Prius turn on and off repeatedly!!!
Discussion in 'Gen 2 Prius Technical Discussion' started by JSH, Jul 12, 2009.
  1. richard schumacher
    7,664
    1,044
    United States
    JSH, did you find any loose or corroded connections on the old battery when replacing it?
  2. JSH
    JSH Senior Member
    2,605
    140
    PDX
    Richard,
    No, everything looked as clean as the day the car was assembled. All the bolts were tight.
    Jayman,
    I didn't grease the threads on the ground or battery terminals. That is something I normally do but considering this battery is inside and out of the weather I didn't bother.
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Ok. How is the car behaving now? Did you have a chance to test the old battery, or is it now pretty obvious the old battery really was kaput?
  4. JSH
    JSH Senior Member
    2,605
    140
    PDX
    The car is acting completely normal now. Voltage as measured with the MFD is good. I am convinced that the old battery is bad because it can't crank a 250cc motorcycle fresh off the charger.
    Thanks for the help everyone.
  5. jayman
    13,439
    641
    Winnipeg Manitoba
    If you're happy, I'm happy
  6. richard schumacher
    7,664
    1,044
    United States
