Prius V -2012 rear brake caliper pins "seized"
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by syscon, May 8, 2018.
  1. Mendel Leisk
    41,463
    Not saying this will work, but what I would try:
    Take the caliper mounting bracket off the car, mount it in a vice. If I recall correctly, there is a 17 mm hex shape on the shoulder of the pin. Try to coax penetrating fluid into the interface, and let it soak. Maybe some gentle hammer taps. Put a 6 point 17mm socket on the pin, try to turn it. Repeat with heat (heat gun, not open flame) if no luck. Repeat with some sort of electric impact wrench on lowest setting, if adjustable.
    There is also a threaded hold in the back of the pin. You could screw a metric bold into that, and grab that with a puller, try a few slams.
    There was something here about that a few months back. I'm not sure, but someone might have found a source for just the rubber ring? Ask a dealership service department, I'm sure they've had to deal with this, would know part numbers if it's available.
  2. Mendel Leisk
    41,463
    Here's (US) McGeorge Toyota Part link:
    Rear Brakes for 2012 Toyota Prius V | Toyota Parts
    To just replace all the affected parts, you're likely looking at 5~6 hundred in Canada. I used to drop $400 on a 4 wheel brake job, decades back, didn't concern me.
    Maybe just shop around for best deal, get all the parts you have to get, get the proper pin lube (Sil-Glyde Brake Lubricant is good, and Permatex Anti-Seize, for the pad-to-shim-to-caliper faying surfaces, and then stay on top of it, thereafter.
    A lot of owners here are saying their pads last and last, the Prius brakes are lifetime. But they're dilussional: the pads are just one component of the brakes, and Toyota does spec complete brake inspection. This is from Canadian 2014 warranty and maintenance booklet, for all Canadian Toyota models:
    Note the brake fluid replacement interval too.
  3. syscon
    syscon Member
    329
    43
    Edm. Alberta
    I've ordered the pins and boot already, will get it by end of May.
    ACDELCO 18K2445 Caliper Guide Pin
    Have a heat gun so will try it.
    #23 syscon, May 9, 2018
  4. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Good suggestion, I'll try to get electrical impact gun it might work. But I think I'll have to take the bracket off.
    When I'll be installing the bracket back ON what the tightening range? Is it: Torque: 57 N·m (585 kgf·cm, 42ft·lbf)
    Do I need to use lock tight on these two bolt?
  5. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Impact guns are not cheap for one job :-/
    If WD-40 will not work, I'll take it to a local tire shop they have impact guns.
    Mendel Leisk and scona like this.
  6. Mendel Leisk
    41,463
    No, it's not spec'd. I would almost never use lock tight on bolts, even if it is spec'd, makes it a pain in future to remove. I've taken brackets off our (regular) 3rd gen Prius, it's not that hard. The bolts are just a little harder to remove, but if you have a good long-handle ratchet wrench and 6 point sockets it's no problem.
    I'll attach third gen Prius brake instruction, fwiw. Obviously the v is somewhat different, but very similar for brakes I think.
  7. farmecologist
    farmecologist Senior Member
    1,958
    1,799
    Southern MN
    sfv41901 likes this.
  8. padroo
    padroo Senior Member
    2,763
    2,252
    I have always justified buying tools by the money I would have spent by taking it to the man.
    The next time I use the tool it is free.
    Common tools are cheaper today than when I was young.
    scona likes this.
  9. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Update.
    I removed the caliper mounting bracket and I was able to remove one pin but the other pin broke. Now, I need to order the bracket itself :-/
  10. Mendel Leisk
    41,463
  11. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Thank you for the information. It seems to me both Left and Right bracket are the same
    Caliper Mount
    Part #47821-47080
    Though, they don't ship to Canada :-/
    Canadian Dealer quoted me 700.00CAD to replace both left and right bracket/pins on the brakes (that is including labour).
    I'll call dealer tomorrow for price of the brackets.
    Though sliding pings, they have rubber O-ring on the end but only lower pins isn't it?
    I'm wandering what kind of grease I should use for the pins.
    It seems to me it has to be "rubber grease" #08887-01206
    But if that is what they used on these rear pins, it is not worth it. My pins are so seized that I broke the metal pin head, it is as if it was welded.
    I have some AMSOil 2000 Synthetic Lithium Complex Grease, would it be compatible with rubber boot and inside ring?
  12. ChapmanF
    18,213
    What was the condition of the (outer) rubber sealing boots on those pins? I'm thinking there has to be a story behind them getting that stuck. I wouldn't be too quick to blame the Toyota grease.
    If you buy the rubber kit at the dealer (pin and piston boots and seals and bleed screw caps) you get a little packet of the right grease right there in the kit so you don't have to spring for a whole tube. I have no way to answer your compatibility question about some other product.
    Often by several years in, the bleed screw caps can be cracking, loose, or gone. Well worth replacing if so, else water gets in through the passage in the screw and bonds the thing to the caliper from the inside out. Can turn routine bleeding into a nightmare job.
    -Chap
  13. syscon
    syscon Member
    329
    43
    Edm. Alberta
    The boots are not damaged on the pins, but the one I was able to remove looked terrible, it is not smooth at all. It looks like somebody put some glue on and let it hardened. I will post a picture once I get a new brackets.
    #33 syscon, Jun 3, 2018
  14. Mendel Leisk
    41,463
    I've been using Sil-Glyde Brake Lubricant on th caliper pins, on our 2010, and revisiting 3 years later they were fine, free moving still, and no swelling of the rubber O-rings on rear brake pins. It's not the "kosher" lube, but it's readily available, and works. I put a thin layer on the rubber "collars" at heads of pins too.
    Faying surfaces between pad backs, shims and caliper, I use Permatex Anti-Seize.
    In a pinch I could ship to a mail box in Blaine, just across the border, it's a common practice. But that's not going to work for you, so far north. Yeah it'd be interesting to see what the dealership quotes, it might not be too bad. Post the the price, good or bad.
    #34 Mendel Leisk, Jun 3, 2018
  15. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Can you ship on my DHL account if I email you the papers (waybill)?
    I'll post it tomorrow, the price.
  16. Mendel Leisk
    41,463
    Better stick with dealership. Sorry, but I don't want to get that involved.
    #36 Mendel Leisk, Jun 4, 2018
  17. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Canadian Price is from 203.00CAD to 234CAD for Caliper Mount Part #47821-47080 Way Over Priced!
    I ordered one from Local Dealer as I need to fix it. But second one I paid 88US (including shipping) to USA address, it will be forwarded to me.
    #37 syscon, Jun 4, 2018
  18. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Here is a picture what is left from Caliper Sliding Pin (original) vs. a new one.
    I've used a vice grip with an extension pipe, didn't work very well :-/
    I don't know what kind of lubricant they use to grease this pin but whatever they used didn't work very well.
  19. Mendel Leisk
    41,463
    Can you trace through the service history? My guess is the brakes have no maintenance, beyond a glance-over when they rotated the tires.
    Or, someone used something like anti-seize on them, another no-no.
  20. ChapmanF
    18,213
    What that is, is rusted beyond belief. I saw you say the boots were not damaged on the pins, but the boots are what have not done their job here, which is to keep the water and salt out.
    -Chap
