Prius V Lift Mods?
Discussion in 'Prius v Accessories and Modifications' started by TaftMaster, Feb 15, 2020.
  1. TaftMaster
    TaftMaster New Member
    Tennessee
    I'm looking to lift my 2012 Prius V2 a few inches for the rougher roads in my area. Does anyone know of any safe ways to do this without compromising the smooth ride of the vehicle? Is the suspension compatible with the suspension of any other vehicle? I haven't found anything but lowering kits online so far. Thanks guys!
  2. Centerpunch
    Centerpunch Active Member
    150
    139
    OH / NC
    2017 Prius v wagon
    #2 Centerpunch, Feb 16, 2020
  3. Kenny94945
    Kenny94945 Active Member
    864
    439
    Sausalito
    2016 Prius v wagon
    Interesting question.
    Finding a lift kit would be the answer...but never heard of one.
    That leave to items that I can think of.
    1) Coil over shocks with a height adjust.
    a) May not be inexpensive
    b) Wheel re-alignment, especially the rear, may be futile.
    2) Tall tires
    a) Again may "screw up" the speedometer, bounce and jounce function, traction control and Abs and be futile.
    b) You'd might be the "ginny pig" experimentor.
    Anyway, good luck let is know if you succeed with your project.
  4. Tim Jones
    Tim Jones Senior Member
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    V shocks are different than prius......
    Front and back.............including bolt pattern and length.
  5. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    A company called CEIKA makes a lift coilover kit. Actually choosing the OEM height version seems to go higher than stock as well.
    moto g(7) power ?
  6. Onikally
    Onikally Junior Member
    Have you figured out a good way to lift your car OP?
    PriusOffroad likes this.
  7. PriusOffroad
    PriusOffroad Active Member
    108
    170
    Chico, CA
    spudnut likes this.
  8. PriusOffroad
    108
    170
    Chico, CA
  9. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    670
    269
    Dodge Co. Wisconsin
    2017 Prius v wagon
    No lift shown for the v
  10. PriusOffroad
    108
    170
    Chico, CA
    The Gen 3 kit works on the Prius V. “DESCRIPTION - Front and rear strut/coil spacers for 2010-2015 Toyota Prius, and Prius V.“
    bat4255 likes this.
  11. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    Just for anyone's info..... the front and rear shocks are not the same on the v and hatchback
  12. bat4255
    670
    269
    Dodge Co. Wisconsin
    2017 Prius v wagon
    I assume it works for a '16 v
  13. PriusOffroad
    108
    170
    Chico, CA
    The front strut mounts, and rear spring perches are the same however which is what components the lift kits utilize. Making them interchangeable between the V and hatchback.
  14. PriusOffroad
    108
    170
    Chico, CA
    Yessir. 2010-2017 V. I’ll probably end up creating a separate product listing for V and plug in models just to avoid confusion.
  15. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    I know that..... just throwing in the additional information about the shocks..... they are totally different.... just like the transmission, headlights, and master cylinder(ecu) , just to name a few.
