Prius Trivia
Discussion in 'Gen 2 Prius Main Forum' started by roger, Dec 14, 2004.
  1. Graz
    Graz Member
    179
    28
    HUD???
    Why does t he speedometer display have to be reflected at all? Seems to me that it would serve the same purpose if it was a direct view instead of a mirror image. And since they insist on reflect it, Why didn’t they make it a true heads up display (HUD) and have it reflect off of the inside of the windshield?
  2. arubinst
    arubinst Junior Member
    Lausanne
    Re: HUD???
    <div class='quotetop'>QUOTE(Graz\";p=\"70767)</div>
    Ok, how about this for an explanation:
    The speedometer and the other instruments displayed on the dash are just plain lights that do not need to have “high resolution†but are sure useful if they are big and bright enough so that every one who drives the car can see them. So, it is a lot cheaper to produce a reduced scale model of the whole set of lights and then just use magnification to show them the way you see them on the dash (you can actually see the image is magnified). The reason for using reflection would be in this case that, if you want to build the speedometer and all other lights very small so they’re cheap and you want to display them satisfactorily big, you would need a very long distance back from the panel to the magnifying glass; they would need to be placed too far behind the dash. That or you would probably need a very powerful magnifying glass that could distort the image and result in additional costs.
    Now, you can magnify using mirrors!!! Or you can place the original instrument panel and speedometer deep down into the dash and use a not so expensive and not so powerful magnifying glass, because distance will increase magnification.
    <div class='quotetop'>QUOTE(Tideland Prius\";p=\"70733)</div>
    You don't necessarily have to use two mirrors to obtain a straight image to show. You just arrange the lights in such way that they are a mirror image of the whole panel so once reflected, they become straight.
    Does this sound reasonable to anyone?
  3. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    You asked for it, you got it, Toyota!
  4. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(V8Cobrakid\";p=\"70727)</div>
    Are you looking for this?
    It is designed so that a driver can focus on it easily from the road surface,
    Tech Manual says.
    Regards,
    Ken@Japan
  5. rocco
    rocco Member
    146
    FL
    So . . I have a "spot" somewhere from perhaps washing my windshield (it dripped) - where the heck or how the heck can I wipe it? (like the guy with the bug) where was his bug?
  6. rocco
    rocco Member
    146
    FL
    I have a trivia: Of course if you push the power window button down (on the driver side only) it goes down automatically but did you know that if you lift it up it rolls UP automatically too?
    I didn't know this until accidently yesterday
  7. DanMan32
    3,799
    27
    Tampa Bay, FL
    <div class='quotetop'>QUOTE(rocco\";p=\"70877)</div>
    Put your finger in the well below where you see the display. You will see your finger IN the display. Think of it as a projector in the dash projecting onto the panel where the directional indicators are. If cleaning the window covering the projector housing doesn't work, then the combination meter assy mirror will have to be cleaned.
    <div class='quotetop'>QUOTE(rocco\";p=\"70879)</div>
    Yup, that's why it has a safety to automatically lower the window if it gets jammed.
  8. karmavore
    karmavore New Member
    65
    Madison, WI
    This was pointed out to me by someone with eyes not quite as young as mine:
    The farther away the actual spedometer is from the driver's eyes, either straight line or reflected distance, the easier it is to change ocular focus from the road to the spedometer and back. Any extra "virtual" distance placed between the driver and the spedometer is an additional ergonomic plus.
    Brad
  9. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    interesting point and something i had not thought of either. i just assumed that the overlarge number display was the reason why it was so easy to read the indicator.
  10. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    :idea: TRIVIA - Great Forum Subject...!!!
    Have you noticed? - Your rearview mirror is mounded on the windshield with a BALL JOINT at the windshield mount. This allows you to swing the mirror arm side to side, up and down to adjust for your height and tailor the mirror view to your individual taste. At my height (5'11") I have swung the arm as far down as I can which provides a better view out the back window.
  11. dgstan
    dgstan Member
    159
    OC
    Here's One*
    The knobs for the audio volume and tuning can be pushed in to be flush with the rest of the dash? I just noticed that this morning.
    DGStan
    * May only apply if you are as clueless as me.
  12. karmavore
    65
    Madison, WI
    <div class='quotetop'>QUOTE(V8Cobrakid\";p=\"70738)</div>
    If you were to place two mirrors at the appropriate locations with the appropriate angles, you could get a clear-shot view into the unit itself! That would be much easier than using a fiber-optic camera. :D
    Sorry, felt the need to be a smart-***. :D
    Brad
  13. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    lol :lolup: :ahole:
    lol. ill look. i guess my real interest is to take it apart and study it. i have the feeling with the whole car. I just want to take the whole car apart and study it... but.. i won't.
  14. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    actually, i do know the feeling of fending off my car-crazy friends who all wanted to take the cover off the EV amongst other things just to see what it looked like....
    sorry but until it breaks, aint nothing being disassembled on my baby...
  15. Stocky
    Stocky New Member
    84
    Christchurch, New Zealand
    SAME!!!!!!!
  16. timmsumm
    timmsumm New Member
    Seattle, WA
    Trivia: the steering wheel is somewhat oval instead of circular.
  17. Tideland Prius
    16,631
    If you 'remove' the rim, it looks like a Sega Game Gear lol
  18. V8Cobrakid
    3,790
    152
    rim? *lost*
  19. Tideland Prius
    16,631
    well the part of the steering wheel that you hold
  20. V8Cobrakid
    3,790
    152
    ah.. never took it apart.. i have to resist.. or else i might take the whole car apart.. people would come out in the morning.. and i would be sitting there with this huge pile of parts next to me.. a big grin.. and a hybrid battery in my hands.... " i hold the power "... it would be bad..
    same effect if i were given " the One Ring"... i would abuse it.. go invisible.. so on.. so on.
