Prius & towing: Do they mix OK?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Brock, Aug 26, 2012.
  1. Brock
    Brock Junior Member
    40
    Ok, I am sure this has been done to death. My question is Can you SAFELY tow a small trailer behind a prius, like for small motorcycles? By safely I mean not destroy the Prius tranny/engine ect ect...
    What are you thoughts on this ?
  2. Patrick Wong
    18,210
    6,517
    Toyota does not recommend that Prius be used for towing, so keep in mind that you bear the risk of any damage caused by that activity.
    A number of owners have towed lighter items without having their powertrain self-destruct. I suggest you do a search to see what has been done.
  3. Malcolm338
    Malcolm338 Junior Member
    27
    Carlisle uk
    I read some wear on here that some one had been towing a 1 ton mine digger with his and had on problems
  4. R-P
    R-P Active Member
    808
    288
    Netherlands
    I hope that should read "had NO problems" :ROFLMAO:
    It is often mentioned that the electrics are pretty much the same as the Lexus RX400h, which has no such restrictions.
    I just installed my hitch and my father-in-law has a 5000lb trailer... which I am not going to tow :p
    But if I ever install my motorcycle hitch (as in a hitch to tow something behind my motorcycle), I will have no reservations using a ~400lb(max) trailer behind either the motorcycle or the Prius.
  5. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    You are correct.
    Try using the search function: Search Threads and Posts | PriusChat
    Enter "towing" and/or "trailer" as the search keyword, select the appropriate subforum under "Search in Forums" and check the "Display results as threads" box.
    You will find plenty of threads giving examples and advice on this topic.
  6. SynEco@eVehicle.co.nz
    139
    yea.. but the RX400H has upto 200kw POWER available and also a rear wheel electric driver motor for 4 wheel drive ... the RX400h towing limit is lower (1500kg braked)than other SUV towing limits even with all this power ..
  7. Coolride17
    Coolride17 Junior Member
    55
    Would it be any different then a car full of 200lb. adults driving up the mountains in a Prius. That would be harder on the car, because your tongue weight wouldn't be 800lbs. on the springs,it would be on the trailer,and I assume your not going up mountains either. Once in motion, the car shouldn't encounter much resistance at all with a small trailer behind it unless your talking 7ft. high trailer, and the wind resistance.
  8. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    The catch in your statement is the "once in motion". That is not where the problem lies. The problem surely is going to be the added strain on the transaxle, the motor generators and the brake system every time you start and stop. Having the weight on a trailer is different from having the weight on the cars suspension when it comes down to engineering aspects.
    Bottom line: The Prius is not designed for towing. It is in the owner's manual. Of course, there are those who ignore the manual and do tow with the Prius. By doing so, it is understood that it is at each individuals risk. Yes, it can be done and maybe nothing will happen afterwards, then again maybe not. Transaxles are not cheap on the Prius.
