably know, the sooner the compressed energy is used, the less energy would be lost as heat.
    I was wondering if the refrigeration effect of releasing the pressure could be used to cool the passenger cabin, but I'm fairly sure this would be impractical.
  10. SageBrush
    11,627
    2,533
    Southwest Colorado
    The discussion was with regards to thermodynamics. Carnot cycle stuff.
  11. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    Actually, the max pressure of the tank is not a factor. When calculating a thermodynamic cycle what I really need is three of the four location points on the thermo graph chart. (I'm old fashioned, I'm use to plotting cycles.). In this situation the energy inefficiency is the area enclosed and those location points are not identified in your question directly. A set of pressures and temperatures for at least three points in the cycle is needed.
    For example, if the tank is fully insulated and suffers no temperature loss, it should be close to 100% efficient. It is acting like a big spring in this situation. If the tank is completely charged in hot air on a hot day and then cools to morning ambient before discharging, then the area gets big and the losses are significant.
    What I do know is ANY energy storage device of reasonable efficiency (battery, HP air, flywheel) can be engineered to make for much more efficient autos.
    SageBrush likes this.
  12. SageBrush
    11,627
    2,533
    Southwest Colorado
    Well, as long as I am putting my thermodynamic ignorance on display, please explain why the drop in temperature inside the container is not part of a Carnot cycle
  13. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Actually, using a HP air tank as an energy storage medium is trying to avoid being part of any thermodynamic cycle, Carnot or otherwise. So any thermal losses in this application are pure energy losses. Now a cyclic temperature change in this energy storage setup can be shown on a Carnot plot of Pressure vs. Volume. Think of it this way:
    1) Empty HP air tank is pumped up to 500 psi. The tank heats up to 200 degrees. (This a seat of the pants calculation, not an accurate one.)
    2) Overnight tank cools to 75 degrees. Pressure lowers to 400 psi. (Useless heat loss.)
    3) You only get 400 psi of work out for the 500 psi of work put in.
    4) The rest of the work went into heating the planet.
    That is a cycle, but not a Carnot cycle where the useless heat loss is designed to be (close) to zero. So any area enclosed on a Carnot like plot is useless energy loss.
  14. SageBrush
    11,627
    2,533
    Southwest Colorado
    FPL,
    Starting from your point that tank PV losses and loss to the environment can be close to nil, and assuming a serial hybrid configuration using a diesel engine operating @ 45% efficiency, P/M with 2.5% losses each way and a gearing that loses 3%, I calculate 41.4% of each gallon's energy reaches the wheels.
    Since diesel's energy content is ~ 11% higher than petrol, I calculate
    15.348636 kWh to the wheels per gallon of diesel.
    Assuming 200 Wh/mile, that works out to almost 77 MPG (us)
    Sound about right for a target ?
  15. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    I don't see how you got the 41.5% with the losses presented, but that is minor. The overall calculations work out sensibly.
  16. SageBrush
    11,627
    2,533
    Southwest Colorado
    45% thermo efficiency for best in class diesel car engine
    2.5 + 2.5 + 3.0 percent losses in the drivetrain, so
    0.45*0.92 = 41.4% tank to wheels
  17. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Does this link better explain how this air car works?
    Peugeot 2008 Hybrid Air prototype review | Auto Express
    Not being educated in such matters I am probably wrong but it appears to be more hydraulic than just compressed air. The main tank holds compressed nitrogen and oil and pushes it through the motor to a lower pressure tank, or that's how I read it. I'd imagine nitrogen is more stable and the oil helps keep pressure stable in various temperatures?
    "Central to the HYbrid Air's powertrain is a compressed air tank, entirely self contained, which can hold 20 litres of nitrogen and oil at a pressure of 220 bar. By discharging this tank and forcing the oil through a hydraulically actuated motor which spins the front wheels."
  18. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Got it.
  19. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    That answers two questions I had:
    1) An accumulator is a standard name for a tank holding both compressed air and liquid in the same tank. There may or may not be a piston or separator (e.g. bladder) between the air and liquid.
    2) The real engineering challenge is for a real high efficiency method of converting expanding air into rotational motion. Using an intermediate liquid makes the size and efficiency of this conversion occur in a lot smaller space compared to using air. The liquid can be optimized for temperature range, lubrication, and viscosity. All the issues with moisture in the compressed air is totally eliminated with this approach.
    Now the issue is cost effectiveness. Given the EU cost of fuel, this should take off.
  20. wjtracy
    11,367
    3,608
    Northern VA (NoVA)
    ...closer to $12000 for my minivan (I have VW-badged Dodge Caravan disucssed in the PM article):
    How to Convert Your Car to Natural Gas - CNG Conversion - Popular Mechanics
    In the USA, gaso ICE is our cheap case, everything else is $5-10k more, right?
    ICE gasoline $BASE
    ICE Hybrid +$5000
    CNG ICE (Civic GTX) +$8000
    CNG Conv +$8000
    Diesel (Cruze) +$8000
