Prius v: Multiple Warning Lights, Hybrid Battery Code, but 12v Disconnect Fixes it. Huh?!
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Merv Himself, May 9, 2020.
  1. rjparker
    rjparker Tu Humilde Sirviente
    10,153
    6,310
    Texas Hill Country
    Merv wants to fix it Himself
    #21 rjparker, May 9, 2020
    Raytheeagle likes this.
  2. Merv Himself
    Merv Himself Junior Member
    71
    Georgia, Florida
    2013 Prius v wagon
    Thanks. Please re-read the first 2 sentences of my post.
    The premise of my post is to find other possible solutions without a costly trip to the dealership. I respect all opinions, but let's be real, nobody comes to Prius Chat to be told "go to the dealer". We all know dealers exist and that's an alternative that goes without saying. What I'm kindly looking for is people who may have had or heard of similar issues. Someone with some insights that might help me piece together a solution to this mystery. If there aren't any answers, I will respectfully accept that. But I am looking for ideas BEYOND "go to the dealer". That's the point of this thread. Thank you again.
  3. rjparker
    10,153
    6,310
    Texas Hill Country
    Its pretty clear you are not reading the posts or we are not communicating well because of a lack of a common vocabulary. I suggest an obd2 reader with the apps needed and you say maybe if its not too expensive. The post shows its $28 from Amazon. Others recommend the same app and explain how codes are not instantly set after a reset. One suggests a $75 diagnostic. Around here that is a dealer price for a half hour. Another gives you a contact for a priuschat member that has the factory scanning ability. Probably free. But you act like we are failing to read your question. “Hi all. I'm trying to avoid a trip to the stealership. Any help would be much appreciated.” Not sure its really appreciated.
    So maybe we should say check the battery fan. Wait we did suggest that, even though that $28 scanner will tell you the exact temperature in real time if your knowledge base is there. Without spending an hour to get to it. I am sorry if some us suspect that the “most likely” problem is the battery. But that is the only code you provided.
    When you get a bill from us for three hours of diagnosis time on your car with our tools, then I might complain if no pathforward is obvious. In the meantime I believe you are getting first class advice from people who have been there with the exact same concerns.
    jzchen and Raytheeagle like this.
  4. ChapmanF
    18,204
    I'm not seeing as much of a mystery. You're being given a trouble code that tells you your traction battery is not long for this world. The mystery "how can I be getting that code when I don't think that's the case?" seems like more of a self-created sort of mystery. It seems you think that can't be the case, because your car drives like a car without a failing battery, every time you force it to it forget that it has a failing battery and should be driving protectively.
    Chances are you will be succeeding at making it forget that for shorter and shorter periods of time, and you may or may not have one of those periods of time end with a pop, bad smells, and a tow.
    A dealer visit is optional, but it would probably be a good use of time to research what you're going to do about the battery. A simple and good option is to replace it. A much more complicated and usually shorter-term option is to take it apart and whac-a-mole individual problems. All of the options are discussed at length here on PriusChat.
    In any event, having a working Techstream rig so that you can avail yourself of all the information the car is trying to give you will make a lot of things easier.
    The reason other dash lights come on at the same time is that the different computers in the car talk to each other, and some will set trouble codes and light dash lights because they know of a problem detected by another ECU. For example, the brake ECU has to know about issues detected by the power control ECU, because it needs to count on the latter to make regen braking happen. When it becomes aware of a problem, it will set codes of its own accordingly, and light the brake/slip lights on the dash, which it is responsible for.
  5. Merv Himself
    71
    Georgia, Florida
    2013 Prius v wagon
    Thanks, RJ. I see you are a senior member. It seems you feel insulted that I'm trying to cultivate a variety of answers. I don't know what to say, other than I'd like to keep this thread focused on the matter at hand, rather than getting in a hen fight over who said what.
  6. Merv Himself
    71
    Georgia, Florida
    2013 Prius v wagon
    I hear ya, but MPG is such a simple common-sense thing to pay attention to. Do you seriously think a Prius with a bad hybrid battery would be getting 51 MPG? Now seriously, think about it.
  7. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    The repair manual for the Prius is 1000 + documents. It's much easier to take advantage of the built in diagnostics than to figure out the problem without it. Battery or not, get the codes read and call us in the morning...
    moto g(7) power ?
  8. ChapmanF
    18,204
    Are you assuming I haven't thought about it? Or just not seriously?
    Merv Himself likes this.
  9. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    Merv, people who have given you suggestions are frustrated because you have not indicated that you have followed or plan to follow the advice given including low cost ones like getting an OBDII bluetooth adapter from Amazon and running the Dr. Prius app. So, please indicate what you plan to do now that people have made several suggestions other than go to the dealer.
