Prius shut down while driving. Won’t start back up
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Stacy Packer, Aug 4, 2022.
  1. Stacy Packer
    Stacy Packer New Member
    Georgia
    I have a 2005 Prius. I was on my way home and it cut off while driving. And wouldn’t start back up . I didn’t have any warning lights till it died. I had to have it towed to my daughters house does anyone know what it could possible be. I need to get it moved. Because it’s blocking a culdesac but I can’t get it to power on enough to even put it in neutral
    52,629
    probably a blown fuse
  3. Should redirect from Prime to Gen 2 forums to get more replies from others who may know more about this model.
  4. monoshock
    monoshock Member
    66
    27
    Rocky Top TN
    Doe it have a burnt wire smell around the left headlight ?
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    This is most frequently caused by the AM2 fuse opening in the underhood fusebox due to the inverter cooling water pump failing electrically.
    If so, you can disconnect the pump from the circuit, install the spare 15 amp fuse and be on your way. The car will be drivable as long as you stay under ~40mph so the inverter doesn't get overly hot.
    Look at this thread, I have some photos in it to help..
    Completely died while driving. 12v good, but no power | PriusChat
    alftoy and ydpplqbd like this.
  6. pasadena_commut
    pasadena_commut Senior Member
    2,960
    907
    Southern California
    Be aware that the outside temperature should be cool as well. Wait until evening or early morning. Trying this at 3:00PM on a 102F day will not result in much range before the warning lights come on.
