Prius sign after engine wash
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Lukman, Sep 13, 2020.
  1. Lukman
    Lukman Junior Member
    Zambia
    Hello my friends
    I took my 2010 Prius to total filling station wash..they washed It form outside n inside n then they washed my engine bay..after the wash when I started the vehicle,it is showing me some signs..one is brake system warning light in yellow ndicator,slip indicator,master indicator n malfunction indicator..I talked to the manager n he said that it might be of the water has gone inside some sensors n might bevy tomorrow it will be normal..
    Now I am a bit afraid that what will be the problem..please suggest me that whether I should wait till tomorrow to see whether it is normal or should I have to consult some mechanic for it
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Welcome. Scary stuff! Most people recommend agains washing the engine bay. So does the owner's manual:
    That said, I have gently washed the engine once or twice. Yours will probably be OK once it dries out. If they used high pressure, though, water could have damaged or disconnected something.
