Prius v (lowercase v for the Prius v wagon) more sporty feel.
Discussion in 'Prius v Accessories and Modifications' started by msg4life, Nov 16, 2016.
  1. msg4life
    msg4life Member
    74
    29
    portland, OR
    2015 Prius v wagon
    If you have techsteam and under body and chasis. Go to customize and other change body control chasis torque to off. It disables the pitch and bounce feature and this made my prius v (lowercase v for the Prius v wagon. Only 2010 Prius used uppercase roman numerals for model designation) feel so much more responsive in normal mode. They say to disable this feature if you change any suspension parts with aftermarket. Please check it out. I dont notice a difference in ride quality but I do notice a difference with throttle response.
  2. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Thank you for letting Priuschat know! Smart thinking
  3. fyl
    fyl Junior Member
    Auckland
    Interesting find. Will definitely give it a go.
  4. Air_Boss
    Air_Boss Senior Member
    4,001
    1,093
    New Yawk
    Since "Pitch and Bounce Control for the Prius v" works only on low frequency longitudinal oscillations, changing spring rates would change the pitch oscillation frequency and thus the system's behavior, but adding ARBs or chassis stiffeners which operate in the roll axis would not. Since the system functions by modulating motor torque, disabling it would eliminate the low frequency +/- modulation of motor torque
  5. fyl
    fyl Junior Member
    Auckland
    I think Nissan's Active Ride control works the same way and their explanation is definitely clearer to me. Can't find much details on Toyota's.
