Prius v computer "stall"
Discussion in 'Prius v Technical Discussion' started by martinontheroad, Nov 16, 2011.
  1. martinontheroad
    martinontheroad Junior Member
    San Diego
    Just bought a Prius v with all the trimmings. Very satisfied with the car with <160 miles driven. I have noted only one negative thing so far - when interacting with the cockpit computer, such as entering map destinations, the computer behind it just seems to "stall" or go to sleep for 10s of seconds at a time. It is quite frustrating to wait 30 seconds between individual button pushes to enter in a destination address. Has anyone else experienced this? Is there a fix? I haven't had the opportunity to contact the dealer yet.
    - Martin, San Diego
  2. pvogel
    pvogel '05 Five & '12 v
    87
    25
    Santa Clara, CA
    haven't noticed that at all in my v Five with AT, the nav is much snappier than in my '05 Prius V.
    Peter+
  3. Vinoh
    Vinoh Junior Member
    San Jose, CA
    I haven't noticed this problem but I did just notice something in the nav manual that might help. It says that, in the event of a slowdown in the display, you should push the volume/nav power button for 5 seconds to reset the nav system. Hope that helps.
  4. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Just to clarify you are stopped when this happens correct?
  5. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    does the prius v use a dvd based nav? if so, you may want to clean it....
  6. MBRGuru
    MBRGuru Member
    255
    26
    None of the new systems use a DVD.
    OP -> Are you driving when this happens? Idling?
  7. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
  8. martinontheroad
    San Diego
    It appears that the Toyota navigation system will not allow inputs while the car is in motion. This being my first Prius, I am not sure if this is standard or not. As a passenger, I could start entering info at a stoplight, but could not continue until the next stoplight.
    So, is this SOP for Toyota/Prius nav systems?
    Can this be modified at the dealer? Seems silly to have to pull over and stop so that nav info can be entered.
    Thanks in advance!
  9. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    That is standard for all Denso systems. It is a safety "feature". The way around it is to use voice navigation input, but I am not sure if any Toyota models have it.
  10. MarathonMarty
    MarathonMarty Prii 4-timer
    38
    Spokane, WA
    2013 Prius v wagon
    Any 'v' with nav has voice command capability. And it works very well, I might add.
