Prius Traction battery repair summery
Discussion in 'Gen 3 Prius Technical Discussion' started by abdelellah, Feb 27, 2018.
  1. abdelellah
    abdelellah Junior Member
    25
    37
    Amman, jordan
    This is a summery for ”Gen II Prius Individual Battery Module Replacement” 106 pages thread (and still growing) posted by “Ryousideways” Apr 24, 2013 which contains a lot of useful information and knowledge shared by skilled people like jdenenberg, Britprius, MTL_hihy, S Keith, Strawbrad, Ericbecky, Kiwi, dolj and others sorry if I didn’t mention.
    It’s only copy past I didn’t bring anything new only sorting the most valuable information that can help start a project after studding the charging characteristic of ni-mh batteries.
    Traction battery pack contains several modules blocks depends on year model.
    Each module block is two modules coupled in series.
    Each module contains six ni-mh cells.
    ---------------------------------------- CAPACITY ------------------------------------------------
    Prius battery module capacity original specification is 6500 mAh.
    It is important to remember that the capacity of a module is that of the weakest or lowest charged of its 6 cells.
    The capacity of your HV battery is then determined by the AH capacity of the weakest module in the pack.
    All of the modules should have well matched capacities.
    Capacity stored in the Prius battery modules within that voltage range 7 down to 6 is minimal. Could be about 0.1 – 0.5Ah in a working packs and can be neglected in bulk tests. I’ve done hundreds of tests (many are published) conducted under electronic load of 6A. Under electronic load current stays constant during discharge. That provides better representation, accuracy and individual test results are hence comparable.
    FYI: In the live test I’ve conducted on brand new pack in Prius and on the very used pack the threshold when the MTG kicks in after discharge was the same – slightly less than 7V.
    Measuring Capacity below 7v is of no use for us (only for demo purposes) as that is the area where Delta V increase and that is the area which is not used by Prius.
    The amount of capacity (or energy) battery provides in between, say 6 & 7 volts (even less in between 6 & 6.5) is a tiny fraction of what it provides in the range of say 7 to 8.5 Volts. Meaning that you do not have to be so much "presize" - around that area and the difference could be neglected.
    Your overall battery capacity will be limited by the lowest capacity module, but your car should work fine. Problems happen when you have a bunch at 4500-5500 and one or two at 500-1500.
    Your Prius will be quite happy with modules at 4 amp hours as long as they are a matched set. You will not see a noticeable decrease in performance until the modules drop to about 2.5 amp hour’s capacity
    ------------------------------------------ LOAD TEST -------------------------------------------------
    Module load testing is more important than capacity.
    Voltage readings without putting the module under load can be misleading.
    Load testing is one of the most critical steps so keep charging current as low as possible (2A max! pref 1A) and discharge as high as possible for best results.
    You really need to do a full top balance of each module before doing this test. This means charging at a very low rate (350 mA) until the voltage stops climbing and then continue the charge for another 4-6 hours (grid charger charging). The is best achieved (time wise) with a grid charger charging all modules at once, but can also be done with at home RC car/drone hobby charger.
    Once you have the battery fully charged, repeat the above discharge under load test. In your spreadsheet, you need to add an additional column that is the difference between start and end voltage. You are looking for modules with a greater difference than its peers.
    1) A 35w load is not nearly enough, minimum of 55w/65w high/low beams on together (120w)
    2) Time for each test must be exactly the same (minimum of 2 minutes each, down to the second)
    3) You need to calculate voltage change, this is what actually tells you if the module can keep up or not.
    4) Charge all the batteries up (RC charger, very low current) and run the test again to get useable results
    Again, you need to then calculate the difference between starting and ending voltages. You are looking for modules with a greater difference than its peers.
    Modules that have a greater difference from its peers in the above tests are candidates for replacement.
    So if you compare the load test results of a nearly full and nearly empty module it's meaningless gibberish. Use your grid charger to get all the modules to 100% SOC. Then run the load test.
    ---------------------------------- SERIES RESISTANCE --------------------------------------
    I would also determine the series resistance of each module by measuring the terminal voltage while doing a 1 amp discharge.
    "stronger cell" will only dissipate excess charge as heat when and only it is overcharged and not with "parallel balancing".
    A good module will have a resistance of 10-15 milliohms and your Prius ECU will report the resistance of 2 modules in series (their resistances add). You can measure module resistance of a charged module by pulling a known current and measuring the voltage drop.
