Prius Two operating voltage (B+)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriusGuy32, Mar 5, 2015.
  1. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    I took my '12 Prius Two on a 5 hour round-trip today. I decided for fun, to drive with my laptop and TechStream running. Everything looked great, even my MG temperatures & ICE temps, in spite of having my grill blocked 100%, BUT my body voltage was always 15.0v while driving down the freeway o_O I was only running the LED DRL's, radio, and heat (auto, 69f degrees, a/c OFF). This was during the whole trip.
    Is this considered normal behavior in the Gen3?
    #1 PriusGuy32, Mar 5, 2015
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I have never seen my auxiliary battery charge voltage above about 14.5V. I have seen it drift up to about 14.7V momentarily and return to 14.5V.
    I have seen it drop to 13.5V but never as high as 15V.
  3. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    mine is pretty much for the first 90 minutes at 14.8/
    it'll go from there on quickly down to 14.7,14.6 & then a big step to 13.5, where it stays/
  4. mrbigh
    3,686
    699
    Long Island, NY
    It must be an anomaly in your vehicle; 15 volts it is NOT normal.
  5. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Probably cooling fan working over-time in order to keep things cool? Hal
  6. CARspec
    CARspec Junior Member
    53
    Eden Prairie, MN
    2014 Prius Plug-in
    Per techinfo, the normal range is 13-15 volts, so while it's at the absolute maximum, it is within normal range.
    He'd have lots of DC/DC converter codes if it was out of specification I'm thinking. They melt down before they throw high voltage though.
