Prius v (lowercase v for the Prius v wagon...) Wagon (only) MPG - Please Post Your Results
Discussion in 'Prius v Fuel Economy' started by F8L, Oct 30, 2011.
  1. Vinoh
    Vinoh Junior Member
    San Jose, CA
    Interesting data point: I tried reducing my tire pressure to the Toyota recommended 33 front and 32 rear. (The car came from the dealer with about 36 IIRC) My MPG dropped over 10%!
    Needless to say, I increased it, this time back to 39 front and 38 rear. I can see the average steadily increasing although I don't have a new MPG to report yet. I had no idea it would make that much difference!
    Also, the ride was much spongier at the lower pressure.
    --Dave
  2. mep99
    mep99 New Member
    Chicago
    We have now driven our v for 1500 miles and are averaging 44.3 MPG (display). It's about 60/40 city/highway. Anything above the EPA rating is great.
  3. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Is the display accurate. I know in our Prius it is off at about 3.5 mpg.
    For instance if it reads 50 mpg calculated will be 46-47 mpg.
    al
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,151
    6,308
    Texas Hill Country
    MPG Displayed and Calculated
    Year of vehicle: 2012 Prius V Three
    Date: December 18, 2011
    Miles driven: 465
    Gallons Pumped: 10.01
    Hand-Calculated MPG: 46.5 MPG
    Displayed MPG: 46.5
    Average Speed: 60
    Tire Size / Wheel size: P205/60R16
    Tire Brand / Model: Toyo
    Tire PSI (Front / Back): 35psi/35psi
    Seasonal Conditions: Mild fall weather, temps between 50F and 70F
    Commute Length: 45 miles
    Hypermiling Techniques: light acceleration when possible, highway at traffic speed
    Other: 10% ethanol, eco mode, hilly commute starts at 1300 ft ends at 800 ft then back
  5. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Re: 46.5 MPG Display and Calculated
    Looks like Toyota has finally corrected the mpg guage display
    error after nearly three years. I do anticipate that the other
    2012 Toyota hybrids will also have corrected displays.
    Thankyou for the info
    al
  6. pdp
    pdp New Member
    162
    17
    Bay Area, CA
    FYI, there are plenty others (like myself) who are consistently getting up to over 3MPG more on the computer calculated figures vs the hand calculated figures. I've had 3 fill ups so far, here are my results for our Prius v Three:
    HTML:
    COMPUTER        HAND
    45.1            44.0
    47.4            44.3
    46.8            44.0
  7. Vinoh
    Vinoh Junior Member
    San Jose, CA
    I'm also getting about 5% more optimistic numbers on the display than the hand calculations.
    I noticed that the Scangauge II has an MPG function with calibration. Anyone know if that calibration also affects the built-in display on the car?
  8. easted
    easted Junior Member
    64
    Pillow PA.
    2018 Prius
    Now have 3254 odometer reading, and have used 72.115 gals. This calculates to 45.12 MPG. The displayed MPG is 47.7 . That is about 2.65 higher displayed than caculated. Somewhat disappointed on this amount of difference of mpg, but over all well satisfied with most other aspects of this v. Driving is not aggresive, over relatively flat terrain and temp. around 60 to 77 degrees for the last 1800 miles. Prior to that, hilly terrain and 40's to 55's degree temp. The tire psi is approx 36 front, 35 rear.
  9. Lngbrdr
    Lngbrdr New Member
    Rocklin, CA
    1st fuel up:
    407 miles 10.05 gals 40.5mpg
    First tank and learning to drive. Probably 50/50 freeway and commute
    2nd fuel up:
    300 miles 5.88 gals 51.0 mpg
    85% commute and trying to get good mileage
    3rd fuel up:
    360 miles 9.89 gals 36.4 mpg
    San Fran trip, freeway 95% of miles with 3 people and 70mph.
  10. mi2k
    mi2k Junior Member
    42
    MD
    1st tank: 40.6mpg
    december/mid-atlantic/25% highway/eco mode (and tried to stay in eco range)/tire pressure as it came from the dealer
  11. dz302
    dz302 Prius Rookie
    South Carolina
    Took a 900 mile trip to Florida this week. Recorded 45.8 mpg on the first tank, and 48.4 on the second tank. Current running total for the first 4,000 miles since new is 44.9. This is calculated, not using the on-board computer, which is always high.
  12. dz302
    dz302 Prius Rookie
    South Carolina
    It does not affect the accuracy of the on-board gauge.
  13. buckaroo
    buckaroo Junior Member
    64
    Austin TX
    My last tank was 45 MPG. Looking good.
  14. pjay
    pjay New Member
    99
    Westchester, N.Y.
    So, Wuster, you're saying the hybrid CR-V has been produced--just by Toyota instead of Honda? :)
    I am the original owner of an '06 CR-V EX with no problems and 44,353 miles. Have been thinking about a Prius V wagon, as it seems to be the closest thing to a hybrid CR-V out there in terms of cargo capacity. Just don't know if I want to spend the $25K to $27K when I don't need the car for daily commuting. What year was your CR-V? Did it serve you well?
  15. pdp
    pdp New Member
    162
    17
    Bay Area, CA
    Just curious how fast you drove on your trip and if you used any techniques to get the MPG you got? We just took a near 400 mile (each way) trip from Northern California to Southern California and we averaged only 39.45MPG so far, this was calculated, the computer said 42.5. We were driving on average in the low 70s down I-5 to so cal and rarely sped up to do any passing. I'm wondering if there is anything we can do on the drive back up to nor cal to get MPG like yours.
  16. El_Spectre
    El_Spectre Junior Member
    75
    As an experiment, I did a tank on "regular" mode (no ECO, only used PWR on a couple of onramps). My calculated mileage (again, making no attempt to drive efficiently) dropped from approx 37MPG to 33MPG.
  17. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I would be very careful with interpreting your results. There are a lot of factors that go into calculating mpg differences. I'm not slamming you but I would suggest including all of the variables that could have influenced your results so that others can determine if your numbers were the result of weather, commute, road surface, driving style etc. rather than just changing driving modes. :)
  18. El_Spectre
    75
    Agreed. However, since I drove pretty much the same places/times/distances as I ever do, and the weather hasn't changed appreciably, there was no need to mention those things.
    The bigger concern, scientifically speaking, is drawing a conclusion based on one tank. Take anecdotes as you will.
  19. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Agreed. :) Thanks!
  20. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    @pdp; I have been driving like you or even more aggressive. I have been driving my Prius v5 w/ATP like my 2000 Lexus RX300. That means average speed on hwys is 75mph even up hills. But speed kills MPG stats as detailed in this good writeup:
    http://www.metrompg.com/posts/speed-vs-mpg.htm
    So if you want better MPG you will have to slow down. When you do the math you don't lose very much time by going slower. I have started to tell people that my wife's 08 Prius 5 makes it fun to drive economically and my Prius V5 makes it fun to drive aggressive again. I only have one tank (411 miles) tracked on fuelly and it reports 38.3 MPG. I'm treating that as a worst case MPG because I have been driving aggressively, testing all the driving modes (Eco, Normal, Power, EV when the car wants to in this cold weather), warming up 1 -2 min while Grammy gets it the car, tire pressure 35front/34 rear, cold temps 20s - 50s.
    Secondly look up all the good Prius Chat threads on “hypermiling”
    Lastly, make it fun to get good MPG stats.
    Here are some questions about your trip that could affect your MPG stats; What driving mode were you in for your CA trip? How many lbs in the Prius? Tire pressure? Average air temps?
