Prius V ( JDM) 2011 Engine
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by ahmad ashfaq, Jan 17, 2019.
  1. ahmad ashfaq
    ahmad ashfaq Junior Member
    57
    islamabad islamabad
    2011 Prius Alpha
    Dear folks ,
    I am in the process of getting a used Engine for my Prius 2011 V ( ALPHA ) , the sellers insists i change my transmission too ,
    the Engine i am buying is 2014 Model ,
    Can you guys advise what to consider during engine change , like Shall i swap Wiring , ECU etc ,
    And are 2014 model better as compare to 2011 model etc ,
    #1 ahmad ashfaq, Jan 17, 2019
  2. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,782
    2017 Prius c
    The entire process will be easier if you take as much as you can WITH the new engine, especially the transmission.
    ahmad ashfaq likes this.
  3. ahmad ashfaq
    57
    islamabad islamabad
    2011 Prius Alpha
    Sam , these are used but newer model imported from Japan , so will there be any issue regarding Moel year difference , mine is 2011 and the available is 2014 model ?
  4. sam spade 2
    7,035
    2,782
    2017 Prius c
    I do not know.
    I really hope your mechanic does know.
  5. ahmad ashfaq
    57
    islamabad islamabad
    2011 Prius Alpha
    i hope so too , thanks Sam
