Prius sitting for 5 years, help needed ASAP!
Discussion in 'Gen 3 Prius Main Forum' started by Eric Victor, Aug 16, 2019.
Thread Status:
Not open for further replies.
  1. fuzzy1
    10,687
    He says he inherited it, so presumably he is the legal owner. Do any states have age restrictions for owning property? Note that owning a car is legally separate from, and not connected to, being licensed to drive it on public roads.
    Being a minor, he may not be able to sign contracts to buy or sell, but that doesn't preclude receiving gifts and inheritances.
    Note also there are states ( PA not included) were learners permits are available at his age. I even had an actual driver's license at his age, though all the states where that was once possible have since raised their minimum ages.
    #21 fuzzy1, Aug 17, 2019
    52,740
    does asap mean faster than a day?
    Raytheeagle likes this.
  3. Eric Victor
    Eric Victor New Member
    Pennsylvania
    Well, since i legally inherited it in the will, my mother will drive it regularly for about the next year and a half until I get my permit. She is legally in charge of the paperwork, and my step dad is trying to teach me about cars, so this is a project we need to work on by next week before the auction of items on the property, so we might tow the car also.
    Montgomery likes this.
  4. Eric Victor
    Pennsylvania
    I got a little bit of time, but only about 6 days before the auction of the property.
    Montgomery and bisco like this.
  5. Leadfoot J. McCoalroller
    8,257
    7,760
    Pennsylvania
    2018 Prius c
    Howdy neighbors. Sounds like you're both within 20 minutes of me too.
    Unfortunately I'm on a work trip now, won't be back there until the end of the month.
    Montgomery and Raytheeagle like this.
  6. bisco
    52,740
    if you inherited it, why are they auctioning it?
    The Electric Me and Johnny Cakes like this.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    Do we solve anything in a day around here:whistle:?
  8. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Sounds like it’s time to start a local meetup:).
    When out to see my folks in the greater Wilkes-Barre Scranton Area, I’d stop by(y).
  9. Eric Victor
    Pennsylvania
    Well, we need to get it out of the driveway and headed to our house so the auctioners dont auction the Prius.
  10. Eric Victor
    Pennsylvania
    Also, im super excited to have this cars, since i have been fasinated since a little kid by Hybrid .
    davecook89t, RMB, mjoo and 1 other person like this.
  11. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    If it was me I'd also do a complete EGR system clean while you're pulling the spark plugs out to add oil. @Mendel Leisk should have links for you in his arsenal and posted momentarily... I think he has a special keyboard shortcut programmed for this task. Maybe [ctrl]+E+G+R?
    Pixel XL ?
    #31 mjoo, Aug 17, 2019
  12. Mendel Leisk
    42,219
    I still think a lot of cargo cult going on here. Sure there could be a lot of things knackered, but why not just fire it up, see what transpires. Yeah check the oil level, tire pressures, and for sure you'll need a jumper cable.
    dubit, mjoo and Raytheeagle like this.
  13. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    But hasn’t the old cargo cult become the new sidewalk to supervise :LOL::ROFLMAO::LOL::ROFLMAO:.
    But give it a shot and see what happens (y).
  14. bisco
    52,740
    great learning experience. consider adjusting the valves too (y)
  15. avongil
    avongil Member
    67
    56
    Easton, PA
    Take plugs out, squirt some atf in. Rotate engine by hand a few times. Replace battery. Change oil and oil filter. Fire up see if it runs. The reason for this is to minimize engine wear due to rings sticking or rusting. The oil is bad, it has absorbed too much bad stuff and broken down. The 12v is dead for sure- don't even risk it. the air filter was also a great suggestion.
    bobzchemist, Mendel Leisk and mjoo like this.
  16. frodoz737
    frodoz737 Top Wrench
    4,790
    2,553
    33
    Bad gas is the single most overlooked item if you turn and burn. Follow the above post, but hook up a remote can of fresh fuel for your initial start and run. If all is good, then remove as much of the old fuel as possible and flush the system before it enters the injection system. Then start with fresh. Even lawn mowers will foul with +5 year old gas...and that's with a simple easy to rebuild carburator.
  17. fuzzy1
    10,687
    If it was grandma's car, and has been parked for at least half its life, it is very unlikely to have anywhere near enough miles to have built up an EGR clogging problem. Skip this issue for now, just get the car running again. The EGR issue can wait several years.
  18. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    I don't assume to know the mileage. This is a 10 year old car. In any case it's good for the OP to learn about a common issue.
    Pixel XL ?
  19. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
    Also make sure to flush/replace the brake fluid as soon as you can, but certainly before you do any kind of sustained driving.
  20. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Yes. They ALL do, in one form or another.
    Most places you can't be the legal owner of ANYTHING if you are under 18.
    Some places, you can't legally register a vehicle if you don't have a valid drivers license.
    Since they usually won't issue a title unless you also register it at the same time.......no registration means no ownership.
    Grit likes this.
Thread Status:
