Prius Tuning - More HP (200-300 whp)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by andreimontreal, Jul 3, 2021.
  1. SnowMexicanuck
    56
    66
    Quebec, Canada
    I was talking about my '05 MINI Cooper S... it's a 1.6L s/c.
    Reading is hard I guess.
  2. black_jmyntrn
    black_jmyntrn Senior Member
    1,728
    407
    2013 Prius Plug-in
    Call me crazy, but the thought of swapping the A25A-FXS in my Gen 3 with one of those L-ion lightweight batteries as an upgrade to my plugin battery with a 100-mile range and still plugin superpowers... some dreams come to reality ya know!
  3. andreimontreal
    andreimontreal Active Member
    380
    117
    37
    Montreal
    Say what?
    I just had a thought: not sure if it fits in the prius engine bay, but for sure taking a hybrid engine system of a Highlander and adapting it to a Prius should be more straightforward than swapping or turboing. And that's about 240 hp - still a 4i.
    EDIT: forgot to say earlier: that Prius racing concept, iirc, has nothing stock on it - it's the Prius idea with oversized everything for powah'. Edit 2: it's a 3.4L v8 ; outrageous :whistle:
    #23 andreimontreal, Jul 5, 2021
  4. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,688
    Somewhere in Wisconsin
    2013 Chevy Volt
  5. bisco
    51,961
    link please :p
  6. andreimontreal
    380
    117
    37
    Montreal
  7. bisco
    51,961
    andreimontreal likes this.
  8. Rmay635703
    2,669
    1,688
    2013 Chevy Volt
  9. andreimontreal
    380
    117
    37
    Montreal
    Chill fam (y)I double posted God knows how and edited to "..."; it meant nothing.
    Here's an engine swap rant - just because.
    Samuel Williams Jr and bisco like this.
  10. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Decades ago some Australian swapped both a supercharger and then a turbocharger into their gen 0 Prius. He found that the battery charged much more frequently with more power. It ran out of battery much less frequently, so power delivery was more reliable.
    He had to do all the fabrication him self, using parts intended for kei cars, 360cc japanese domestic engines. There is almost no extra room under the Prius hood, so he removed parts of the frame, not very safe. He found the super charger so loud that he could not get passengers to ride in the car. The turbo plumbing was so bad that lag was significant.
    The Bonneville world speed record gen 2 Prius used an engine swap to an Otto cycle Toyota Echo engine, for a 20% HP gain, not near the 200% gain you want.
    Samuel Williams Jr likes this.
  11. ASRDogman
    ASRDogman Senior Member
    7,599
    3,915
    Once you swap the engine to a none Prius engine, it's not a Prius anymore...
  12. bisco
    51,961
    what constitutes a prius?
  13. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    so what should it be then?
  14. SnowMexicanuck
    56
    66
    Quebec, Canada
    Apparently, if you put an LS in a Belair, it is no longer a Belair, it's a Chevrolet Silverado.
    Grit likes this.
  15. Rmay635703
    2,669
    1,688
    2013 Chevy Volt
    Priuck
    andreimontreal, TGrracie and Grit like this.
  16. Samuel Williams Jr
    246
    Dayton NV
    It's a "Frankenstein"," or a "Sleeper," something that " look's like something, it is not? .
    Lot's of them out of there, and the best of the best look and sound "Stock?" The SRT 8 Prius, is not gonna fool anyone with those rear tires?
    It is an "awesome," car but it's not going to "Fool," anyone. And the whole point of "Sleeper Cars," is to "look" like something they are not? :)
    #36 Samuel Williams Jr, Jul 6, 2021
  17. Vman455
    Vman455 Senior Member
    539
    556
    The Middle
    That was Julian Edgar (editor of Autospeed); he drives a turbocharged 1st-gen Honda Insight now with significant--tested--aerodynamic modifications. I can't find part 1 on the site (I get a broken link), but here are part 2, part 3, part 4, and part 5.
  18. rjparker
    rjparker Tu Humilde Sirviente
    10,160
    6,316
    Texas Hill Country
    The thing most people don't appreciate is the software magic synchronizing engine power and rpm with the electric motors in the transaxle. This synchronized dance has to be perfect when power splitting for maximum power. So you would have to add engine torque without increasing rpm since one of Toyota's hybrid techniques is to preset engine rpm at one of several spots, allowing the electric motors to change rpm and torque to achieve more power, speed or torque at the wheels.
    One might lighten the load but the car is stripped down already with little or no interior insulation or other low hanging fruit to remove. Toyota implemented a lower final gear ratio in the v wagon which "might" be useful for slightly improved acceleration.
    The easiest improvement could be a lithium hv battery retrofit depending how the third party emulates the factory pack's full charge voltage. In some cases the existing pack will go to a higher voltage than normal and you get a noticeable power boost as the hybrid system attempts to burn it off. High voltage combined with an acceptable battery temperature gets you a boost, short lived with a standard battery but perhaps possible for a longer duration with a replacement.
    However, the best Toyota hybrid for power is the Rav4 Prime. 300 hp using battery and engine, around 100 mpg equiv on battery alone and almost 40 mpg in standard hybrid mode. This amazingly fast hybrid is now becoming available in the Lexus NX450h and will obviously become an option on many Toyota models. So do you chase performance in an old gen3 by spending thousands in a questionable quest or do you sign up for today's technology with a fully engineered solution and warranty?
    #38 rjparker, Jul 10, 2021
  19. ASRDogman
    7,599
    3,915
    If they battery pack is a higher voltage or more amperage, wouldn't it take more engine power to turn
    the generator for a longer time to charge it? Thus negating the extra power?
    Grit likes this.
  20. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    great point.
    or use more gas to charge it because the battery capacity is larger than stock battery pack? Like the theory that lithium pack higher Ah vs nimh lower Ah yields better mpg on the gen 3?
    ASRDogman likes this.
