Prius self-started!
Discussion in 'Gen 3 Prius Main Forum' started by Kermit262, May 3, 2011.
  1. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    I've had this happen many times when turning off the car and then pushing the button again for the radio. I think it's a timing thing. If you hit the power button immediately after turning off it goes right back into ready mode. If you wait half a beat or so then it doesn't. I've been meaning to look it up and see if this feature is designed in that way, but have never gotten around to it.
  2. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Normal behavior per the manual.
  3. Rocco42
    Rocco42 Member
    115
    30
    Rosendale, NY
    I found a small grey skinned guy with long fingers in mine last week. I told him that he better get out of here, and haven't seen him since. I think he was trying to abduct my cat, but who the heck knows.
    I have heard that the Prius uses alien technology from some Neanderthals that I have the dubious pleasure of knowing. Then again, what do they know, they still drive around in horse powered buggies!
    :D:D
  4. WE0H
    WE0H Senior Member
    3,247
    527
    I just put it in Park as the motor is off anyhow.
    Mike
  5. BhamPrius
    BhamPrius Member
    128
    Bellingham, WA
    Yeah, that's what I was wondering. In previous non-hybrids, I of course always shut it off. With the Prius, I'm wondering about just putting it in park. That way it'll still be warm & running after the fill-up. Anyone else want to chime in on this?
  6. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    I keep the car off on the off chance the car will start the engine.
    I don't keep conventional cars running when I fill up on gas.
  7. DetPrius
    DetPrius Active Member
    545
    92
    Southeast Michigan
    I seem to recall reading here that there is something that changes when it is off vs in Ready mode, that is related to the fuel system, and it should be off when fueling. Tom, was that you?
    I have meant to put it in Acc mode, had the foot on the brake out of habit and unintentionally put it in Ready mode and that is what I suspect happened to the Op.
  8. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    Or the OP pushed the button too quickly after turning off (even with the foot off the brake), in which case it'll fail to switch mode. This is per the manual.
  9. midwife
    midwife Prius on the way!
    Indiana
    :D Indeed!
  10. Troyroy
    Troyroy Member
    373
    30
    Troy, NY
    I just put it in park.......with the updated gas vapor return hoses on most gas pumps in the country.......I don't see a problem with it......chance of a spark causing a gas explosion are slim.
    My opinion !!!!!!
  11. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    I'd be willing to say it is zero from the engine starting. Static electricity is another matter when the air is very dry but that has nothing to do with the engine.
  12. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    Congrats! Lets add the human factor into the operation. You turned the car off then turned it on again (foot was on the brake). Enter Ready mode, Radio came back on, you got out of the car, it beeped 3 times, you ignored it. 10 seconds later the car started while you were filling up. Simple. :D
  13. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    You must have one of the new radioactive mutant its alive models!
    Had this happen with a Lexus, OK who has the 2nd keyfob on them? I don't get to drive these fancy pushbutton type cars that much. Always forgetting to push off or ending up in acc ie why are the wipers still on.
