Prius v bluetooth problem with iPhone 4s.
Discussion in 'Prius v Audio and Electronics' started by Chuckher, Aug 26, 2015.
  1. Chuckher
    Chuckher New Member
    Marysville, WA
    2013 Prius v wagon
    I have a 2013 Prius v and an iPhone 4s. I have had the phone and car for the same amount of time, and the blue tooth has worked flawlessly until about two weeks ago. I press the "Call" button on the steering wheel, just as I always have, and ask for a contact by name and phone type ("Call Joe Jones, mobile") nothing happens for about a minute or so, then I get the screen asking what type of command I want. If I say "Phone commands" nothing happens. I have to touch the phone command line, then touch the by name command, then I can repeat the name I want called and it will complete the call.
    Sometimes it gives me the "This name is not in the contact list." statement. I have to pull over and select the contact on the phone, then the call goes thru Ok.
    I have removed the phone from the bluetooth on the car, then reconnected it several times, i have also refreshed the contact list several times. Why would it suddenly start acting up like this?
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,919
    4,685
    Texas Hill Country
    Make sure the air conditioning fan is not higher than about 1/2. The noise it makes will sometimes garble the voice commands. Once it misses a command altogether, hit the steering wheel "hang up" button to cancel and then start over. Speak faster rather than slower. It does not like slowly spoken commands.