  10. mikefocke
    3,998
    1,807
    Sanford, NC
    There is a difference between an OBD2 reader and a OEM diagnostic computer. It all starts with the law that said that non-dealers must be able to diagnose ICE problems and emissions troubles. And so the generic code readers can. But modern cars are far more complex and the dealers computer not only reads lots of codes that a generic code reader doesn't relating to systems beyond those covered by the generic OBD2 reader but also has links to recommended diagnostic sequences, parts numbers, TSBs, etc that help the tech efficiently troubleshoot. And shotgunning gets really expensive.
    In my garage I have a generic OBD2 cose reader (Actron). For my last car (a 2001) it would read less than 25% of the possible error codes that car could emit. Now fast forward to your car and its hybrid nature.
    My suggestion would be to post your location and see if someone can point you to a trusted hybrid mechanic or battery replacement place. Sometimes you just have to spend the money to shorten the time between problem to fix.
  11. ChapmanF
    18,204
    One reads a lot about people here setting up an old Windows laptop to run the same magical software used at the dealership, which is called Techstream.
  12. Merv Himself
    71
    Georgia, Florida
    2013 Prius v wagon
    Yes. Definitely. As soon as I get back to the car, I am going to get the codes. Will probably order that OBD2 bluetooth code reader someone suggested and let the thing sit in the garage until I can figure this out.
    jzchen likes this.
  13. Merv Himself
    71
    Georgia, Florida
    2013 Prius v wagon
    I have read that also. However, I'm a Mac guy without a windows laptop. Go figure. I do , however, have a PC tower. Tempted to haul it out to the garage and use that software on it.
  14. royrose
    1,389
    953
    Foot of Pikes Peak
    Dr. Prius recommends the Carista adapter. Hybrid Assistant App recommends the OBDLink LX and also says Carista is OK. I have the OBDLink LX and it works well.
    #34 royrose, May 9, 2020
  15. ChapmanF
    18,204
    I think some people have run it on Mac under virtualization.
  16. Merv Himself
    71
    Georgia, Florida
    2013 Prius v wagon
    Yes, I am going run the codes. Never considered not running the codes. Not sure if people are expecting me to run back & forth to the garage or what, but I'm not even anywhere near the car right now. I've expressed thanks for every suggestion.
    What I've been trying to explain is that, in my view, the generic P0A80 code "replace hybrid battery pack" is permanent and does not get wiped when I disconnect the 12v battery. Therefore, that is why it's the only code popping up when at the Auto Store. Not because they have a bad scanner, but because other wipeable codes have been erased. Therefore, my plan is to wait until I get all error messages lighting up again, and at that point, I will NOT disconnect/reconnect the 12v before reading the codes. It is my hope that more codes other than the P0A80 will then manifest themselves.
    Importantly, I no longer feel good about driving this thing to the Auto Store, or at all for that matter. Thus my presence here. But to scan it, I have to order the correct device. In the meantime, as mentioned, I was simply wanting to talk through the situation and pick people's brains to see if anyone had similar experiences or suggestions beyond my obvious need to read codes or go to a dealer. (BTW, I called around to find out what a dealer scan would cost. Cheapest quote was $140. That's why I call them STEALERships.)
    Thoughts that leap to my mind are the Inverter Coolant Pump, The Battery Fan, Maybe Coolant Control Valves? Some sort of inverter cross-over switch thingamabob? Was hoping others could chime in on possible solutions. I know it's all theory at this point.
    IMPORTANT TO KEEP IN MIND: When this problem acts up, the ICE just keeps running but NEVER switches over to hybrid power. If there is a problem causing that, it seems to be solved when I do a 12V battery reset. Yes, I realize I'm just resetting the error lights but is it possible it might be having some other positive effect? Because after doing so , the ICE switches over to Hybrid power again, just as the system is designed to do.
    To Summarize: Will I read the codes: Of course. Will I allow myself to be bent over at a dealership? NEVER. You'd have to know me, but I swear I'll find a way to build a hybrid battery out of empty toilet paper rolls, lithium & tablesalt before I allow the "master techs" at a dealership to screw me over.
  17. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,091
    Columbia, SC
    Merv, The answer to that question is 100% yes. Up until the point where the battery totally fails and puts you in limp mode at all times.
    The P0A80 code merely is giving you a warning and car drivability remains the same. Once a module fails badly enough to trigger a P30xx code to indicate a specific module, the car will go to limp mode.
    The car is not lying to you. You're just failing to listen to it right now.
  18. Merv Himself
    71
    Georgia, Florida
    2013 Prius v wagon
    Excellent info. Thank you! Didn't realize the hybrid batt performance was an all-or-nothing kinda thing. So what's with the brake system warnings?
  19. TMR-JWAP
    6,404
    6,091
    Columbia, SC
    Although I specialize in Gen 2 batteries, I have worked on some Gen 3s. The ecu's in a Prius are not isolated from each other. Many ecu's will trigger additional codes once a hybrid code triggers. Basically, if a battery triggers a HV code, other ecus linked to the HV system will also trigger codes saying, "OMG..there's something going on with the HV system"
  20. TMR-JWAP
    6,404
    6,091
    Columbia, SC
