Prius v brake noise problem fix
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by desmondlee, Sep 13, 2013.
  1. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    FYI
    The Toyota dealer called today to say they have a fix for the brake noise.
    He has to order the parts.
    Will let everyone know if this "fix" works or not.
  2. MarathonMarty
    MarathonMarty Prii 4-timer
    38
    Spokane, WA
    2013 Prius v wagon
    I had the fix (TSB 0081-13) done back in November 2013. Eliminated the dreaded groan and it hasn't returned since.
  3. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    my car already had the fix when I purchased it
    So this is a newer fix
  4. NadaMucho
    NadaMucho Junior Member
    17
    San Jose, CA
    Last couple of weeks I've been having the rear brake noise on my 2013 so i took it in to get it fixed.
    To my surprise, it's worked like a charm. Left the car outside in the rain these past three days with no brake noise in the morning.
  5. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    Got my car back on Saturday 3/3/2014.
    The brake noise seems to be fixed. No noise yesterday morning or this morning.
  6. Danf51
    Danf51 Junior Member
    Eugene Oregon
    I am taking mine in tomorrow morning. Apparently new calipers will be installed. It is supposed to take 2 hours. I guess that it would be a miracle if they installed new pads also, but I can always hope.
  7. h-dogg
    h-dogg Junior Member
    44
    South Bay
    Does this fix only fall under the 36k miles warranty? My 2012 is experiencing this and it is at 38k miles and just wondering how much this will cost out of pocket.
    Thanks!
  8. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    How much does it really bother you? There's nothing mechanically wrong with your brakes.
  9. h-dogg
    44
    South Bay
    If that's the case, then that doesn't bother me too much. i'll wait for a brake change down the line to replace.
  10. Seamus Warren
    Seamus Warren New Member
    Sydney
    2016 Prius v wagon
    According to someone experiencing a similar issue, it was addressed and noted in a Toyota Service Bulletin “T-SB-0081-13” (Brake Callipers).
    At cooler ambient temperatures my idling 2016 Prius V starts howling or groaning as it coasts out the garage. The groaning ceases as I reach the drive.
    A/V samples of the howling/groaning sound are available at the links below.
    My initial and non-technical speculation was some moving part is not lubricated or warmed up or correctly aligned.
