Prius shuts down after Starting?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Paul OByrne, Mar 30, 2018.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Check your fuel pump, or the fuel rail pressure;).
    If the car was running for that short time and the battery is draining that quickly, you’re on a very limited pitch count:(.
    Good luck and keep us posted (y).
  2. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    So it runs when you directly add fuel (starter fluid).
    It dies when you removed that fuel source.
    Check to see is the fuel pump is running. If it is, check psi.
    jerrymildred and Raytheeagle like this.
  3. Paul OByrne
    Paul OByrne Junior Member
    36
    Tampa, FL
    So after a lengthy learning session- about diagnostics and about many aspects of the Toyota Prius,
    I've determined that my problem was my fuel pump that went out- which makes sense- as it sat idle for over a month
    which was not the plan, but it happened, and it has 191K miles on it so it was due to go soon, sitting like that didn't help.
    I'm turning it over to Todd at Tpa Hybrid to handle that job, then it should run like a champ with all the other work I did on it.
    Thank you guys for all the insights and ideas along the way. I have another Prius needing some work also- HV is weak
    I may invest in the charger/ de-charger system to recondition that one too- Hybrid Automotive the best choice?
    Raytheeagle, bisco and SFO like this.
    52,761
    yes, all the best!(y)
    Raytheeagle likes this.
  5. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    If you have more than one Prius, the economics of Prolong equipment ownership improve:).
    Good luck with your Prius (y).
    SFO likes this.
  6. Danny13pruisc3
    175
    28
    maryland
    Was it the fuel pump?
  7. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    If you are having troubles with your Prius c, I would suggest that you search in those forums and post your questions there too. You cannot guarantee that what works for one model of Prius will work in another model,
