Prius v - full test
Discussion in 'Prius v Main Forum' started by jhinsc, Apr 29, 2014.
  1. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    Finally, another honest auto test drive of the Prius v! :)
    Prius v Full Test - Edmunds
    They describe the pros and cons and actually achieve real-world mileage similar to what I do - unlike another auto mag that will go unnamed who could only do 31 mpg!:cautious:
    Oddly though, even though the stats show how 'slow' it is, I've never felt I didn't have enough get-up-and-go to handle all traffic situations. Either I'm getting older and slower, or likely, we really don't need to go 0-60 in under 6 seconds to feel you have adequate power!
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    The only time I really notice the lack of power is at 75-85 mph when trying to pass or climb a hill. The reviewer seems a bit uninformed about engine braking, but otherwise its a pretty decent review. Some of his criticisms are just typical reactions for someone who's not used to the car. He's clearly not a Prius driver.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Folks, I put another cargo mat on top of the (folded) rear seats, facing backwards. It eliminates the gap, protects the seat backs and quiets the car.
    It seems every test driver finds B mode and decides he HAS to use it. The only reason it exists is Toyota is legally required to have a transmission position with more engine braking.
    And yes, if there were other 40 MPG station wagons with more than 65 cubic feet of cargo room, I would be looking at them.
    My only 'if only' is no 3 door SKS on the v 3.
    bigrin likes this.
  4. vlady
    vlady Junior Member
    42
    Issaquah, WA
    Yeah, car does labor the steep hills, so did my 1998 Corolla. Even my v6 98 Sienna downshifts and revs to 4000 to deal with mountain passes while maintaining speed limit. Nothing strange here.
    On level terrain car is blast to drive and maneuver between traffic at any speed. On my trip to SoCal on congested I-5 hauling 4+luggage ,I may upset a few drivers by stealing space in front of them. Car has enough available power to propel in front of traffic.
  5. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    Pretty spot on for a short article.
    I felt stupid when It said
    What the heck is Normal Mode, and where do I find it? I looked everywhere ;)
  6. jhinsc
    1,167
    259
    South Carolina
    Normal mode is when your v is not in Eco or Power mode. There's no button for it.
  7. Stevevee
    821
    224
    Vermont
    How would I get into Normal Mode?
    Aha, but I think I've done this at some point.
    Press the ECO button if already on, and it should go off. LOL, what a hoot.
  8. jhinsc
    1,167
    259
    South Carolina
    The same way you turn on Eco or Power modes with their buttons, just press them to turn them off. Just make sure you're not in Eco mode or Power mode. When they are both off, you're in Normal mode. You won't see anything to indicate you're in Normal mode.
  9. Stevevee
    821
    224
    Vermont
    I don't like the added pressure in ECO mode. I've also found that in ECO, plus using pulse and glide, I've begun to hate driving ;) Frankly, I miss my 2004 Corolla S. 75 on the interstate in complete harmony, averaged high 30's all the time.
  10. jhinsc
    1,167
    259
    South Carolina
    I use Power mode most of the time. I like the response from the gas pedal plus I can get the same mileage as Normal or Eco. It's easier for me to feather the gas pedal in Power mode too.
  11. mikefocke
    4,079
    1,862
    Sanford, NC
    Odd that he uses the upper case v.
    And every time I see a diesel comparison, I want to scream "but put in the extra cost of diesel fuel and the cost per mile looks a lot different than raw MPG figures".
    All in all, a review that mostly matches my perceptions except that, as a ex-Porsche driver I have found no case where I really wanted/needed any extra power. I think I unconsciously drive it a bit differently allowing more room. I'm first out at the stoplight but don't need to play boy racer. I can't recall a single incident where I'm holding up someone else who is driving in a semi-reasonable manner.
  12. Stevevee
    821
    224
    Vermont
    If you look at the rear emblem, it's a pretty Large V they use.
    They really need to change to entire Prius nomenclature, it gets pretty confusing. I've always hated the trim level designations Three Five, etc..
  13. Mike500
    Mike500 Senior Member
    2,593
    767
    Since retiring, I've had no desire or need to do any "high performance driving" or risk my life pursuing crooks, although I still have the skills.
    Even then, I knew and felt when the car was losing it. Luckily, I was wise enough to back off. In the current situation, I clearly hear at least one or two reports of idiots running off the road, overcorrection and overturning. They don't report, if the drivers were texting or looking at their I-Phones.
    I just take my time in going anywhere, ECO mode is good enough for me. If others are in a hurry, I just let them pass.
    Driver's have gotten so much worse over the years, especially with the distraction of cell phones and texting.
    The majority of my driving time is to stay alert and to stay away from these idiots as much as possible.
  14. Makaru
    Makaru Junior Member
    51
    2013 Prius v wagon
    I totally dispute the veracity of this sentence in the article:
    Ford C-Max Hybrid: As the Prius v's closest rival, the C-Max Hybrid is similarly priced and betters the Toyota's fuel economy by 1 mpg
  15. Mike500
    2,593
    767
    They also do NOT mention all of the C-Max's reliability issues.
    I'm glad I got the "v."
  16. JeremyB
    JeremyB Junior Member
    24
    Huntsville, AL
    The C-MAX Hybrid does beat the Prius v by 1 mpg combined using the (corrected) EPA numbers. I think it's beyond a reviewer's scope to independently verify mpgs with respect to the EPA except under extreme circumstances (aka previous C-MAX mpg ratings). All sorts of 'official' numbers (legroom, EPA passenger/cargo volume) can be gamed and don't correlate 1:1 to real world experience.
    I'm in the market for a Prius v, and the I generally agree with the review. "The 2014 Toyota Prius V lacks any semblance of excitement or personality." That sums up my impression from my test drive. The poor acceleration, lackluster handing, etc can easily be chalked up to the fact that you're getting 42 mpg out of it. The boring, ho-hum interior a bit harder to swallow, especially when compared to similar (non-hybrid) offerings.
    Bob-blehead likes this.
  17. Stevevee
    821
    224
    Vermont
    In terms of size, the best comparison for the CMax is the Prius hatchback. They don;t use that comparison because the Prius kills it in fuel economy. It's also sportier inside and a but easier to throw around.
    The v has far more space than the Cmax, it's like comparing a Rav4 to a Suburban. But then again, Ford has managed to persuade people to think this way. In the real world, it's not hard to get a v to get better mileage than the C Max. Ironically, the Fusion hybrid fell off the radar when they lied about the 47/47/47 mileage.
    But I do admit, the little Ford is fun to drive, and is very nice inside. Toyota could learn a lot if they'd just open their eyes a bit.
