Prius V map hard to read
Discussion in 'Prius v Main Forum' started by jbaley, Mar 12, 2012.
  1. jbaley
    jbaley New Member
    Huntington beach,CA
    I am dissapointed by the Gray background and tiny type for street names on the map display. My Garmin handheld is easier to read even though it is a much smaller screen. My LS460 has a easy to read map.
    Can I change the background color and or type size on the display?
    Is there an app I can download to improve readability?
  2. Keiichi
    Keiichi Active Member
    808
    79
    Goleta
    Not sure about the readability, but I think your nav system should have some customization via setup. But since I am on a Model 5 version with ATP, my nav system is slightly different than yours as to the options.
  3. Wanderer
    Wanderer Hybrid neophyte
    366
    39
    Cold country
    You may try setting it to 2D. I find that easier to read. W
  4. jbaley
    jbaley New Member
    Huntington beach,CA
    The problem is the gray background makes the small type blck street names hard to read. 2D does't fix it/
  5. PDXstriper
    PDXstriper New Member
    Portland, OR
    I noticed the same problems. For all this technology, the navigation system on our shiny new 2012 Prius V is the worst I have seen in years. It is very hard to read. Any Garmin, iPhone of Android device is much clearer. How could they ship such low quality? Odd...
  6. Eileen82
    Eileen82 New Member
    us
    2012 Prius Alpha
    [​IMG]The problem is the gray background makes the small type blck street names hard to read
  7. Retchiefmcl
    Retchiefmcl New Member
    Cresskill, NJ
  8. rcturner
    rcturner Junior Member
    53
    The entire standard nav system seems pretty limited. The are so many limitations to what can be done with this system that it really isn't worth the effort to use it.
  9. parnami
    parnami Member
    227
    47
    .Lancaster, PA (Amish Country) :)
    I have a V5..and the standard nav ..it's really not a bad system. Not quite as intuitive as a Garmin.but it does pretty much all the same things. You just need to spend some time playing with it sometime; Like a few hours..parked!!
  10. Donrim
    Donrim Junior Member
    Illinois
    The "night" display is hard to read as it greys out the lettering on the screeen. I just selected to keep it in "day" display all the time and don't have the visibility problem. You can also adjust the contrast of the screen to make it easer to read during the day. Now it is fine for me.
  11. ovni
    ovni Member
    243
    91
    Sugar Land, TX
    The nav is horrible!!! Nothing beats the 06 to 09 nav screen. Toyota went cheap starting in 2010
  12. Crunch
    Crunch Junior Member
    NC
    I agree. Use my droid phone more than V sytem.
    It would be nice if I could just extend my droid phone screen to the Prius screen.