    You can calculate the series resistance (~ 10 to 20 milliohms in a typical module) by dividing the delta voltage by the current.
    High internal resistance and self discharge are the killers
    Measuring internal resistance possibly the best module voltage to do this at is 7.2 volts (the nominal module voltage). The discharge voltage curve at this voltage is almost flat so that any voltage drop from discharge that takes place while taking the readings will be negligible.
    Measuring voltage drop adding a load means the voltage continues to drop steadily.
    Measuring the the voltage rise suffers the reverse effect as the module recovers voltage steadily rising when the load is removed.
    ------------------------------------- SELF DISCHARGE -----------------------------------------
    They should be a bit below 8v after a resting period and then exhibit a very slow self discharge rate for the next few weeks.
    A good module will then exhibit a very slow self discharge rate of under 0.1 volt per month.
    Official Quality Testing Standards I am familiar with suggest leaving the battery for a month before you conduct capacity test (Self - discharge is factored in of course).
    Another test that is useful is ascertaining the self discharge of each module which can be done by measuring the voltage of each module, leaving the battery to sit for 7 days (or longer) and then measuring again the voltage of each module.
    ---------------------------- SINGLE MODULE BALANCING --------------------------------
    code p0a80 is signaled (I think) when the HV battery ECU detects a 1.2V module pair (block) difference.
    Some say that a voltage difference of 0.3V between blocks is enough to set a DTC but I'm pretty sure it's much more than that - closer to 1V.
    The 1.2 volt differential happens when one of the 6 cells in a module is shorted (usually due to being discharged beyond 0 volts). This is a permanent failure of that module. The 0.3 volt module pair (Battery Block) differences can often be corrected by module balancing (getting all 6 cells to the same SOC) and equalization of all modules to the same voltage.
    We are trying to slightly overcharge our modules on each cycle. This allows the cells in each module (there are 6 in series) that have a lower SOC to catch up with those with a higher SOC (which dissipate the excess energy as heat) thereby "balancing" the module.
    To properly balance a module, you would overcharge it. The weaker cells will keep charging, the stronger full cells will give off the extra charge as heat....until all 6 cells are 100% charged.
    Top end balance: Steady, gentle charge (0.05C; ~340 mA) continuing passed the DV point so that the out of balance cell or cells in the module can "catch up". As the full cells will convert this excess charge to heat, you want to use a very gentle charge in this phase to minimise the possibility of damage, as heat is the enemy.
    Bottom end balance: Gentle and controlled deep discharge at a gentle rate (depending on the level of discharge, 1.5 A down to 7.2 V; 500 mA down to 5 V; 200 mA below 5 V) usually done in successive tranches to a lower level each time (1st discharge to 4.8 V; 2nd discharge to 3 V; 3rd discharge to 0.6 V). The reason for this is to recover lost capacity due to crystal deposits/voltage depression which will inevitably happen over time when the battery is shallowed cycled in the 40-80% range (a good thing for longevity).
    ---------------------------------- MODULES BALANCING -------------------------------------
    Good to note this as well, don't put full charged modules back in or you will get an error from the hybrid ECU. You want to aim for around 50-60% charge (between 40-80% is fine, nominal 7.2v = 50%) and balance voltages again before install. So 7.9v is a little on the high side, I would run some better load tests and drop them all back to around 7.2-7.6v, re-pair modules based on better load test results, then re-balance everything again and do your final install.
    If your modules are all at full charge, discharge @1.2A to some arbitrary voltage well above 7.2V. You only need to bleed off a couple hundred mAh. Start with your lowest capacity module and discharge 200mAh and see where that puts you. Discharge all modules to that voltage at the same current. You're not just balancing based on voltage in this case, but to internal resistance as well.
    If they are in the discharged state, charge at max current (6A?) until a given voltage is attained. I would recommend it be some arbitrary voltage achieved AFTER you have put at least 1000mAh into the module.
    You just can’t install a pack that is at fully charged because the computer will throw a code if the voltage it too high. The computer itself runs the battery at a 40 to 80% charge. So at 100% charge, the computer will think something is wrong.
    Discharge to 7.6volts. This way, your somewhere in the 40 to 80% soc. Then do your equalization.
