Prius v. Camry Hybrid
Discussion in 'Gen 2 Prius Main Forum' started by roshr, Nov 14, 2006.
  1. TJandGENESIS
    TJandGENESIS Are We Having Fun Yet?
    5,299
    47
    ★Lewisville, part of the Metroplex, Dallas, in the
    <div class='quotetop'>QUOTE(Tideland Prius @ Dec 2 2006, 10:56 PM) [snapback]356816[/snapback]</div>
    Yes, well. The HyCam had been in a accident...and the miles were at 9000 or so. I got a great trade in value for it.
  2. Cox
    Cox New Member
    38
    <div class='quotetop'>QUOTE(daniel @ Nov 15 2006, 01:01 PM) [snapback]349573[/snapback]</div>
    Well said. I couldn't agree more. I'm surpirsed it took this long in the dialog to be said.
    If I wanted comfort or performance I wouldn't have traded an M3 for the Prius... what I wanted, and I believe we should all wish for this, is a way of getting around that does its best to reduce this countries dependence on foreign oil, encourage the development of the greenest cars, plus hand over the cleanest planet to the next generation (and yes, I do walk or cycle the shorter journeys).
  3. Tideland Prius
    16,683
    <div class='quotetop'>QUOTE(TJandGENESIS @ Dec 2 2006, 11:09 PM) [snapback]356886[/snapback]</div>
    ohh, that explains it lol.
  4. Per
    Per New Member
    232
    San Antonio
    <div class='quotetop'>QUOTE(Jonnycat26 @ Nov 15 2006, 08:59 AM) [snapback]349446[/snapback]</div>
    According to the brochures, the HyCam battery has a higher kW rating and also higher voltage than the Prius battery, so is it true it's smaller?
  5. NuShrike
    NuShrike Active Member
    1,378
    <div class='quotetop'>QUOTE(TJandGENESIS @ Nov 14 2006, 01:57 AM) [snapback]348627[/snapback]</div>
    The Prius does have A/C vents for passengers underneath the front seats, unless I'm misunderstanding and the Camry has some better vents located in say the rear of the center-console.
  6. Tideland Prius
    16,683
    <div class='quotetop'>QUOTE(NuShrike @ Dec 4 2006, 08:10 PM) [snapback]357785[/snapback]</div>
    You're mistaken
    The Prius has "rear seat heater ducts" and those are the ones that are under the front seats
    The Camry's "rear seat vents" are the ones that come out of the rear of the centre console box. That's in addition to the rear seat heater ducts
  7. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    the AC vents may not be available in the backseats, but on more than one occasion, i've had complaints that my AC settings were too cold for someone riding in the back.
  8. daniel
    14,487
    1,519
    Spokane, WA
    <div class='quotetop'>QUOTE(Per @ Dec 4 2006, 06:32 PM) [snapback]357744[/snapback]</div>
    I don't know the specs for the HyCam. But do not confuse the kW rating with the kWh rating. The first is the amount of current it can provide, and therefore the amount of power for acceleration. The second is the amount of energy it holds.
  9. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    <div class='quotetop'>QUOTE(daniel @ Dec 2 2006, 11:27 PM) [snapback]356851[/snapback]</div>
    The sheer ugliness of the system sitting up on the dash precludes any of those benefits to me.
  10. pvsurfer
    pvsurfer New Member
    Daniel, which model Garmin do you have? ...and how well does it handle re-routing (if for example, you run into a detour on its prescribed route)?
