Prius Shifting issue
Discussion in 'Gen 2 Prius Main Forum' started by Suman, Mar 26, 2019.
  1. Suman
    Suman New Member
    Four Touring
    I am having a shifting issue with my 2007 prius. After I reset my car by disconnecting the small battery, the car works perfectly. However after sometimes the red triangle is coming back on the dash board and a "problem sign" comes on the display window. At this time if I park the vehicle, it's not shifting to drive or reverse now. Only going to neutral. If I do the resetting process again, the the car works again perfectly..I checked my big battery, all the blocks showed more than 7.8V. And changed the small battery too. Changed the transmission oil too. Still the same..
  2. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Get the fault codes read immediately.
    SFO likes this.
  3. Suman
    Suman New Member
    Four Touring
    No fault code are coming
  4. kenoarto
    398
    Chicago, IL
    Are you using Techstream?
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Most likely you have a HV insulation resistance fault. Typically caused by electrolyte leakage from a module in the HV battery, but can be many other causes (cable insulation, inverter, transaxle). An electrolyte leak will have very little, if any, impact on the module voltage. It can usually be identified by discoloration on the metal plate the modules are mounted to.
  6. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    If you have a red triangle locking in, then there's a code in there waiting to be read. It may just be your reader is not hybrid capable.
    SFO, Raytheeagle and kenoarto like this.
  7. Suman
    Suman New Member
    Four Touring
    I am using a kitbest obd2 reader with torque pro app.
  8. Suman
    Suman New Member
    Four Touring
    Yeah suspect the high voltage leak too.. But how to check that I don't know..
  9. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    So torque is not showing any Diagnostic Code?
    Unfortunately, I'm not familiar with torque, as I use techstream for all things prius, but I've heard a lot of good things about it.
  10. Suman
    Suman New Member
    Four Touring
    Nope...I have run so many times..it says no fault codes are stored in the ECU..
  11. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    You may need to drive to a parts store like AutoZone or similar to see if they're able to use one of their readers to see if they can pick it up. There should be a DTC and subcodes in the freeze frame data.
    The only time that the Red Triangle lights and provides no code (as far as I'm aware) is when oil pressure is low.
    Makes me wonder if it would be worth the forum making a member location list showing who has Techstream, where they are (generally) and how far they'd be willing to go to provide assistance.....
    SFO and Raytheeagle like this.
  12. Suman
    Suman New Member
    Four Touring
    Thanks.. I live in Auburn,Alabama..If anyone is near by that would be great..
  13. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Looks like he’s in Auburn, AL if the location and zip code align;).
    Not sure who’s in the general vicinity either:cool:.
    I agree that There is a code there though(y).
  14. Suman
    Suman New Member
    Four Touring
    My zip code is 36830
  15. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    5 hour drive is a bit much for me tonight.......I hope you get lucky and someone nearby chimes in...
    SFO, Suman and Raytheeagle like this.
  16. kens97uber171
    kens97uber171 Active Member
    177
    133
    US
    If torque cannot read the codes any code reader you're going to find at a regular auto parts place is probably not going to see anything either. You might try dr. Prius app or hybrid assistant app. I believe they can see and clear Hybrid battery codes as well as others. Both are free on the app store
  17. bisco
    52,847
    is there movement in the inverter fluid?
  18. dolj
    dolj Senior Member
    8,641
    4,393
    Wellington, New Zealand
    Not wanting to reach Grandma to suck eggs, but you loaded the Prius specific extended PIDs in Torque Pro, didn't you?
    Also, don't disconnect the 12 V battery before reading the DTCs. You will not see any DTCs after you have disconnected the battery, hence why the light(s) go off after doing so.
    Skibob likes this.
