Prius Two - Add EV Mode button?
Discussion in 'Gen 3 Prius Technical Discussion' started by PriusTime, Feb 24, 2013.
  1. PriusTime
    PriusTime Junior Member
    55
    25
    Can an EV Mode button be easily added to a Prius One? If so - where do the wires connect to?
  2. BZzap!
    BZzap! Senior Member
    1,607
    878
    Maybe I'm' misunderstanding your question but there is an EV button. It's on the console next to the ECO and POWER mode buttons. At least that's the case on my 2012.
  3. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    If you mean a gen II prius (which would mean that this is in the wrong forum), Yes, you can add a button. Do a search on the forum to find more information than you could want.
  4. PriusTime
    55
    25
    This is a 2012 Prius Two. Mine has a blank cover where the EV mode button would be next to eco and power mode buttons.
  5. El Dobro
    El Dobro A Member
    7,106
    3,282
    You could probably add the switch, but you may also need the harness and some programming.
  6. PriusTime
    55
    25
    Right - I'm looking for anybody who has done this that knows exactly what's needed. Where to wire the switch to or if anybody has even done it.
  7. Corwyn
    2,171
    659
    23
    Maine
    I would doubt that any programming is needed. As the Gen II US version has all programming intact, but no button (The European version has the button. EV mode in the Gen II basically consists of grounding a single pin. I wouldn't expect Toyota to remove the programming for a Model when they didn't for an entire country's cars.
  8. El Dobro
    El Dobro A Member
    7,106
    3,282
    The easiest way to find out is to pull the console cover. If the harness has all three connectors, buy the switch and plug it in. If it works, great. If not, it's back to the drawing board.
  9. PriusTime
    55
    25
    I am hoping it's the same in the Gen III. I searched but haven't seen anybody do it yet.
  10. The Dude
    The Dude Member
    197
    32
    Phoenix
    Don't understand how my 2010 II has an EV button, but not on your '12 two? That's odd...
  11. PriusTime
    55
    25
    I agree it's weird... First I thought it was only on Threes and up. I wonder what makes the distinction whether a car gets one or not in the first place?
  12. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Sounds like you have an One, and not a Two. Do you have the Smart Key System?
  13. The Dude
    The Dude Member
    197
    32
    Phoenix
    Yes, does anyone know why? I thought it was on all gen IIIs
  14. PriusTime
    55
    25
    Yes, it has SKS. It's a Two.
  15. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Just dug out the 2012 brochure I picked up when I bought my car, it shows EV, ECO, PWR are standard for Two to Five. Take it back to the dealer and ask. Maybe the guy on the assembly line did not get the correct Bill of Materials and built it partially to One spec.
    If they sold it to you as a Two, this should be a warranty item.
  16. El Dobro
    El Dobro A Member
    7,106
    3,282
    I just looked at the 2013 brochure and it shows that all levels have the EV button.
  17. The Dude
    The Dude Member
    197
    32
    Phoenix
    It's just so freaking odd... If all Prii have the capability, why would they skimp out on a button and some wiring?
  18. PriusTime
    55
    25
    I doubt they'd give on it being a warranty issue. Might be on my own to figure this one out!
  19. El Dobro
    El Dobro A Member
    7,106
    3,282
    Maybe it was built on a Monday morning or a Friday afternoon. :D
  20. The Dude
    The Dude Member
    197
    32
    Phoenix
    I really think you should ask the dealer. It could be an error like someone else said above.
