Prius starts fine but idles a little rough
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by halpos4, Feb 17, 2011.
  1. Mendel Leisk
    41,512
    Does the second Gen have adjustable valves, shim-on-bucket style? They will drift. They are more stable than screw-and-locknut type (Honda for one), but...
    Shim style is likely left to pros, I believe they are difficult to check/change for DIY'r. Probably expensive though, due to the difficulty.
    Off-topic: is 3rd gen hydraulic, self-adjusting? I believe someone here said that. Also, I might have read that in the repair manual, but the damn thing is so terse it's hard to tell for sure.
  2. Patrick Wong
    18,210
    6,510
    Classic and 2G valves use buckets of variable thickness to provide the correct valve clearance. You are right that it is not easy to adjust because you have to remove the camshafts and substitute the correct size bucket.
    3G uses hydraulic lash adjusters. My reference is the 2010 New Car Features Manual, 2ZR-FXE Engine Mechanical: Engine Unit: Details (2010 Prius), seventh page of that section.
  3. Mr.Vanvandenburg
    1,353
    572
    2020 Prius Prime
    It isn't overly difficult to check the clearances though. Supposed to do at 60k I think. Not many do this check I would bet. Once checked and a set of values is obtained, it can be decided if the difficult bucket replacement is necessary. From the measurements it should be possible to select a bucket length that falls into the range. IF everything is clean and goes back the same.
    From my limited experiences with Toyota buckets, they stay in adjustment a long long time, pretty much for the life of the engine.
  4. Mendel Leisk
    41,512
    Patrick, do you have a link for:
    Thanks in advance ;)
  5. Patrick Wong
    18,210
    6,510
    I count myself among the few who did that check, on my 2001. Several valves were slightly loose when I did the check at 60K miles. However I decided it wasn't worth the effort to remove the camshafts so I put everything back together.
    techinfo.toyota.com which is the Toyota subscription website in North America.
    In Europe, Toyota Service Information
  6. Mendel Leisk
    41,512
    Yikes, that's what I was thinking. :eek:
    Thanks for the link.
  7. halpos4
    halpos4 "Taxi"!
    377
    25
    Ireland
    Just an update,
    No solution just yet but i had my car in with my local Toyota dealer,
    It was indeed misfiring slightly on No 1 Cylinder,they swapped plugs and coils between 1 + 2,it still misfired on No 1,so they reckon it's down to the injector in No 1,so they're going to take it in and swap injector 1 and 2 around and see if the misfire moves to No 2 cylinder,so we'll see what next Wednesday brings?
  8. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Well, that sounds like fun
    Not
  9. halpos4
    halpos4 "Taxi"!
    377
    25
    Ireland
    The mechanic said it would take about an hour,hopefully it'll yield some results.....and we'll take it from there.
  10. Patrick Wong
    18,210
    6,510
    I'm wondering what is the cost of an injector vs. the labor cost associated with swapping injectors around, and then having to remove the fuel rail yet another time to actually replace the failed part. Depending upon the relative costs involved it may be cheaper just to replace the injector and see what happens.
  11. halpos4
    halpos4 "Taxi"!
    377
    25
    Ireland
    That's true Patrick,
    As i've said in other previous post,i get along well with the lads in the service dept and we discussed that very point but the head mechanic [Paddy] who does most of the work on my car said that if we go ahead and change the injector and the problem persists i'd be down the labour costs [?] and the cost of the injector which will cost me €190 shipped which i'll get from Northern Ireland,Toyota Ireland cost for the injector is....wait for it!....€223 + 13.5% VAT,you guys in the States don't know how lucky you are with regards to the cost of parts,i actually enquired with Carson Toyota about buying all my service parts and they're cheap but when you calculate shipping plus when it gets to Ireland you're hit with Excise Duty and VAT it just spirals.
  12. halpos4
    halpos4 "Taxi"!
    377
    25
    Ireland
    Well the injectors were swapped around and indeed the misfire moved to No 2 cylinder,so new injector and hopefully good for another 345,000km!!
  13. jayman
    13,439
    641
    Winnipeg Manitoba
    Good to hear. Hope this finally solves your problem
  14. halpos4
    halpos4 "Taxi"!
    377
    25
    Ireland
    Thanks jayman.....me too!!
  15. halpos4
    halpos4 "Taxi"!
    377
    25
    Ireland
    Finally,problem solved,new injector,running like new again!!