    -------------- MODULE PAIRS MATCHING & PACK REARRANGING ---------------------
    I would match pairs based on effective series resistance, not capacity. When you do the load test you will see a delta voltage drop. Put together pairs so that all module pairs have the same total drop (sum the two module drops). That will minimize the deltaV that the Battery ECU sees under load (after you equalize the modules) and prolong the period without HV battery alarms.
    I also find it very interesting that instead of seeing capacity sag in the middle of your battery pack, it appears to be quite linear across the entire pack. Given this fact I would just reverse the order in the pack (#1 becomes #28, #2 becomes #27, etc) and then load test them all to make sure you don't have any bad ones
    Shuffle the modules when rebuilding center modules to the outside of the pack.
    1.7amp at high SOC is not necessary and simply not a good idea.
    for example 5.5AH "good" module from the fresh wreck into your pack where all otheres are 4AH. What would happen, you wonder? During discharge your weaker but still good 4AH modules will drop in voltage quicker than the donor 5.5Ah one and the voltage difference between pairs will increase above threshold and your Prius will throw a trouble code.
    So called "shellow capacity" range of operation is not shallow enough for that situation not to occur.
    Area below 7 Volts is where the difference in remaining capacity of the individual modules plays the part. That is why when capacity is high enough and pack is operated in the shallow range - things are ok, but when remaining capacity is low due to age and mileage - then high loads force modules to drop voltage below 7V - where their discharge curves are not flat - that if last long enough and repetitive – will trigger DTC (that voltage difference is above the threshold). That is why I emphasize the importance of rebuilding the pack from modules with high enough and equal capacity.
    Example (voltage drops over time on load test):
    0.22v, 0.25v, 0.24v, 0.23v, 0.23v, 0.24v (avg 0.235v) On reassembly I would order them 0.25, 0.22, 0.24, 0.23, 0.23, 0.24 (now you can see each pair/block averages 0.235v)
    Modules with different capacities still work quite well together, as long as their discharge rates are similar.
    The car cannot not see voltages within pairs. It only compares one pair to the all the others.
    Matching all 28 rebalanced modules:
    1. Same capacity - within about 0.2 ah
    2. Same terminal voltage - within 0.05 v by controlled discharge of high modules
    3. Same series resistance - within about 10% (you can pair up modules to control this further as the resistances add)
    4. And all having similar low self discharge rates will result in not having to do the job again for a long time. Self discharge rate - Usually very slow in a good module; about a tenth of a volt per month (after the surface charge dissipates)
    ------------------------- MODULE CHARGING & DELTA PEAK ------------------------------
    If you have 14 chargers it will take only 3 days. If you have 1 charger it will take 42 days.
    I would suggest staying at 2A for charge current (use less if doing this in ambient above 100F).
    Those modules you're tickling just came out of a car getting 80A slammed into them and 120A yanked from them. Furthermore, your < 1C charge rate makes deltaV unreliable, so you need time or capacity provisions for cut-off. Furthermore, you have a much higher chance of overcharging individual cells at the lower rate if the module is significantly imbalanced. What I mean by this is that lets say 5 cells are in sync, but one cell is lagging by 20%. The voltage drop of the 5 cells when they are full will be too low trigger cut-off. This will result in an extended overcharge while the last cell catches up. If you're charging them at 1C, the voltage drop of the 5 will be enough to trip deltaV cut-off and prevent them from being over-charged.
    There are basically 3 charge rates:
    0.1C for 16 hours
    0.3C for 5 hours (or deltaV cut-off, but not 100% reliable)
    1C or higher to deltaV cut-off.
    You are playing in an area of uncertainty with NiMH. I'm not at all saying they won't work, I'm saying they're unnecessarily conservative and pose as much risk as any you might perceive from higher currents. The only low-risk option is the 0.1C charge for 16 hours. With adequate cooling, there is no downside.
    The Reaktor formation charge is also an excellent tool for balancing individual modules. Unfortunately, it takes about 3.5 hours to charge a module; 1 hour at 1C, 2.5 hours at 0.1C as a topping charge.
    On setting a capacity limit you need to look at the discharge figures not the charge side of things.
    There are diminishing benefits after 3 charging cycles so It is not worth further cycling. Batteries have some wear out mechanisms which can limit the number of full cycle cycles each cell can take without significant capacity loss.
    The Prius uses voltage and coulomb counting for state of charge and discharge, but charging from an external source directly to the battery will not be calculated
    The discharge capacity readings are the real capacity of your modules. It is the discharge capacity of the last cycle that is relevant (hopefully the highest one).
