Prius V-Brake Booster & Pump Assemblies Failures
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Kenneth S, Nov 18, 2021.
  1. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    It looks like the henway is leaking.....
  2. ChapmanF
    19,019
    Good thing that's only five or six pounds.
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,094
    6,961
    Texas Hill Country
    What's a henway?
    #43 rjparker, Jan 1, 2022
  4. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Then henway is located next to the hammerfor..............
  5. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
  6. Kenneth S
    Kenneth S Junior Member
    32
    Kansas City, MO, United States
    2013 Prius v wagon
    OP here giving a quick update: It's now been 2+ months and Toyota still has my car. Apparently the parts aren't just backordered, they're also simply not available.
    Car was dropped off at Toyota Service on 19 November.
  7. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Thanks toyota.........
  8. rjparker
    11,094
    6,961
    Texas Hill Country
    Did they give you a loaner or rental? My guess is no. I am hearing Toyota's new Tundra is in trouble with junk Turbos, some of which don't make 500 miles. They are not loaning those guys cars from what I hear.
  9. Kenneth S
    32
    2013 Prius v wagon
    Yes, we have a loaner Corolla from the dealer.
  10. Kenneth S
    32
    2013 Prius v wagon
    Toyota still has my car. It's now been ~4 months and I'm wondering about the ill effects of my car sitting unused in the dealership lot for this long. Should I be asking them to perform some additional service to ensure the rest of my car isn't degrading from lack of use?
  11. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    Yikes! Supply chain issue?
  12. Kenneth S
    32
    2013 Prius v wagon
    That's what they're telling me. They have one of the two parts needed for the repair. No insight into when the second will arrive.
  13. rjparker
    11,094
    6,961
    Texas Hill Country
    I would have them drive the car if it is not torn down or at least run the engine if possible to benefit the hybrid battery. The parts availability issue is odd since other v's have been repaired in the meantime. I have a feeling they never really checked other dealer's stock.
  14. Kenneth S
    32
    2013 Prius v wagon
    Thanks. I'll call and ask them about both topics: driving the car and parts. I take it the other repairs you mention have been other threads on Prius Chat with the same problem?
  15. rjparker
    11,094
    6,961
    Texas Hill Country
    Yes. In fact a few days after your delay I referenced the reported parts backup. That guy had his brake booster system (master cylinder and pump) fixed free two days later. I will say there are different part numbers for the master cylinder based on tire size.
    #55 rjparker, Mar 14, 2022
  16. Mendel Leisk
    42,343
    The 12 volt battery is very likely toast, if they're a typical dealership.
  17. Tim Jones
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Thanks............toy......................... gen 3 a nightmare when they get older......... my trani finally went out........
    Deciding whether to fix or sale...........actually needs engine and trani....... 300,000....... not even close to the reliability of my Camry and Previa.
    Traction battery
    3 water pumps
    blown inverter
    master cylinder and accumulator
    blown head gasket
    Once a prius lets you down you are never quite so trusting anymore.....
    good thing these thing were done by me or covered under some kind of safety recall....or it would have been many thousands...
    Used gen 3 not recommended unless it's low miles and you don't plan on keeping it for a long time.
  18. Kenneth S
    32
    2013 Prius v wagon
    I called a few other dealers nearby and asked about these two assemblies. Apparently the regional distribution center has them in stock, but because they are not the “CSB part numbers,” the dealer can’t use them in order to get Toyota central to pay for the repair. Does that sound accurate? Seems absurd I’m waiting 4 months when suitable parts are readily available.
  19. rjparker
    11,094
    6,961
    Texas Hill Country
    You need to talk to the dealer. They may have forgotten about it.
  20. Kenneth S
    32
    2013 Prius v wagon
    Tried calling my own dealer. My service rep won’t call me back for me to ask the question. At this point I’m not even sure what to ask because whenever I do get the rare chance to talk to him, he says the parts department has no update
