Prius v: 100,000 Mile Club
Discussion in 'Prius v Main Forum' started by usbseawolf2000, Jan 28, 2012.
  1. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Sounds like a good maintenance routine. Both coolants ?
  2. Estela13
    Estela13 Member
    Yes both coolants:)
    ~Estela
  3. JBumps
    JBumps Member
    167
    57
    Morgantown, WV
    2013 Prius Plug-in
    100k+ on the oem tires!!!???
  4. schmuly
    schmuly Member
    209
    51
    BC
  5. JBumps
    JBumps Member
    167
    57
    Morgantown, WV
    2013 Prius Plug-in
    Thanks.
    One post seemed to say only one tire change was part of the maintenance done - hadn't seen that post. Makes much more sense
  6. AllenZ
    AllenZ Active Member
    640
    63
    Chicago
    Do you use synthetic oil or regular?
  7. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    Synthetic is for all current Prius in US
  8. schmuly
    schmuly Member
    209
    51
    BC
    Only use 0-20w, I have a few jugs on hand.
  9. Estela13
    Estela13 Member
    180K on Sunday morning;)
    changed atf ,air filters ,oil
    I did notice it's burning oil will need to keep an eye on it
      File size:
      47.9 KB
      572
    telmo744 likes this.
  10. pooligan
    pooligan Wannabe
    Elgin, TX
    I got 75000 miles on the factory tires.
    Replaced all around with Michelin Defender 90K tires. Got a good deal, but ticked off because my mpg immediately dropped from averaging 45-46mpg per tank to 40-41mpg if I'm lucky (PriusV).
    Anybody else had this problem with these tires? I went on the recommendation of a co-worker who put them on a regular Prius and got no adverse effects. Any reason why a V might get, what I consider, a major gas mileage hit? Already checked proper inflation. No noticeable jitter from improper alignment or mounting that I can tell.
    I had hoped there might be a breakin period, but I've put 8000 miles on the new tires and mpg is still low.
  11. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    As I understand it, tires are complicated. For a given brand and model there can be variants that materially differ.
    Technically, it appears that they're not considered LRR tires.
    [Edit: Oops, I'm wrong!]
  12. Estela13
    Estela13 Member
    changed spark plugs this makes x's 2
    brake fluid flush 1st one
    both coolants this is x's 2
    cwerdna likes this.
  13. Estela13
    Estela13 Member
    Pic... I don't think I will pass 200K until next week
    Pic
    cwerdna, schmuly and Chazz8 like this.
  14. Estela13
    Estela13 Member
  15. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    wow. congrats!
  16. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    I just passed 100,000 miles, I take it in for coolant change monday. No repairs, scheduled service, tires and wiper blades.
  17. LINSEN
    LINSEN New Member
    NEW YORK CITY
    2016 Prius v wagon
    Picked up my prius v on 2-9-2016, I had 40800 miles now,Oil Change / rotate tires. Average between 40 mpg,Using 0w-20 mobil l filter every 10000 oil toyota filter .
  18. sURFNmADNESS
    sURFNmADNESS Prii Family
    199
    48
    Omaha, NE
    My light just came on this week,
    Time for 100,000 oil change/check up.
    Replaced tires around 40k with Michelin Energy Saver A/S (fantastic tires)
    K&N air filter
    Mudflaps from Priuschat.com
    OPT7 LED headlights (tired of replacing Sylvania ultra's every 9 months)
    Replaced all interior lights with LED.
    No oil leaks, not burning any oil. Never run ethanol blended gas in it as manual suggest not too. (had to maybe 3 times)
    Look forward to another 100k.
  19. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
  20. Prius from Dad
    724
    1,116
    Toms River, NJ USA
    Just traded in my 2012 V5 for a Prime Premium. Loved the V! 125,000 mi. 51.6 reported MPG 48.86 calculated. OEM tires, (Yokohama?) Blue Earth, got 100k out of 3 tires, lost one to screw in sidewall. Tires inflated to 65 psi for 100k. I miss the cargo room though. :)
    GregC1979 likes this.