    "For the Delta Peak Voltage setting, its probably easier if I give you a basic explanation of what it is. When a NiCd or NiMh battery reaches full charge, the voltage hits a maximum (PEAK) value, and then "changes" (DELTA meaning change) and the voltage starts to drop or reduce as the battery starts to go into overcharge.. So this setting refers to the point at which the Batteries Voltage reaches its PEAK, and then Changes (DELTA) and starts to drop...
    What a "Delta Peak" charger does is monitor the batteries voltage, and when it senses the Change in Peak voltage, the charger turns off with the battery being fully charged.. With your charger, you can adjust the point at which the charger registers the change, so as to remove the possibility of having a pack false peak, and also ensure that the pack is fully charged.. The greater value you set the Delta Peak setting at, the more your charger will overcharge your battery..
    Most NiMh packs don't like to be overcharged at all, so I generally use a setting of between 3 - 6mV per cell (8mV/cellmaximum for my older packs)."
    Charging/Discharging at a high rate in the middle range of SOC is not a big deal.
    It's the ends of the SOC range where the problems arise (NOT TO CHARGE AT A HIGH RATE AT THE ENDS OF SOC.
    --------------------------------- CHARGER SETTING -----------------------------------------
    Mode: Program Save then use Program Load when cycling other modules
    Battery type: NiMH
    Nominal voltage: 7.2V
    Charge current: 2A (lower is better to prevent excessive heat buildup at high SOC)
    Discharge voltage: 6V
    Discharge current: 1A (use highest setting available)
    Charge capacity: 7000 mAh
    DCHG>CHG: 3 (more cycles if modules continue to improve)
    Also go into User Set Program and set:
    NiMH Sensitivity: D. Peak Default
    Capacity Cutoff: on, 7000 mAh
    Safety Time: off, (time doesnt matter)
    Temp Cutoff: 45C (if you are using temp probes)
    Waste Time: 5mins
    Or more aggressive charging:
    Charge at 5 amps up to 7250mAhr
    Discharge at .7 aMhr down to 6 volts
    DSCH<CHG for 3 cycles.
    Other settings: I set the timer limit to 720 minute cut off. I also set the cool down period to 5 minutes.
    Capacity cutoff = on and 7250 mah (set to 4500 on the 4th cycle to be ready for balancing)
    Or:
    Battery type: NiMH
    Charge current: 2A (2A-5A, lower is better for heat buildup in modules)
    Charge capacity: 7250 mAh (range 6500-7500 mAh, higher capacity should use lower charge currents)
    DCHG>CHG: 3 (more cycles if needed)
    Capacity Cutoff: on, 7250 mAh
    Safety Time: off, (time doesn’t matter)
    Waste Time: 5mins
    If required:
    Delta peak voltage set to 20 mV the idea is to stop the peak detection from operating forcing the charger to input the 7250 mah charge before cutting out.
    ------------------------------------------ GENERAL NOTES ---------------------------------------------
    In selecting replacement modules you need to find modules that are of a similar capacity and charge/discharge in a similar way to the ones that are existing.
    The contact between bas bar and the module is not the weakest point.
    Corrosion is travelling up the voltage detective lines and what you perhaps have not seen yet:
    I witnessed 5 cases so far on your model - corrosion is going all the way through to the battery comp and kills it
    You can't see it unless you disconnect the orange plug and scrutinize the contacts on the computer.
    When dismantle the comp - corrosion travels onto PCB and to the componentry. Dead beyond repair.
    To clean bas bars - you may use phosphoric acid (aka anti rust solution) - no mechanical brushing needed and to keep them in storage and not corrode - just dump them in the motor oil.
    If applying the grease - be careful for the grease to be heat resistant and dielectric.
    Double checked the "stall test" guidelines - there is a set of thresholds mentioned in relation to particular DTC:
    1.2V max for VMAX-VMIN
    0.3V max for swith-over between CHRG/DSCH
    2V max for the "swing"
    --------------------------------------- HOW TO START -----------------------------------------
    Take the battery out, let it sit 7 days. The bad ones will lose its voltage. Replace with KNOWN good modules and charge/balance the battery
    Or
    Label your battery modules with a permanent marker. 1 through 28.
