Prius upgrade in 2008?
Discussion in 'Gen 2 Prius Main Forum' started by DocToss, Feb 15, 2006.
  1. jdjeep98
    jdjeep98 New Member
    211
    Wilmington, DE
    I don't care if they don't change the outside a bit! I just want a plug-in Prius that'll go about 50 miles on a charge, even if it's only below 34mph! B) (although, if it could go up to 55 or so, that would be ok... ;) )
    Better fog lights, a real heads-up display, a block heater that is connected to the charger, and racing moon (disk) wheels would be ok, too... :lol:
  2. airpolgas
    airpolgas New Member
    108
    Cosmo, the article is actually hinting at a sportscar hybrid concept. Although I would still like to see the Volta go production. Toyota has the GS hybrid right now for performance, and I would not be surprised if they have hybrid plans for the IS as well. Regarding the Prius, I think they will always market that for its MPG and efficiency, not performance. Sure, a little bit of power would always be welcome, but I believe Toyota would rather give you a choice between a very efficient Prius and a semi-efficient fast Celica.
  3. Tideland Prius
    16,683
    Wonder if that performance/efficiency switch will make it to the next Prius
  4. DeadPhish
    DeadPhish Senior Member
    2,010
    353
    Outer Banks of NC.. Retired to play golf and poker
    Well then how about this as an option.
    http://www.jalopnik.com/cars/gossip/new-to...-too-154643.php
    cheers :D
  5. Sarge
    Sarge Senior Member
    1,325
    785
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    I was just thinking the exact same thing... it has a very similar look to the Mazda 5, except without the sliding doors.
    I actually really like the Mazda 5 for the versatility, style and price - it is just the fuel economy that is pretty scary. 2.3L engine, 157hp, and it only gets 21/26MPG with the auto, 1MPG better on each with the stick. (!)
    Mazda 5 specs
    That is pretty horrid for any modern 4-cylinder engine. :eek: Mazda just seems so far behind Toyota and Honda for fuel efficiency. Then again, I believe a large part of them are owned by Ford..............
    Kevin
  6. airpolgas
    108
    I believe the RX-8 and the Miata are the only real mazda vehicles. The rest of the Mazda lineup are Fords. I thank Ford for letting the japanese engineers continue with the rotary though. It was hailed as the best engine a couple of years back until it got dislodged by a car that gets 50 MPG :D
  7. hobbit
    hobbit Senior Member
    4,089
    470
    Bahstahn
    You want a performance hybrid, look at the Highlander or the
    Lexus or even the Accord. But I will still argue that doing
    performance hybrids defeats the whole purpose of what the Prius
    is about. I, for example, could easily do with *half* the
    displacement of the current 1.5L prius engine, and probably
    do well north of 100 mpg without half trying. That's where *I'd*
    like to see some options ... without compromising back to a body
    size like the Insight as part of it.
    _H*
  8. Tideland Prius
    16,683
    Hopefully that'll happen wit the Yaris. They currently have engines that run from 1.0 litre and CVT to our 1.5 litre and 4-spd auto (a 1.8 litre T-Sport version is coming). Maybe they'll do the 1.0 litre HSD version. That'll be nice since the 1.0 litre already does close to 50mph (high 40s I think)
