Prius v as a Backup Generator
Discussion in 'Prius v Accessories and Modifications' started by syscon, Jun 16, 2013.
  1. syscon
    syscon Member
    329
    43
    Edm. Alberta
    Does anybody have any experience with kits like:
    Plug-Out Island kit Prius 2kva 120v-60hz psw: Home
    I think they connect directly to Hybrid Battery, isn't it?
    If I'm not mistaken Japan models are design to act as an emergency generator.
    It would be a good feature to make it standard on next Prius model 2015 for North America.
  2. mikefocke
    4,079
    1,862
    Sanford, NC
    You want the added cost added on to every Prius? It is already criticized as being too expensive.
    How many people would be interested in such a feature?
  3. syscon
    syscon Member
    329
    43
    Edm. Alberta
    It shouldn't be that expensive if it is mass produce. Though, it might be more suitable for plug-in as it has larger battery.
  4. hb06
    hb06 Member
    550
    Huntington Beach, CA
    Saw the 1KW Plug-Out Island 120v for Any Hybrid at the Prius TGB4 meetup this weekend in Riverside, CA. Company ConVerdant Vehicles. It is a simple clamp onto the 12V battery on the right side rear. positive and negative terminals. Discussed plugging in a normal refrigerator (including surge) and more - computer, router, CFL lights, small TV etc, and generally this basic 1KW model will handle all the above just fine for 5 days with a full tank of gas. Just unclamp when not in use. Can also be used for tailgating. Most assuring is it has been thoroughly tested with the Prius, and at the meetup was in fact clamped onto a gen2 Prius 12V battery in the parking lot. Many attendees were definitely most interested in the unit for using the Prius as an emergency generator, or even a tailgate camping generator. Check it out.
  5. syscon
    syscon Member
    329
    43
    Edm. Alberta
    That Toyota 12V battery is not very strong so I would be skeptical about this approach. Connecting it directly to traction battery would be OK but not the 12V one.
  6. hb06
    hb06 Member
    550
    There is already a 1000 watt power feed from the engine to the 12V battery, so it should be fine if not connecting to a heater etc. It's definitely worth checking out. This vendor can be emailed or called to discuss.
    from FAQ Converdant website:
    "The Basic system is for less than 1000 watts [1kw] of aggregate wattage requirements. The Basic systems allow surge currents of 100% greater than the Rated Power. So, the 1kw unit can sustain a short [10sec] surge power need of 2kw. It gets connected to the car’s 12v battery by the user each time it is used. As a 12v system, the Basic Plug-Out system can work on any car or truck, but works best with Toyota Synergy Hybrids where the 12v battery is in the trunk [set unit on the trunk floor], where there is >1000watt power feed from the engine to the 12v battery, and where there is start-stop engine operation while the car is On and in Park. The Basic unit is inexpensive and easily portable, so could be kept in the car for adhoc uses."
    "The first step is to inventory and prioritize your desired appliances and devices to be supported in emergency situations. Next step is to find out the wattages [voltage and current] for each appliance then total them up."
  7. mikefocke
    4,079
    1,862
    Sanford, NC
    Plug-Out Kits
    Makes sense as an owner purchased after-market option.
  8. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I read somewhere that Toyota was offering the AC inverter only in Japan at this time and as an option, not as a standard component.
    The price was in the $3000 range, though.
  9. hb06
    hb06 Member
    550
    On the Converdant site, noticed a Hurricane Sale for $350 for the Basic 1kw unit ending June 15. Usual price online is now $429. Hopefully, there will be another sale.
  10. triplempg
    triplempg Junior Member
    2001 Prius
    That's pretty nifty.
