Prius v Display Audio Service Menu w Battery Check
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by rjparker, Feb 3, 2015.
  1. rjparker
    rjparker Tu Humilde Sirviente
    10,153
    6,310
    Texas Hill Country
    This is what I am using for coolant temp and the correct mph.
    Ebay
    search p10 obd2 smart digital
    It connects to the obd2 connector and uses the CAN bus to monitor ecu data. You can see the black cable to the left. It has a variety of standard points it can display.
    I added an obd2 16 pin switch cable ($8) as well although their auto powerdown settings are fine since I drive the car every day or two.
  2. AzusaPrius
    AzusaPrius Senior Member
    2,184
    920
  3. Air_Boss
    Air_Boss Senior Member
    4,198
    1,184
    New Yawk
    Internal GPS for accurate speed? Which brand and model? Thanks.
  4. rjparker
    10,153
    6,310
    Texas Hill Country
    No GPS in the P10 available on ebay per post above. Toyota over reports the speed by 2.5-3% on the dash but the CAN bus has the accurate mph. I also set a speed alarm at 70.
    Air_Boss likes this.
  5. Mjlangan
    Mjlangan New Member
    Louisiana
    2015 Prius v wagon
    Thanks for the help, rjparker! Just got a chance to try it. Got a question about the second step, where is the “CAR” button? I don’t see it, probably right under my nose!
  6. ozjimjam
    ozjimjam Junior Member
    35
    17
    22
    australia
    2016 Prius v wagon
    I just found this thread , after owning the car from 2016, it is so useful.
    By the way , on the 2016 base model in Australia market, it is the Apps button ( instead of car button)
    Also there is no setting button, instead, the Audio button worked for me
