Prius troubleshooting help P0606
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by RMB0001, Jun 16, 2023.
Tags:
  1. RMB0001
    RMB0001 New Member
    Hello I know the code is saying that the ECU lost connect and I have been checking wires but can't get anything from it. This code came up a month ago and drove it around for about 1k miles and the code came up and erased it again. And now it's been about 450 miles and came up again any suggestions.
    If it's wires then let me know which wires to check. And if ECU then I'm a bit scared of it.
  2. ChapmanF
    18,626
    I don't think there are many wires to check. According to the repair manual, P0606 comes from an ECM internal self test, and pretty much means the ECM is broken.
    Toyota Service Information and Where To Find It | PriusChat
    It does have you check for other trouble codes first. That is, if you have any other codes besides P0604, P0606, P0607, or P0657 (the ECM internal fault codes), they would have you go resolve whatever other codes you have, first, and then see what happens.
    But if you only have code(s) from among those four internal ECM ones, they say replace the ECM. That doesn't have to be scary, you just get one that isn't broken, and unplug the broken one, and plug in the non-broken one.
  3. RMB0001
    RMB0001 New Member
    I do not have any other codes, P0606 is the only code and gives me a check engine light. If I did just get an ECU from the junk yard and replaced it, I would have to reprogram the new ECU, right?
  4. dolj
    dolj Senior Member
    8,585
    4,360
    Wellington, New Zealand
    For the engine control module (ECM), I believe there is no programming required. The repair manual indicates you simply remove the old one and install the replacement.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,098
    2,001
    NJ-USA
    A Gen2 ECM is plug & play- no programming or relearning. You can carefully flip the ECM connectors around to test the "new" ECM before removing the old one.
    Might want to clean the throttle body bore as well. You'll erase the throttle "learned adaptation" which can cause a problem when starting the ICE.
  6. RMB0001
    RMB0001 New Member
    Sweet thank you guys I'll keep you all updated and thanks again for the info
