Prius Sudden Rev issue
Discussion in 'Gen 2 Prius Technical Discussion' started by Randy B, Feb 6, 2012.
  1. Randy B
    Randy B Member
    104
    30
    NH
    I have a Prius 2005 with an Enginer 4kwh kit installed [v4 bms]. Lately, I have experienced several instances where the Prius suddenly looses much of it's traction power and the engine races, and the red triangle and engine service lights go on at the dashboard. This happens with the kit turned on, and often after a few kit on/off cycles to get more ev mode. The Prius battery is sometimes low, sometimes not, when this happens. Not sure if it also occurs with the kit off.
    The Prius seems to retain some traction power up-down by the throttle pedal, but most power goes missing. On the other hand the engine races and does not seem to power the wheels or vary by throttle. When I pull off the road using brakes normally, and turn off the car/engine and restart [kit now off], the car seems to reset and can resume driving normally, but the error code lights [triangle-engine] lights stay on.
    Anyone have ideas as to cause and remedy?
    Randy B
  2. Randy B
    Randy B Member
    104
    30
    NH
    Further posting, I had the error code read and reset. Code = P0A92. Any ideas?
  3. Patrick Wong
    18,210
    6,515
    Could be the transaxle, inverter, battery current sensor - or some issue with your aftermarket system.
  4. dan2l
    dan2l 2014 Prius v wagon
    653
    263
    Vancouver Wasington
    2014 Prius v wagon
    Hi Randy,
    Your converter is probably set too high. Go to your installer and get it measured and adjusted. This is a known issue with the Enginer PHEV system.
    Thanks,
    Dan
  5. swing
    swing Junior Member
    84
    17
    CT
    Randy - did you ever resolve your loss of power issue? Patrick - where exactly IS the battery current sensor located in a Gen 2?
  6. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Randy has not been here for 2 years and 9 months. I doubt you are going to get an answer
  7. swing
    swing Junior Member
    84
    17
    CT
    scoundrel!!
    bisco and Skibob like this.