    The modules are counted from the terminal (high voltage ECU) end of the battery. The module nearest the ECU being (1) the furthest away being (28).
    on the Gen II, it is the opposite. Module 1 is at the opposite end from the ECU counting back towards the ECU, making the module closest to the ECU module 28.
    Toyota Tech Stream Software and any generic OBDII reader will start the count on the PASSENGER side. That is to say pair one is opposite the battery computer and pair 14 is next to the battery computer. This applies to Gen II Prius years 2004-2009. For Gen I (2001-2003) the count is in the opposite direction with pair one being next to the computer and pair 19 being on the far passenger side. I have not yet opened up a Gen III battery and do not know the direction of the count.
    NHW-10 (JDM 1997-2000) Count from ECU
    NHW-11 (aka GEN-I in USA only) (2001-2003) Count from ECU
    NHW-20 (aka GEN-II in USA only) (2004 - 2009/2010JDM) Count towards ECU from another end.
    It is better to start the load test with all modules at the same voltage for comparison.
    You use the voltmeter to test the voltage of each individual cell. Record your results on a sheet of paper or excel spread sheet.
    IMPORTANT NOTE: Leave battery modules compressed in the case when charging. Otherwise they will swell.
    You may find, or will find sometimes the modules all tests perfectly, and even when you put a load on them with a light and test the voltage they still seem fine? How is this? I don't know, but in order to find out the real culprit you have to pull the battery out and disconnect/test it right after it has been used in the prius. So you want to either drive the car for a while and immediately pull out the interior and the battery, or if you already have the interior out, run the prius for about 30 to 45 minutes to get a load on and off the battery. If you let it set over night I think the bad modules tend to try to rebalance themselves with the pack, which makes them hard to find with the voltmeter. If you run the car, stress the battery, and immediately after test the pack, it will be easier for you to diagnose. At the minimum get the pack out of the car and remove the bus bars, even then, these batteries tend to want to equalize on their own, so I would just test as soon as possible after running the car. This allowed me to find a bad module I couldn't find before.
    What I did was to cycle each module 3 times D>C at 7000 mAh (first discharge tells you the state of the module coming out of the car, the second and third tells you what the total capacity is at high SOC and helps to exercise the cells back into shape). Then once that was done I would do a final D>C cycle at 4500 mAh, but make sure you discharge the cells initially so there is less than 4500 mAh when the cycle starts (usually I just discharge the cells below 4000 mAh then start the cycle again). If you don't discharge it below 4500 mAh remaining the charger will complete the cycle, but the voltages will be off considerably since the battery wasn't pulled down to the 6V minimum before the charge cycle starts. If you follow this method it makes sure they all have similar starting voltages before final balancing.
    Traction battery Disassembly:
    Remove bus bars
    Disconnect inlet air temp sensor from far end of pack.
    Remove ECU bay (3 nuts and a few connectors)
    Remove two nuts holding plastic clamps to base.
    Stand pack on non-ECU end facing the bottom.
    Remove all mounting screws from bottom of case
    Remove bottom of case
    Note installation and remove temp sensor harness.
    Now you have all your modules clamped between the two plastic ends.
    Flip clamped modules to other end (now sitting on ECU end)
    Remove 4 bolts securing top clamp
    Remove/rearrange/replace modules as you see fit.
    Traction battery Assembly:
    Reverse of above EXCEPT
    After you start and snug the clamping bolts, you need to lay the pack flat and ensure it does not rock when you put the final torque on the bolts. If you do it in the vertical position, the pack will twist.
    When attaching the case bottom to the clamped pack with screws, don't just start at one end, start the extremes and work inwards in a random fashion. The idea is to get all of them started before screwing any of them down.
    Then I found these threads that proved to be helpful as well:
    Prius Battery rebalance thread | PriusChat
    HV battery issues | PriusChat
    Traction battery rebuild question | Page 6 | PriusChat
  2. Old Wrench It
    Old Wrench It Member
    58
    51
    Very well put together! Thank you for putting the answers to multiple questions in one place!
    Jim Swart, C Wagner and abdelellah like this.
