Prius v (lowercase v for the Prius v wagon...) Wagon (only) MPG - Please Post Your Results
Discussion in 'Prius v Fuel Economy' started by F8L, Oct 30, 2011.
  1. woppa
    woppa Junior Member
    60
    NYC
    2013 Prius v wagon
    Its probably got something to do with the pressure change in the tires when the temperature drops.
  2. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    I check my tire pressures frequently with a digital gauge and I don't see that much change. So, I don't think you would see such a wide range in mpg from the tire pressure changing by a few psi (50*-75*).
    I think the bigger impact is the use of cabin heat when it gets colder. Using heat will cool down the engine faster when in EV along with the engine staying on longer when you stop. That tends to reduce your mpg.
    Personally, my trip mpg's only chaged by only 2-3 mpg the first week of May (our warm spell). I normally get about 52-53 displayed mpg (on dry roads) on my 32 mile (each way) commute. During the first two weeks of May, I averaged 55-56 displayed mpg's. You can see my tank info from my Fuelly.com signature.
  3. 13PV
    13PV Junior Member
    82
    2013 Prius v wagon
    2nd tank of gas: 39.9mpg included a 200 mile road trip: avg 70mph?
    tire pressure: 40-42?psi - stock 17" rims
    a/c on/off intermittently
  4. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I did my first short road trip - 175 miles round trip. Highest speed was 70, but ranged between 55 and 65 since I didn't want to go more than 5 over the limit. I still have a couple days before filling up but I already know this will likely be my worst tank so far, unless I can get my mpg's up over the next 125 miles!
  5. jhinsc
    1,167
    259
    South Carolina
    I did a bit better on this tank than I thought; 44.7 mpg - right at my average. I thought I would be somewhere between 40 and 42 so I'm happy with the results. I have to do the same road trip again this week, most likely during the day when I have to use a/c so it will be good to see the mileage impact.
  6. Priuswagon
    Priuswagon I love my Prius
    112
    Kingston Washington
    Last summer when I drove to the ocean and it was warm out I got close to 50 mpg. It is fairly flat terrain so it all depends on if you live on a hilly place or live in a flat hot place. This week my Prius is averaging around 47mpg but the temperatures around here are in the mid 70s.
  7. 2013-Prius v
    2013-Prius v 2013 Prius v 5
    198
    39
    Orange County, CA
    2013 Prius v wagon
    With 160 miles driven on this tank of gas, currently clocking average 49 mpg
    iPhone ?
  8. blisterpeanuts
    blisterpeanuts Junior Member
    28
    2013 Prius v wagon
    51.7 mpg on last fill-up. I had driven about 520 miles, mostly highway driving for a trip out of town, using air conditioning much of the time. It was so nice to drive 200+ miles to my destination, do a bit of driving locally, then come home and still have plenty of range left in the tank!
    Currently the display is showing 54.9 mpg for the first 270 miles of this fill-up, mixture of highway and local driving. I'm hoping to bump it over 55 by the time I fill it up again, but when the wife takes the car she doesn't try to hypermile as I do.
  9. 2013-Prius v
    198
    39
    Orange County, CA
    2013 Prius v wagon
    563.6 miles on tank
    Computer reads 46.3 mpg
    She took 13.319 gal of fuel to refill
    Fuel light on with range=1 mile. Didn't want to risk it so I filled up
    This is my personal best on a tank of gas
    iPhone ?
  10. jhinsc
    1,167
    259
    South Carolina
    So I guess this proves the v gas tank holds more than 11.9 gallons?
  11. 2013-Prius v
    198
    39
    Orange County, CA
    2013 Prius v wagon
    I could have shoved more fuel down her throat but decided thus was enough
    iPhone ?
  12. jhinsc
    1,167
    259
    South Carolina
    I'm typically at 465 - 485 when I'm down to 0 miles to empty. The most I ever filled up was at 495 miles and 10.84 gallons. To me that was cutting it close. I typically let the pump shut off and then do another two clicks.
  13. jhinsc
    1,167
    259
    South Carolina
    Do you fill up until you see gas at the top of the filler neck?
  14. 2013-Prius v
    198
    39
    Orange County, CA
    2013 Prius v wagon
  15. PLSPUSH
    PLSPUSH Active Member
    359
    132
    Tulsa, Okla.
    last tank
    45.5 calculated
  16. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    Last tank was my best ever (I have owned it through a winter) of 44.2 MPG by Fuelly.
  17. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Very 1st trip to the gas station. Display indicated 45.8 MPG ave, actual mileage is 43.2 assuming it was really full from the dealer. 454.7 miles, took 10.52 gal. Still had one solid pip showing with a red indicator light on and less than 0 mile range showing.
  18. Priuswagon
    112
    Kingston Washington
    I put Arco gas in my Prius last week because I was on empty and it was the closest gas station. My mileage went below 40mpg. This week I put Shell gas in my Prius and I am getting around 47 mpg. I wonder why Arco gas is so bad compared to other gas.
  19. Aran
    Aran New Member
    24
    2013 Prius v wagon
    I'm confused because it appears I have a higher calculated MPG than displayed, where most people get the opposite.
    I just filled up after depleting our first tank.
    Drove 503 miles, filled with 10.11 gallons, range showed 13 mi. left. Avg. mpg showed 48.0, but 503/10.11 = 49.75.
    Am I missing something?
  20. jhinsc
    1,167
    259
    South Carolina
    See if you can repeat this mileage over the next couple tanks. Maybe you didn't quite fill it all the way?
