prius to prius plug-in
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Peeto, May 19, 2016.
  1. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Your initial investment may be that much.
    Long term it may be more.
    If possible you may want to order a couple of extra components at the time of the initial purchase, that way you'll be ready when something fails.
  2. Peeto
    Peeto Member
    123
    55
    Slovakia
    Thanks for info. Regarding KIT, they have only 1 on stock and ordering anything else as another parts from supply US is quite though, they react very slowly, communication is very weak. So If you tell me, that I will soon need any other parts as replacement and will need to order it from US, than it really is not worth. It is enough money to be reliable product which will not go broken for few years, that is what I thought :)
    52,831
    there have been a few installs here. some good, some bad, definitely not guaranteed. i don't recall anyone having a completely successful install, and reporting no problems over the long run. but there's a risk to everything i suppose.
  4. Peeto
    Peeto Member
    123
    55
    Slovakia
    Finaly, price for battery needed for 7kW - its 154pcs you need for 19EUR/each = 2926 EUR + some other small stuff for 100 EUR. So total cost of reworking Prius to Prius plug-in 7kW /range 37miles = 47km/ is 6986 EUR + installation preagreeded for 100 EUR = 7086 EUR. What do you think? I think answer is quite clear, not worth at all ;-(
  5. bisco
    52,831
    how does that compare to selling your car and buying a pip?
  6. Peeto
    Peeto Member
    123
    55
    Slovakia
    Realisticly, my car 12k. Used solid PIP 15k EUR. 3k+1k paper and transport cost = 4k EUR difference between my Prius and used PIP 1st gen. With KIT upgrade range is equal to new Prime and not 1st gen PIP.
  7. bisco
    52,831
    that really makes the most sense then. either pip now, or prime later. how many ev miles does the kit promise?
    Peeto likes this.
  8. Peeto
    Peeto Member
    123
    55
    Slovakia
    its 47km/37miles. PIPs with miles around 50k are priced from 17k EUR here...
  9. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    In the USA conversion only makes sense in Colorado due to government incentives ($6000 credit)
    Upgrades | Boulder Hybrids
    Peeto likes this.
  10. Peeto
    Peeto Member
    123
    55
    Slovakia
    So will be watching good offers for PIP and will see. Although good range from KIT, those guys or in case of service needed will be pain. For PIP cons, Toyota will be here for sure and its more safe. But I do not like that PIP does not have reserve tyre in the back :) everything else, I like about them.
  11. bisco
    52,831
    agreed, i keep one above decks. but the kit probably goes where the spare is as well.
  12. Peeto
    Peeto Member
    123
    55
    Slovakia
    that is a good point and + for KIT, it is not where reserve is. So you can fully use your reserve tyre where it is now. Kit is installed above reserve/its that smaller place which is hiden under main back area/even 10kW will fill exactly there/. So you have all your main area fully free for your bags etc.
  13. bisco
    52,831
    that's amazing. how can they fit that much battery, and toyota couldn't fit 4kw?
    how do you get to the reserve tyre under the battery?
  14. Peeto
    Peeto Member
    123
    55
    Slovakia
    so where you have tire in PIP ? Is it in main back area? We have a small children, so I need all the time take pushcair/hope its right english word -where the baby is:)/ and than my back of car is quite full. With another tyre there, I can not imagine it.
  15. Peeto
    Peeto Member
    123
    55
    Slovakia
    It allows access to the spare tire. The spare tire is under the battery pack. Simply unplug the wires and lift the battery modules out of the way. [​IMG]
    bisco and Dylan Doxey like this.
  16. bisco
    52,831
    incredible.
  17. bisco
    52,831
    yes, tyre is on deck in hatch. no good if you're filling with other things. my children are gone.:)
    prime would be even worse for you. maybe 7,000 pounds is sounding more worthwhile?
  18. Peeto
    Peeto Member
    123
    55
    Slovakia
    I am already in love with PIP, so will find solution to spare tire for sure :) This will not stop me :)
  19. wjtracy
    11,374
    3,609
    Northern VA (NoVA)
    Wow there is 3-ft3 space in that Gen3 under-floor space.
    Hard to believe you can get 10 kwhr in 3-ft3, also so light you can lift it.
    Prius hybrid pack about 100-lbs at 1.x kwhr.
    But I assume Toyota design approach is much more robust and heavy duty.
    As far as PiP, you can stand spare tire vertically in rear cubby space under floor (1-ft3) and maybe get stroller in there.
    #39 wjtracy, Jul 17, 2016
    bisco and Peeto like this.
  20. Peeto
    Peeto Member
    123
    55
    Slovakia
    Thanks. Your suggestion are right for 10kW. Only 7kWs and less are not touching spare tire place ;)
    CoolPrius and bisco like this.
