prius starts and dies
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by kakabro, Oct 26, 2020.
  1. kakabro
    kakabro New Member
    princeton TX
    my 2006 prius starts but dies immediately. I have replaced throttle body with a used one but in vain. every idea will be appreciated.
  2. PriusCamper
    PriusCamper Senior Member
    13,263
    5,358
    Pacific Northwest, USA
    For starters, the way the HV battery spins the motor gives the impression the engine starts and dies, but in truth the engine never starts, it's just that HV battery spins it faster than a normal starter does on a regular car.
    Do you have any error codes? How do the spark plugs look? What were the symptoms leading up to the engine not starting?
  3. JC91006
    16,886
    8,623
    Does the car have enough gas? Try putting in a few gallons
    Raytheeagle likes this.
  4. aloys
    aloys New Member
    princeton TX
    Thanks a lot. Initially it didn't have gas or just had one square showing on dashboard.
  5. aloys
    aloys New Member
    princeton TX
    I will check on codes. I filled up the tank and will check if it works
  6. borgestes
    borgestes Member
    89
    76
    New York
    That's how I fixed the kids car, the one listed needs tow, bad battery bad transmission. I added 2 gallons of gas and put a jump pack on it and drove it home. Kids been driving it ever since :) Awesome car
    The last fuel bar light will not go out..even when the tank is empty.
  7. aloys
    aloys New Member
    princeton TX
    So meaning that when prius dies of gas I need to feel up the tank?the codes it was showing me had something to do with throttle body an I have already ordered a new one online an hoping to get it soon.
  8. JC91006
    16,886
    8,623
    When you run out of gas on a gen 2 car, you usually have to put 3+ gallons in for the car to run properly again. The fortune cookie codes only tells you the computer detected a problem in a certain area, it doesn't go through diagnostics to see if there are other issues that caused that detection.
  9. aloys
    aloys New Member
    princeton TX
    Whenever I try to start the car I smell gas. It's like it gets around throttle body but never burns.i replaced plugs.
  10. aloys
    aloys New Member
    princeton TX
  11. aloys
    aloys New Member
    princeton TX
    These are the codes my prius is showing. I replaced throttle body but in vain.its full tank. I put a capacitor at the cluster as it would go black at times.
  12. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Most of those OBD2 codes (DTCs) aren't related to a gen2 Prius.. "Turbo Charged Control Circuit Malfuction" ? (don't think so).
    That OBD2 code reader or App is suspect at best, not all OBD2 scanners are toyota hybrid compatible, many DIYers prefer to use a 'Mini-VCI' cable (usd 20) and techstream (dealer technician software) installed on a windows device. Others get by with using a App like Dr Prius or Hybrid Assistant, read up on the required adapters for either App here : Hybrid battery diagnostic and repair tool for Toyota and Lexus
    Good job replacing the cap(s) in the dash/combination meter.
    PriusCamper likes this.
  13. kdfchannel
    kdfchannel Junior Member
    59
    17
    Orlando, FL, United States
    I think I also have a gas problem with my C tomorrow I'll check the fuel pump
  14. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    #14 edthefox5, Mar 19, 2021
  15. kdfchannel
    59
    17
    #15 kdfchannel, Mar 19, 2021
    edthefox5 likes this.
  16. edthefox5
    10,096
    4,836
    Clearwater, Florida
    no not you.
  17. dolj
    dolj Senior Member
    8,618
    4,375
    Wellington, New Zealand
    You need to be posting in the Prius c forums. This a Gen 2 forum and not all problems translate across the different Prius variants.
