Prius V 2012 Ready mode issue
Discussion in 'Gen 3 Prius Main Forum' started by Shahsafi, Oct 23, 2019.
  1. Shahsafi
    Shahsafi Junior Member
    Sacramento
    I have Prius 2012 , not going to ready mode won't Start the engine, Please help
    what I already did
    1. Check the Orange service Plug
    2. check the Converter Inverter
    3. Checked the Hybrid Battery
    The Ready Light blink twice and disappear and two clicking sounds came fro HV battery.
  2. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Jumpstart the car with another 12v battery and the jumpstart terminal located under the hood. I suspect your battery is 8 years old and beyond its useful life.
    Raytheeagle and Maarten28 like this.
  3. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    Yeah, you could check the 12V battery voltage to be sure. Also make sure the brake switch is ok.
    52,785
    is it a salvage title? any history?
  5. Shahsafi
    Sacramento
    It is clean title with 167k miles on it, from whom I bought it, he says it is parked at night and next morning won't start.
  6. Shahsafi
    Sacramento
    I will change the 12 v battery with another one to see if it can fix the issue . Yes I already tried to jump start it. The service plug is also OK
  7. Shahsafi
    Sacramento
    I tried starting it with jump, but no luck
  8. Shahsafi
    Sacramento
    I have tried jump start it and it is clean title with 167k miles.
    What if the Transmission is bad? Will it effect the ready mode or starting the engine?
  9. bisco
    52,785
    are any dash trouble lights on?
  10. Shahsafi
    Sacramento
    All the lights are on, today I removed the main hv battery and I found that its few cells are indicated 5.6 which is way low the actual volts should be 7.5. So thank you all the issue is resolved for now
  11. Shahsafi
    Sacramento
  12. bisco
    52,785
    ouch, that is bad
    Johnny Cakes likes this.
  13. Shahsafi
    Sacramento
    Updates. I have install a used battery and the car get to ready mode but soon it drain the battery and engine get shut off. Any idea?
  14. Shahsafi
    Sacramento
    Engine make white smoke and shaking and knocking badly
  15. ASRDogman
    ASRDogman Senior Member
    8,047
    4,078
    The white smoke is steam from the coolant getting into the cylinder(s).
    Probably a blown head gasket. Which would also cause the shaking and knocking because water won't burn.
    Raytheeagle likes this.
  16. JayRock_PHX
    JayRock_PHX Member
    83
    28
    phoenix az
    Sounds like you bought a Prius v with a blown engine. A lot of jackass people do this and sell a blown hg Prius without disclosing it and then you find out after words
