Prius Synergy Drive
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by CaliforniaBear, Sep 11, 2017.
  1. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    Am I correct in that the only Toyota hybrid that uses the synergy drive is the Prius? If true (or approximately true), why?
  2. Travis Decker
    Travis Decker Active Member
    139
    116
    Portland OR
    Once they put a boost circuit in the inverter to increase voltage to the electric motors over battery voltage they called it Synergy Drive. It's the same system in Highlander or a Camry or any Toyota hybrid newer than a generation 1 Prius
    Pluggo likes this.
  3. CaliforniaBear
    1,180
    289
    Northern California
    52,484
    however, only the gen 4 prius has the latest hybrid synergy tech. hycam coming out now.
  5. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    It's just marketing spin, all Toyota and Lexus hybrids are "series-parallel" or "power-split" hybrids with some variations. The 3rd gen Prius, Auris Hybrid (hatchback variant of the Corolla sold in some markets) and the Lexus CT200h all use the exact same powertrain, for example.
    Hybrid vehicle drivetrain - Wikipedia
  6. Prodigyplace
    12,696
    11,840
    Central Virginia
    The Prius Prime has the latest one too, along with an additional one-way clutch for MG1.
  7. bisco
    52,484
    also gen 4.
    Prodigyplace likes this.
  8. Prodigyplace
    12,696
    11,840
    Central Virginia
    Technically, it is the Gen 2 Plugin ? Bob calls Prime Gen 4.5
  9. bisco
    52,484
    i guess toyota would determine the technical name. not sure what terminology they use. it is their second plug in, with mostly gen 4 tech.
  10. QuantumFireball
    420
    269
    Ireland
    Toyota's terminology:
    ZVW50 = current Prius (2015-)
    ZVW52 = current Prius PHV/Prime (2016-)
  11. Prodigyplace
    12,696
    11,840
    Central Virginia
    ZVW50 started at 2016 model year.
  12. QuantumFireball
    420
    269
    Ireland
    I'm not American, so I don't do "model years" ;)
  13. Prodigyplace
    12,696
    11,840
    Central Virginia
    Ok, they were not actually available until 2016.
  14. QuantumFireball
    420
    269
    Ireland
    December 2015 in Japan
  15. Prodigyplace
    12,696
    11,840
    Central Virginia
    I missed that Japan got it in December 2015. Thanks for the correction.
  16. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    I believe ford uses Toyota synergy technology in the C-max and fusion hybrids
  17. Prodigyplace
    12,696
    11,840
    Central Virginia
    They only licensed some of the technology IIRC. I believe they licensed Gen 3 I do not know if they licensed any Gen 4 technology.
    I believe Ford uses a different transmission design than Toyota.
  18. QuantumFireball
    420
    269
    Ireland
    The first generation Ford Fusion Hybrid (and a few other Fords, also the Chrysler Pacifica Hybrid) uses power-split transmissions produced by Aisin Seiki - who also make the hybrid transmissions for Toyota. Toyota own 30% of Aisin Seiki, but I doubt Ford actually dealt with Toyota as it's Aisin's technology. Ford supplied the ICE, batteries and everything else outside the transmission.
    More recent Ford hybrids use a transmission designed and built in-house - but a very similar setup with planetary gearset, two motor generators, etc.
    EDIT: It looks like Toyota held some of the patents, so they did apparently do some patent exchange deal when developing the Escape Hybrid.
  19. bisco
    52,484
    i knew toyota would have a way of avoiding the issue.:cool:
