Prius total lifespan in years of Car, not including battery - your experience
Discussion in 'Gen 3 Prius Main Forum' started by Prican, Mar 18, 2024.
  1. Leadfoot J. McCoalroller
    8,088
    7,569
    Pennsylvania
    2018 Prius c
    Don't assume records are complete or accurate. Car maintenance histories are still a long, long way away from good data practices. Don't count on anybody's paperwork to save you from head gaskets. Check coolant levels.
    Partway through 2014 Toyota started using better piston rings. This helped with some of the other problems, but didn't do much for head gaskets. This made the last of the 3rd gen cars somewhat better than the 2010-2014.
    Toyota's European division recently coughed up some technical documentation saying that the variable speed electric coolant pumps should have been running a little faster to prevent head gasket failures. Oops. We haven't seen a hack to increase that pump speed, or more importantly, a timewarp mode to do it on everyone's car 10 years ago when it mattered.
    Although the 1.8L engine is largely the same into the 4th generation, Toyota did make several important changes that bode well for head gasket health.
    A more general comment- Honestly if the car is to be kept in Toronto I'd expect 15 years to be a meaningful lifespan limit on any car given the salty winters there.
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,155
    6,313
    Texas Hill Country
    Only fixed oil burning. 2016 gen4 hatchback is much better with a redesigned engine and hybrid system that was largely used until recently until the gen5s.
    2016 -17 Prius v is still gen3.
  3. Mendel Leisk
    41,463
    Gen 4 fixed the EGR issues. Main Gen 4 mechanical issue was Exhaust Gas Recirculation component (in one unit together with Catalytic Converter) has been prone to leak (engine) coolant.
    Maybe a bad batch; not sure how prevalent. It still can lead to head gasket failure (if coolant runs dry), if neglected too long. There’s a service bulletin (or sim) for it, but dealerships are misdiagnosing, and replacement parts are in short supply.
    again, with cars for resale, probability it’s being ditched is there.
    #23 Mendel Leisk, Mar 21, 2024
  4. ASRDogman
    ASRDogman Senior Member
    7,596
    3,916
    Maybe a corrolla would be better for you. Or a camry.
  5. rjparker
    10,155
    6,313
    Texas Hill Country
    Exhaust Heat Recirculation (Recovery) System to warm up the car faster.
    Gen3 has one as well but some Gen4 versions leak coolant into the exhaust which is sometimes mistaken as a head gasket leak since coolant is not leaking on the ground.
    The repair can be less than ten dollars with a hose bypass.
    Detailed from Gen3
    #25 rjparker, Mar 21, 2024
  6. ASRDogman
    7,596
    3,916
    Bypassing will effect the emissions... which makes it illegal to do that.
    FIXING the problem is the way to do.
    Do it right the first time. Don't "patch" it.
  7. rjparker
    10,155
    6,313
    Texas Hill Country
    The whole purpose of the Exhaust Heat Recirculation System is to warm up the car faster. Maybe one minute to noticeable cabin heat rather than five.
    In that time period the car may run slightly richer and lower fuel efficiency slightly, but it’s an emissions issue in very few locations, primarily California.
    #27 rjparker, Mar 21, 2024
  8. Mendel Leisk
    41,463
    Are you saying some dealerships will do the bypass? I appreciate bypass is the pragmatic fix, but last I heard dealerships won't do it, for aforementioned reasons.
    Toyota's dug themselves a hole, combining the expensive (and defective) exhaust heat recovery system in a single unit with super-pricey catalytic converter. Now who would benefit immensely from "short supply" of replacement components?
  9. ASRDogman
    7,596
    3,916
    Thus post number #26.
  10. Mendel Leisk
    41,463
    I wonder if they could authorize a mod, to add a flanged/bolted connection between the (perfectly good) catalytic converter and the defective Exhaust Recovery System? Doubt it though; not their style.
  11. rjparker
    10,155
    6,313
    Texas Hill Country
    An independent could do it using a clamped coupling or by welding. Cheaper and more effective to bypass it.
  12. Prican
    Prican Junior Member
    42
    toronto
    2019 Prius Prime
    Technology
    Okay. Based on what is been said, There is a lot to think about
    #32 Prican, Mar 21, 2024
  13. ASRDogman
    7,596
    3,916
    There is a warranty recall for that exhaust/coolant leak. So it won't coast anything to fix for
    the car owner. Just time.
  14. Mendel Leisk
    41,463
    But there's the rub, Can be months, a year?
  15. rjparker
    10,155
    6,313
    Texas Hill Country
    Bypass. Ten dollars and an hour diy.
  16. ASRDogman
    7,596
    3,916
    Fix correctly and legally, Free!
  17. Moving Right Along
    Moving Right Along Senior Member
    723
    579
    I’ve put roughly $15,000 into maintenance and repair of my car over the 7+ years I’ve had it. At the time I bought it, it was 7 years old and had less than $3000 in maintenance and repair costs up to that point. So the costs can rise dramatically as the car gets older. I’ve needed to fix or replace tires, TPMS sensors, brakes, the radiator, a control valve, the 12v battery, the multifunction display screen, and the catalytic converter (twice, both times due to theft).
    So currently my 2nd gen Prius is 15 years old, with 182,000 miles, and is still going strong. I can’t predict exactly how long it will last before it’s no longer worth fixing, but I’d be surprised if it doesn’t get beyond 200,000 miles
  18. Mendel Leisk
    41,463
    I saw a second gen roll by (on our morning dog walk); always nice to see, affirming; these cars can give lots of service: if you learn the foibles and stay on top of them.
  19. Prican
    42
    toronto
    2019 Prius Prime
    Technology
    Is it more maintenance than you expected? having maintenance for small items is pretty normal. Did you have to pay for your catalytic converters?, much to the screen cost to fix?
  20. bisco
    51,944
    i wouldn't figure costs due to accident or theft into the equation.
