Prius shuts down after Starting?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Paul OByrne, Mar 30, 2018.
  1. Paul OByrne
    Paul OByrne Junior Member
    36
    Tampa, FL
    My 2005 Prius was running great until I went out of town for several months and had a friend turning it on once a month until it started shutting itself off after 10 seconds, which is current status. I am back and trying to figure it out. Please let me know if you have heard of this symptom and have any ideas on a fix.
    So far I have found the key fob went dead and was responsible for throwing an error code B2775- Immobilizer, but that has cleared up by using the other key. The HV Battery is reading at 15v and other battery at 12.5 v
    I now have these codes remaining:
    POAOF- Hybrid Control- engine failed to start
    P3190- (poor engine power)- and P3191 (engine failed to start)- both from Engine & ECT
    On my car screen- energy generated- it shows the engine generating juice for those 10 seconds, before shutting itself off.??? Let me know any ideas or tests I can try. Thanks
    51,154
    how many miles on her? any gas in the tank?
  3. ChapmanF
    17,343
    Be careful here ... the P3191 is correct, the engine never started. You thought it did, because a Prius cranks the engine at around 1200 rpm, fast enough most people who hear it think the engine started and then cut out. Nope, just being cranked, and then the system gives up.
    Every such cycle uses a bit of charge from the HV battery, and you don't have an easy way to recharge that. So you are on a strict budget of starting attempts.
    The reasons the engine might not start are the same usual three suspects: fuel, compression, or spark. So from here on out, you should be planning your remaining start attempts, and placement of your test instruments, such that each attempt will tell you something you don't yet know about one of those three things.
    If you have any diagnostic tool (even a ScanGauge II, for example) with which you can watch the traction battery state of charge, you'll be able to have a better idea how much it drops on each attempt, and how many you might have left.
    -Chap
    jerrymildred, valde3 and SFO like this.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    What obd device are you using? It should show more codes than that I don’t think your seeing the whole report,
    You need a techstream device that has TIS software that will capture every single code and point you in the right direction. Without that you will have no where to start. Best you can do is check For gas check the 12 under load and All the fuses.
    And yes the clock is ticking on engine start attempts.
  5. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Three threads, and running. The PriusChat search feature works quite well at the moment, it can be your friend in times of need.
    Did you put gas in the tank? (4 gallons should do it)
    First turn off the SKS (button under the steering wheel) and any interior lights that may illuminate if you open the doors. This could help save your 12V battery from draining further.
    Here is a recent thread that might get you up to speed on things to think about:
    Sudden loss of power, Red Triangle, Won't Start + P3190 | PriusChat
    Raytheeagle likes this.
  6. Paul OByrne
    36
    Tampa, FL
    Thanks for the ideas- and Sorry about the multiple threads- was not having good luck with search feature and answers. Frustrated!
    I bought a VXDIAG and these are the codes that came up with Techstream. If there is a tip to find other ones more precise I'd love to hear.
    I think I did make an error on install, so not able to enter the TIS section for more info. as it asks for log-in name and password.
    I have a full tank of non-ethanol gas. I will double check the batteries. Its hard to believe that the engine is not running. I've been driving Prius for years and it sounds and feels exactly like it's running as with a normal start-up, but like clock work shuts itself off at 10 seconds.
    I will check the plugs and spark.
    Thanks for any and all advice
  7. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Did any of the codes have a “snow flake” icon just to the left of them? That icon will allow a deeper drill into the code. With the P0A0F, there should be some INF codes which will point you in the direction to go next;).
    If you can get those, I have a 2 day subscription active into tech info, so I could help once you get those sub codes:).
    Just don’t forget you are on a pitch count as there are only so many starts in the hv battery;).
    Good luck and keep us posted(y).
    #7 Raytheeagle, Mar 31, 2018
    SFO and bisco like this.
  8. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    they all run for 10 to 15 seconds when you first start them and shut down..
    does the car still move after the ICE shuts off?
    what warning lights are on the dash?
    give tampa hybrids a call, if he has the time the owner is very helpful and can walk you through what to check...
  9. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Just to clarify, there is only one 12v battery in a Prius.
    The other battery is the HV traction battery which is over 200v.
    Did you have a chance to read through the thread linked above, paying attention to post #9 (HV battery state of charge after reconnecting 12v battery) and post #14 (cleaning MAF and intake after reconnecting the 12v battery) and the work up for P3191 and P3190 in post #23.
