Prius V 2012: 12V dead Battery replacement
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Hussain22, Dec 27, 2024.
  1. Hussain22
    Hussain22 New Member
    Any Idea why my vehicle wont start after i replaced dead battery with brand new 12V battery? the dashboard comes on but doesnt start. I had this issue before like not starting from first time but now doesnt want to start at all like not reading FOB keys or need to be reprogrammed ? or something wrong with fuse or relay ? Any idea or thoughts ... thanks
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,895
    6,839
    Texas Hill Country
    You could hold the fob up to the button per the owners manual. It will work without a good fob battery in that manner. Otherwise measure your 12v. A new battery should be 12v or better.
    If someone played with the orange hv battery disconnect it may not be properly engaged with the last side push.
    If there was a reversed polarity jump start attempt, things could be serious.
    Hussain22, Air_Boss and Brian1954 like this.
  3. Hussain22
    Thanks for your response.
    I did tried to put the FOB up the button and didn’t work and I installed brand new 12 V battery and new battery for the FOB but still didn’t work. I ve checked all the fuses and they all working. What I think prevents it to run is the anti-theft system as when I press the button the dashboards light up and still the anti-theft engaged and flashing. Any idea if that would prevent the car to run ?
  4. rjparker
    10,895
    6,839
    Texas Hill Country
    We assume you don't get a Ready indicator. True?
    There were four suggestions and you addressed the first.
    A new battery does not guarantee proper voltage. What is voltage at the engine fuse box jump point?
    The high voltage disconnect is often not completely engaged with a sideways push.
    A reversed polarity jump attempt will damage many fuses but the worst is a 125amp fusible link which can be tested by voltage measurement at a defined location.
    Engine fuse box
    Hussain22 likes this.
  5. Air_Boss
    Air_Boss Senior Member
    4,238
    1,192
    New Yawk
    Is it possible the FOB was exchanged? (Different FOB?)
  6. Hussain22
    Thanks for your response!!
    Yes the ready button isn’t showing! I got my mechanic to check on the vehicle and the battery was reading 11.7 V but we boosted up and was showing in the scanner 13.2 V and still Ready button didn’t showed. Any other suggestions? Thanks in advance
  7. Hussain22
    I tried both FOBs and changed the battery in one of them and still nothing . Thanks for your response
  8. rjparker
    10,895
    6,839
    Texas Hill Country
    ok now you have checked 2 out of 4, assuming the 12v was checked with an obd2 scanner.
    Was really looking for the voltage at the front jump point but if it reads through a scanner it's probably ok. However I am not sure you checked the voltage downstream of the fuse box 125a fusible link to ensure a reverse polarity jump has not happened.
    Plus no response on the hybrid battery disconnect referenced above.
    Not all mechanics know enough about these cars to diagnose. A dealer may be the answer.
    #8 rjparker, Jan 2, 2025
  9. Air_Boss
    4,238
    1,192
    New Yawk
    Do you have another Toyota vehicle with a SmartKey FOB?
  10. Kenny94945
    Kenny94945 Active Member
    861
    437
    Sausalito
    2016 Prius v wagon
    OP, FWIW
    If the battery is the only thing worked on and before the battery change all was "normal"...
    Check your work.
    1) You did not accidentally hook up the poss to neg and neg to pos terminals at any time?
    2) When you hooked up the battery the headlights/ stereo/ doors and all were off and closed.
    3) Cables are torqued securely to the battery.
    4) If not mistaken there is a circuit board on the poss battery cable, with a fuse, look for damage and secure connection.
    5) Perhaps easy is to remove/ reinstall - visually check - the fusebox and blade fuses.
    6) As further info to your comembers here on Prius Chat, besides the no start, are all the other lights, door locks, alarms, and other functions all working correctly?
    7) Finally, as a test, will the car start if a booster battery is hooked up?
    Note: I have a "foggy" memory that some Toyota Software may be needed to recognize a new battery... other co-members may remember better.
    Seems you have the car at a mechanic shop now? Post 8, RJ, makes a valid comment.
    Lastly, sometimes Murphy Law/coincidences occur. The no start may not be related to your 12v battery change.
    Good luck with your hunting :)
