Prius V buying advice
Discussion in 'Prius v Main Forum' started by danielac86, Oct 5, 2022.
  1. Zradub
    Zradub Junior Member
    40
    Oh, my wife got an indicated 60.4mpg in the 3rd gen drafting me home. Normally I’d have the worse aero/mpg car follow, but wanted to see real numbers in the V. I’m going to tank up and add my ‘secret’ brew to the tank and see what happens. :)
    Thanks again.
  2. Zradub
    40
    Will I see an mpg improvement with the gen 4 engine? A power increase? Wish, but don’t understand why the non-hybrid motor can’t be tuned/mildly built to add power and/or efficiency…o_O
  3. Zradub
    40
    I’m an old, heavy guy that doesn’t train much and am about as fast on my bicycle as young, lithe, super hero’s, and my speed is proven on Strava.
    Understanding aero drag and efficiency on the bike are my wins. Same things I used 2 decades ago on my Mk1 (70s/early 80s) Volkswagens to make them overachievers.
    Why isn’t it used to make our cars perform better? Why isn’t there an Intake, porting/polishing, exhaust, wheel weight, aero mods list available to go from 44 to 60mpg? I can’t believe it’s lazingness as many engineers own these…
    I’m not an engineer by trade, but I guarantee I can find gains.
  4. Mendel Leisk
    42,355
    First couple of links in my signature have some tips, strategies, relevant repair manual info and links.
    Zradub likes this.
  5. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    Look up Atkinson Cycle Engine and do a little reading. The intake valves are left open for a certain amount during the compression stroke. Not sure how you'd tune that....
    REVVL V+ 5G ?
    Zradub likes this.
  6. Zradub
    40
    Thanks guys. Have a good night. Tomorrow I will be cleaning all vehicles after my morning ride. :)
  7. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    A
    #27 douglasjre, Oct 27, 2022
  8. rjparker
    rjparker Tu Humilde Sirviente
    11,123
    6,978
    Texas Hill Country
    These cars are quite aero. Even the hub caps, factory windshield wipers and undercovers are there to enhance aero.
    A Gen4 swap is not mainstream yet, mostly diy. Also requires parts of the gen3 for ease of installation including gen3 egr.
    Gen3 rebuilds are common and start around $3500 installed if you shop and have trust in an independent shop. Best to build that connection before the big stuff hits.
    Probably the only mod that gets results is a lithium battery cell retrofit.
  9. Zradub
    40
    I’ll let you try it soon just for asking. It’s good to have many PhD/post doc friends in the sciences… ;)
  10. CR94
    CR94 Senior Member
    2,832
    1,243
    Northwestern S.C.
    Have the EGR cooler and EGR passages of the intake manifold been cleaned out? If so, or if you do it soon, that original engine might last a long while yet with good care. Methinks the manifold is more critical than the cooler, especially if the overall restriction the car reports via OBD-II port is reasonable.
    The above assumes it isn't consuming coolant or much oil. Otherwise, I wouldn't be so optimistic.
    Toyota has already done for you most of the fine-tuning you're looking for.