    What have you done so far, besides the 12v battery and adding gas?
    At this point I would go slow with the repeated starting attempts, unless you have a way to recharge the HV traction battery. Once the HV battery is low enough it will no longer allow you to turn over the engine.
    You might also be able to save some time/money by finding a qualified hybrid mechanic.
  10. Paul OByrne
    36
    Tampa, FL
    OK, Thanks guys, I have read the other threads and done several things without success so far. Update:
    The vehicle has 191K, was left for several months with a full tank of non-ethanol gas, still full.
    My care taker started and drove a few times then did not start after 6 weeks idle.
    They tried to jump it, and said it ran as long as the other vehicle was attached?
    and I have charged 12V battery a few times now, since my return.
    The car still attempts to start, but I'm only trying it when I think problem is resolved..
    I have basically given it a tune-up- changed plugs, check air filter, new PVC valve, Cleaned the Throttle body and air intake and the mass air flow sensor.
    Still coming up with same two codes: POAOF- Hybrid Control, and P3191- Engine & ECT, both for engine failed to start.
    I did key in on the blue asteric for more info. and it provided the background data from those systems, but I'm not savy enough to know what data may lead to solving the problem. Next step suggestions?
  11. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    How many bars/color do you have on the battery display? Is it the original HV battery?
  12. Beachbummm
    1,160
    392
    you said it runs if another car is jumping it... id jump it off another car and let it run to see if your hv battery is charging.. of course be sure ac radio lights are all turned off.. watch the display it should charge unless the charging system is fried.. might have rodent damage to the wires... id also take the 12 volt to autozone from a load test, odd are its bad.. resting voltage is meaningless if it drop drasticly under load..
    did you call todd at tamp hybrids?
  13. Paul OByrne
    36
    Tampa, FL
    Actually my caretaker said this and I'm not sure of how factual that is, but I suppose it may be worth a try.
    I'm thinking you may be right on the 12 V battery- a load test is a good suggestion.
    What levels would be too much drop under load test and verify its a bad battery.?
    I have not called todd as I'm not ready to tow it in yet.
    Do you think he could have additional insights beyond those on this forum?
  14. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    What were the INF sub codes (background data) that you keyed in on, that could help in solving the problem.
  15. Paul OByrne
    36
    Tampa, FL
    I did not see any sub codes- just a lot of data from different systems. I have bought a new 12V battery but the HV battery level appears to be too low to start it. Contacted Tampa Hybrid for assistance with recharge.
    SFO, jerrymildred and Raytheeagle like this.
  16. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    What is the State of Charge of the hybrid battery.
    I would imagine it is quite low after all the starting attempts.
    After recharging pack there are a few things you should do to increase possibility of the car startin.
    Clean MAF
    Clean throttle body
    Sop up extra oil from below throttle body
    Use some starting fluid down the throttle body when trying to start. Keep adding as necessary to keep it running until Prius takes over.
    If youydecide not to tackle this yourself Tampa Hybrids will do a good job if you have them do it.
  17. fotomoto
    5,629
    3,802
    So. Texas
    You didn't answer if it's the original but if it is...... be prepared for some bad news. Old, tired batteries don't like sitting unused. Once a month isn't enough. BTDT
    GOOD LUCK
  18. Paul OByrne
    36
    Tampa, FL
    Well I have bought a new 12 V Battery, and charged the Traction Battery, and all other tune-up stuff mentioned except use starting fluid- and still not luck- but the current codes cleared but a prior one re-appeared- not sure why B2775 Immobilizer- interior verification (to theft deterrent ECU/ smart Key ECU) came back. Will try the starting fluid if I can clear up the Immobilizer issue.
  19. edthefox5
    10,096
    4,831
    Clearwater, Florida
    How did you charge the traction battery?
    SFO and Raytheeagle like this.
  20. Paul OByrne
    36
    Tampa, FL
    I rented a charger from Todd @ Tampa Hybrid. So I cleared the B2775 Immobilizer code and fired it up with the help of starting fluid and it ran as long as I kept the starting fluid flowing- 100 seconds, but when I stopped it shut down and the same old error codes were back- POAOF with sub code 204? and the P3190. It acted as if it was not getting gas- and one of the data points for P3190 stated- #1 fuel system closed. Not sure where to go with that info. or if that is really the problem, but it makes some sense.
    Secondly, that short 100 second run ran down my traction battery several bars? Any thoughts or ideas for next steps?
    SFO likes this.