  3. Bill Byrd
    Bill Byrd Junior Member
    Yachats Oregon 97498
    I've been a lurker and sucking all the knowledge from all of you knowledgeable people for weeks now, and I'd just like thank everyone for all of their expertise in making this what would seem like a daunting undertaking very doable. I now have a car without and Triangle of Death, nor codes of any sort. The one mistake I made blew up the first charger, by starting a discharge on the wrong type of battery. The second mistake I made was not pushing down the orange service plug handle which results in the Prius not going into drive or reverse and the motor not starting. But other than that it went quite smoothly. I would also like to recommend a video that was actually a pivotal factor and gave me the confidence to undertake a project of this magnitude. The video is by Igor Kadulenkov on Youtube. He takes you through all the steps from removal, rebalancing to replacement. Thanks again to all of you and I just wish there was a way to give back some of what I have gained.
  4. Tfrantastic
    Tfrantastic New Member
    Very awesome!
    Jim Swart and C Wagner like this.
  5. Grit
    Grit Senior Member
    6,456
    4,189
    Wilkes Land
    Thought summaries were brief and short. Imagine the full explanation of this entire battery replacement documentary.
    C Wagner likes this.
  6. C Wagner
    C Wagner Member
    183
    58
    Boston
    Thanks for this. Mentioning this, and my own experiences, I started a Wiki page, as I felt it's needed for Priuses with failed/weak HV batteries. Folks can find the new Wiki here Prius High Voltage Battery Reconditioning | PriusChat (or above under the subcategory of DIY Maintenance). Together we should be able to make a great document to help folks out, such as the OP has done here with the excellent summary of PC discussions...
  7. PriusII&C
    PriusII&C Active Member
    374
    131
    San Jose, California
    Great document.
    Internal resistance seems to be a crucial parameter. To measure it down to m-Ohms, voltage reading needs to have a mV resolution (assuming load current is in single A). What kind of multimeter do you use?
    #7 PriusII&C, Jan 16, 2021
  8. C Wagner
    C Wagner Member
    183
    58
    Boston
    Edit/Update: I paid for the hopefully excellent Dr Prius app and tested my car's battery using the fiendishly fun "Battery Life Expectancy Test" where you get to floor the gas and brake at the same time and then freeze your tush for 1100 seconds while you draw 6 amps. Anyway, despite my iffy internal resistance understanding and iffy pairing of modules,
    the completed battery, reinstalled and driven a week before tested, came out at 102% of new capacity! I don't entirely believe that, but since I think it's quite likely that we get 90-70% numbers after we rebuild the 28 module packs carefully, this pleased me more than 50-10%
    ASRDogman likes this.
  9. C Wagner
    C Wagner Member
    183
    58
    Boston
    I'm just adding the text of a review I left for a 4 port charger called Turnigy Quad 4x6s I bought at Hobbyking -- for folks wondering how they're going to start/do the charge/discharge/cycle process. The charger I used was the cheapest I could find that: was 4 port, that seemed to do multiple cycles and seemed to actually work right, unlike the two Imax B6 chargers I first bought! Note at the bottom how it could be better -- and what to look for in other multiport chargers. If you find a better one, please post...
    Turnigy Quad 4x6S Lithium Polymer Charger 400W DC Only | HobbyKing
    Review for Hybrid Battery Repairers... It's good enough!
    As mentioned in the title, this is a review focused on using this 4 port hobby charger for repairing hybrid batteries. Specifically, I sought out the cheapest, multiport charder/discharger/cycler available.
    This one works OK and it may be your best, cheapest choice, so I recommend it. There are some caveats though:
    Like many hobby chargers, it doesn't come with an AC adapter. Most hybrid battery rebuilders will need one. You could run the thing off a car battery, but you'll still need to make the connection (T60, not supplied) to the charger to power it. So, you'll need to buy (or make) a 12v AC/DC power supply capable of 10A or more.
    The unit is just like having 4 separate Imax/Dentrum/LiIonNimh hobby chargers that are floating around everywhere now. The interface is no better or worse than those - if you've never used a modern hobby charger, it may take some time to get used to the odd menu structures.
    There are current restrictions. The unit seems to not be able to charge at collective rate more than 10A. This is plenty for Prius/HV Hybrid battery charging. The real issue is that DSC Discharge is limited to about 1A, which is terribly slow! At first I used a separate 1 Ohm resistor to discharge the battery modules, but this is just too labor intensive. The unit (and all good hobby charger) does have a multi cycle (set it/forget it) mode, so even though DSC takes FOREVER, you can just set it to cycle DSC/CHG 3 or so times and it will finish in a day or so per module, depending on your CHG current.
