Prius v liftgate lock sticking
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Quaternaria, Oct 31, 2020.
  1. Quaternaria
    Quaternaria Junior Member
    SF Bay Area
    Hi all, new v owner--
    The trunk/liftgate lock is sticking. How hard is it to remove and clean, or replace? It looks like there are a few bolts and a small plastic panel for the emergency release. Thanks so much in advance.
  2. icyrius
    icyrius Active Member
    225
    107
    Florida, USA
    2014 Prius v wagon
    Just vacuum it. That would do the trick.
  3. Quaternaria
    SF Bay Area
    I tried vac, no luck so far....
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,782
    2017 Prius c
    Is it the lock mechanism that is sticking.......or the LATCH ?
    (Edit: OK, maybe there isn't an actual lock mechanism at that point.)
    Either way, spray silicone lube is the best thing.
    It is safe to put into the lock cylinder OR in/on any of the latch parts too.
    When it dries it does not gum up over time like oil based products to.
  5. Quaternaria
    SF Bay Area
    Thank you, I will try that. There's something that looks like sand in the lock in the lid (not from me!).
    I have to slam the back liftgate or it won't lock, and then it fails to unlock. I suppose the locking hoop might need to be adjusted but it looks fine. Tx.
