Prius surged forward
Discussion in 'Gen 2 Prius Main Forum' started by yite, Apr 2, 2008.
  1. yite
    yite New Member
    16
    No good reason, really: I was seeing if I could glide to a stop in Neutral, which I could, just two to three feet behind a truck waiting at a red light. Then had to apply the brake to prevent rolling backward. Then put the car in Drive but with my foot still on the brake as the traffic light (which the truck ahead was waiting for) was still red. With my foot FIRMLY on the brake the car shot ahead.
  2. richard schumacher
    7,682
    1,063
    United States
    OK, so maybe you're not a troll. The simple remedy is, leave the car in D. The only occasion for Neutral is when getting pulled through a carwash.
  3. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    Right. It is accelerate-by-wire, because the gas pedal can't be tied to a 'throttle'. The Prius needs to determine the most efficient & effective method to deliver power, whether it's the engine, battery or combination. And when you're in neutral, you can press the gas all the way down and you won't hear the engine race (that would be silly for a hybrid) or have any other indication that the gas pedal is pressed. Also, you can switch from neutral to drive with the pedal pressed (I tried it at lunch today, under mild pedal pressure to be safe).
    So I can definitely see somebody getting surprised when switching from neutral to drive with the pedal unintentionally down, whether by pressing the pedal or a carpet getting tangled up on it.
    As for being in neutral, I do that in the first mile of driving to eke a little better MPG, since my commute is so short. After that it doesn't buy you anything, and I always switch back to drive when slowing down for the two stop signs I have for two reasons: 1) to recapture energy since neutral doesn't have regen braking, 2) so I don't try to start moving from the stop and forgot it it's in neutral - it's embarrassing when I push down on the gas and absolutely nothing happens, but I'm leaning forward in anticipation.
  4. Patrick Wong
    18,210
    6,515
    Actually, the Prius steering wheel is directly connected through the steering shaft to the rack & pinion steering gear. A torque sensor on the steering column determines needed power steering assistance and an electric motor mounted nearby provides this assistance. Hence, if the power steering system fails, it is still possible to steer the car although much more effort will be required.
    The accelerator pedal transmits the driver's request for power to the hybrid vehicle ECU. That ECU decides how much power will be provided by MG2 and how much will be provided by the gasoline engine. It transmits that request to the engine ECU. So the accelerator pedal linkage definitely is "by wire".
  5. ForTheGlory
    ForTheGlory New Member
    296
    Maryland
    Thanks for clearing up my misconceptions. For what happened to the OP to have been "the car's fault", the accelerator pedal position sensor would have needed to malfunction. I imagine that there is some redundancy built into this critical system, though, so I wonder what the chances are of failure. And shouldn't the Prius's "black box" have recorded data for this event?
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    The brake pedal is also "by wire".
    Tom
  7. yite
    yite New Member
    16
    Am hoping that the "black box" will reveal all! It's now bedtime in England for me, but I'll try to get photos posted. (The front crumple is quite dramatic as the top of the bumper slid under the metal crossbar at the back of the truck ahead. If a pedestrian had been walking between us when the car shot forward, their legs could have been sheared off; don't want to imagine what could have happened to a child. I am very grateful that no-one was hurt.)
  8. yite
    yite New Member
    16
  9. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    the prius engine "revs" in park, but not in neutral.
    post pics of damage
  10. statultra
    798
    31
    Edison,NJ
    2001 Prius
    I dont think theres a black box on the classics, cars with the occupant classifcation system, and advanced airbags have a black box which records the speed and weight of driver. or at least this is what i remmeber
  11. sugar land dave
    137
    houston
    I have a brother who used to wreck cars. He always had an excuse for why it was not his fault and was always looking to find allies for his excuses. This sounds very much to me like one of the stories he would tell.
    Until proven otherwise, I am siding with efusco on this one. Driver error.
  12. ForTheGlory
    296
    Maryland
    Ah, forgot that this was a Classic involved.
  13. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Just got back from groceries. So I thought I would try a little stunt in the parking lot, with nobody around, just to see what would happen
    Shift to N, received warning about not charging. Floored gas pedal, kept left foot lightly on brake, shifted to D. Guess what happened?
    Nothing
  14. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    alternatively:
    1. place parking brake (to keep car from rolling forward in neutral) and wait for engine to stop
    2. shift to neutral
    3. stand on gas pedal. no brake. engine did not even turn on.
    4. shift to drive
    5. car tries to shoot forward. parking brake hinders a little bit.
    if you're on the brake firmly, the brakes will hold the car over the engine revving. simple as that.
  15. miscrms
    miscrms Plug Envious Member
    2,079
    527
    Phoenix, AZ
    I think thats the point. It doesn't matter if the throttle control is by wire or not. The brake isn't. If you are standing firmly on the brake, the car can't fly forward faster than you've ever felt it move before. The mechanical brakes are fully engaged. The brake is not by wire, it just has some travel in the top range before the mechanical kicks in. It does have sensors like the steering that allow it to do other things, like activate the electric braking or throw the emergency booster. The ECUs are also smart enough to know that if the brake and accelerator are pressed at the same time, something funny is going on and it should just do nothing. Thats the nice thing about accelerator by wire.
    BTW the sites you linked are well known to be the products of ambulance chasers trying to get a class action suit together and make $$$. Funny that if search the web this problem of unintended acceleration apparently plagues almost every major auto manufacturer :rolleyes:
    If you're a troll, nice try please move on. If this actually happened to you, sorry you crashed your Prius.
    Rob
  16. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    This bears repeating and emphasis. This is exactly what convinces me that while you were stopped you had your foot on the accelerator in Neutral, dropped it into drive and shocker of shockers the car surged forward. It makes far more sense than an 8 year old car suddenly defying physics and its programming and simultaneously having the brakes fail and send a tremendous surge of power to the wheels.
  17. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Pressing the brake + accelerator at the same time while in Drive
    invokes force-charging, aka the only meaningful "engine loading"
    state the car can produce. If you let off the brake during
    that state, you'll get the expected rocketship effect. This is
    talked about in the land speed article and I warn drivers about
    it in my rally hints text.
    Any owner that *hasn't* gone out to an empty parking lot and
    experimented around with these various control quirks should
    do so, ASAP. Especially finding Neutral reliably -- I've seen
    far too many people totally unaware of the half-second delay.
    The more in tune with the car you are, the less likelihood
    that dumb mistakes may occur.
    _H*
  18. tkil
    tkil New Member
    158
  19. yite
    yite New Member
    16
    That's just the way I'd expect it to be!