    I don't recall it coming with enough charging leads, so I made my own + and - leads. This isn't a big deal. Use good wire, like speaker wire, or what you have, crimping or soldering to standard banana plugs and small-med alligator clips.
    I was using this for NiMH Toyota Prius battery modules. I never quite understood the Peak Charging option, so set it very low. From a different Turnigy manual, I understood that Peak charging pushes the cells a bit higher than 'done' to improve life. I'm not clear on if that works when you are using a set mA charge like 7250mA, which I suggest you use for prius batteries, with Safety timer OFF and such a low charge (2-2.5A) that it's unlikely DeltaCharging will be properly triggered. Thus, I set the Peak Charging setting to very very low. The charger still seemed to sometimes push the modules high.
    Other tips (freebies to help you use this charger better with hybrid batteries): You need adequate module cooling and the modules need to be in their vice-like container. I suggest a Wifi Camera like Wyze to monitor the process. The $20 Wyze camera alerts you when the cycle beeps, at end too! For the 12v power supply, you can buy a 10A unit from Ebay or your country's version of that - make sure to also buy a T60 adapter (not sure whether you need male or femaie, buy both!). Instead, I bought an old design Xbox 360 adapter, capable of 16A. You could also convert an older large PC powersupply, using just the 12v leads, combined and connected properly to the t60 adapter. There are other steps to insure a good battery rebuild, see priuschat's Wiki on HV battery repair. I don't mention them all here, since they are not relevant to this unit. Which is Good Enough. 3 Stars for this purpose.
    Turnigy: Fix the current DSC limit so you can draw the specified 3A on each port simultaneously, and supply a US or "world" voltage adapter, and you have an AWESOME 5 star product, concerning hybrid battery repair.
    EDIT: An additional thing I forgot to put in my review: It's not mentioned how to calibrate this unit. When you use this unit, verify what it says the voltages are against your trusty multimeter's readings. Mine was .2v off. This meant that my DSCs to 6v were actually going to about 5.8/5.9v Something to think about, you want to calibrate the unit before using it, if anyone offers the trick to calibrate it/them!
    #9 C Wagner, Jan 22, 2021
    GaryInSanDiego likes this.
  10. PriusII&C
    374
    131
    @abdelellah Great summary. I wonder if you could clarify the discharging voltage setting? It is 0.6V for bottom end balance, but becomes 6V under charger setting. Thanks.
    #10 PriusII&C, Feb 25, 2021
  11. Hiroshi
    Hiroshi New Member
    Brasil
    hello, i have a toyota prius 3 generation and i need to repair and balance the modules, could someone tell me what is the correct configuration to balance the modules of the 3rd generation or will it be the same as the 2nd generation? I saw in other posts that these two generations are different and have different strengths.
    I am using an imax B6AC charger with the following characteristics:
    Settings:
    Discharge at 0.7 aMhr down to 6 volts
    Other settings: I set the timer limit to 720 minute cut off. I also set the cool down period to 5 minutes and D peak for default.
    I would like to know if everything is correct or if I need to correct something. please help me.
  12. C Wagner
    C Wagner Member
    183
    58
    Boston
    Take a look at my experience from the wiki I wrote / it should be below this message on the signature. Mine is a Gen2…
  13. C Wagner
    C Wagner Member
    183
    58
    Boston
    I just saw this, following up on someone else's comment. My multimeters are digital, pretty cheapish - usually a combination of those free/$3 Harbor Freight red ones, or my old digital radioshack or a similar-to-radioshack unit. What would the process for measuring internal resistance most simply/accurately be and how would we integrate it into the rebuild/rebalance process?
  14. waldox
    waldox Junior Member
    69
    toronto
    reblancing my pack, i find the internal resistance more important than mah capacity, lower ir is better.
    stick to modules under 20 miliohms. order your good modules by ir then suborder by mah. try to pair the lowest ir with the highest ir. then if there are similar ir pairs, match the lower mah with the higher mah.
    you want to measure ir of the modules from 7-7.8volts at rest, so you know how they stack up in discharged state.
    i measured ir with balance charger, some balance chargers do measure it. you can measure with an higher end multimeter, low end ones dont let you measure ir
  15. C Wagner
    C Wagner Member
    183
    58
    Boston
    How did/will you test your completed pack? I used the paid Dr Prius app and got a pretty good %age. 6 months later it was still good. I should test the pack again now, 12 months after the rebuild. As I noted, I wasn't really sure how to test IR or to pair IR, but I did follow your worst module mated with best module approach to hope to produce a pair that would be average.
  16. jvasquez
    jvasquez New Member
    Indiana
    Hey everyone! I hope to get a response soon.
    Ok, I have a few Tenergy T180 chargers going through the process for a friend. He bought a 2007 Prius, so the battery is a gen 2. This is new to me, but I like this kind of stuff.
    set up:
    Tenergy T180
    7250 mah cutoff
    Charge was 7A, but after reading this it seems 2.5-5 is the magic number
    Discharge at 5A (more like 4ish since it's usually around 15W...not sure of the conversion off the top of my head)
    Delta- For the cycle program, it's automatically set at 5mV. If I do each charge/discharge, I should have control to change this.
    Wait time is 10min
    Right now, going through the moduels, I have 1 and 3 showing about 5100, however I have a few that, after 5 cycles, some 8, they hover between 4500-4900...mostly closer to 4600. I'm wondering if this is due to any setting because when I charge, it's only hitting 5200ish max and I see you all hitting 7200 or close. Are these modules ok to use as long as they are close to each other? I read above that above 4000 is still ok.
  17. Javier Ruiz
    Javier Ruiz New Member
    Barcelona (Spain)
    Hello.
    I am here because I tried with setting I saw in other youtube tutoriaLs and they set 5 AMP AUTO. With these settings on my first module with all the package dissassembled because I though it would be better for heat dissipation, I tried the first 3 cycles and I get my module a little bit inflated. I see some people holding the module squeesed between to pieces of wood... If i squweeze it now it returns to its original size... Do i have to throw it?...
    The next ones I will triy with the battery assembled again to avoid inflation.
    I set charge in auto 5.0 Amp like in the video and i observed 5 amps while charging, I expected 1 or 2 amp adjusting automatically but was 5 amp all the time... This is because of a defective module or what? Now I see I should I limit it to 2 amp charge. Thanks in advantadge
  18. C Wagner
    C Wagner Member
    183
    58
    Boston
    I think I charged lower (like 2.5 amps) and discharge was the big problem. Most of those fakes of copies of hobby chargers can't discharge more than 1amp. I sometimes used a 100w car window defroster to get more like 10a discharge, but then I had to watch the voltage of the module with a voltmeter to make sure I stopped discharging at the right minimum. If you have the time, you might just use those crummy 1A controlled discharges. I'd only do this process with the modules in their rails (the original battery case) and even then I'd be sure to only work on modules not too close to each other - and blow cool air on the battery - you can remove the car's HV battery fan and rig it up with the black ducting to shoot air over the modules. I'd also suggest you put small waterballoon-type balloons over the vents on the modules. You don't want those caustic gasses in your work area - and it will tell you when you're stressing the module too much...
  19. prius05thebest
    prius05thebest New Member
    Greenbank, WA
    I just want to say thank you to this group for all the great info in this forum. I was able to refurbish my 2005 battery after the triangle of death came on with the p0420 code. One thing I would like to mention is the ToolkitRC M6D hobby charger. It's 2 channels for $75 on amazon or $46 on aliexpress (if you can wait 2 weeks). I haven't heard anyone talk about this charger, but it has "recycle" mode which discharges the Prius modules back into the 12V battery you are using to power it, so it can both charge and discharge at 5A. Because of this, a full Discharge->Charge cycle runs in about 3 hours instead of the 6 hours it takes with the BGUAD CQ3 quad hobby charger that I was also using. Keep in mind that some of ToolkitRC's other models don't have NiMH cycle feature (you have to dig through the manual online to check and also the AC powered ones don't have recycle mode which allows for the fast discharge rates but the M6D has both these features and is the best value.
    If I were to start over I would order from AliExpress: 3 M6D's, 6 sets of XT60 to alligator clips ($1.35/ea) to connect to the Prius modules, 3 sets of XT60 to ring terminals($2.61/ea) to connect the M6D to the 12V battery. That's about $155 for 6 channels of fast charge and discharge.
  20. prius05thebest
    Greenbank, WA
    Oops actually it was code P0A80: Hybrid Battery Pack Deterioration and also P3016 High Voltage Battery Module 6 Fault that I had. The P0420 code was for my catalytic converter, unrelated to the battery.
